查看: 5825|回复: 3
美国的斜齿轮图纸的英文,谁能帮忙翻译下,不胜感激!
发表于 2010-9-28 10:20:57 | 显示全部楼层 |阅读模式
1.: ]& i* `0 V4 m' _" T3 z8 q
Quality: ANSI/AGMA 2000-a88-q11, full depth, full fillet.
2.
( h9 g) {9 j% i3 }4 \1 J8 p
FOR LEAD, CROWN, AND PROFILE TOLERANCES SEE DWG 54773379
3.
9 @( [6 X/ t. z8 v3 a. J+ Z
CROWN DRIVEN GWAR ONLY
4.! I6 O" W' O' G
NORMAL PRESSURE ANGLE 20”
5.
3 P: u3 _* y! `& `% d4 y
NORMAL DIAMETRAL PITCH 8
6.
7 J" R: i& c0 @  |5 {
NORMAL CIRAULAR PITCH 0.3927
7.
8 R' l. j6 L  q9 \% ~8 S
HELIX ANGLE:16.6011
8.
' S' `' Z5 R& `3 I6 ^
BACKLASH TO BE 0.996” TO 0.008” ON 6.9784” CENTERS
9.
7 Y( ?# ?7 N6 X* d7 J1 s, _9 @1 O. p9 i) V
MATERIAL: AISI 8620
10.' @  A  T% [9 q7 _7 ^
CASE CARBURIZE TO 0.025” TO 0.040” EFFECTIVE FEPTH AFTER GRINDING AND HARDEN TO 57-61 RC, CORE HARDNESS# |5 J( k' V9 A: U  g' ?# M, n
TO BE 25-40 RC.
11.3 C: o/ ^4 s- H7 X+ b; j. a# G# D: k+ [
RETAINED A USTENITE – 5% MAXIMUM BY VISUAL INSPECTION.
12.* ?7 \( @% |; F7 j* d$ S
EACH GEAR DEAR SET TO BE BOXED SEPARATELY AS A SET AND EACH GEAR MARKED WITH THE SET PART NUMBER ON THE OUTSIDE. EACH GEAR TO HAVE P/N AND SUPPLIER INENTIFICATION STAMPED. EACH GEAR TO HAVE P/N AND SUPPLIER IDENTIFICATION SATAMPED OR ELECTRIC ACID ETCHED AS SHOWN, APPROX. TEXT HGT..25’.
13.
9 S! x0 U* k6 ]/ g# n1 H
REMOVE ALL CHIPS FROM TAPPED HOLES.
NUMBER OF TEETH
HAND OF HELIX
LEAD OF HELIX
PIRTCH DIAMETER
BASE CIRCLE DIAMETER
ADDENDUM
WHOLE DEPTH
TRANSVERSE CIRCULAR
TOOTH THICKNESS WO/BL
NORMAL CIRCULAR
 楼主| 发表于 2010-9-30 08:14:12 | 显示全部楼层
; v2 C" O  g- S; j3 l  E* J, g: f6 C
没有人翻译,找到了资料,不知道对不对!望高手出来指正!
8 k, \3 P. Q+ h$ o' A5 v* f        齿轮制造标准和精度等级:ANSI/AGMA 2000-A88,精度12级,全深,全倒角。
8 I* Z+ G& f, M6 P* O9 {+ V        齿向、齿形修缘和渐开线轮廓公差按54773379图纸规定。7 {6 f6 Q) R- B$ d/ q! R% _
        仅驱动齿轮鼓形修整。+ J, b; Q8 \% b
        齿形压力角20º
7 ~+ t% J+ W5 W        节径DP=10
+ y* l. Z) v" a& l+ @        齿距:0.3142
# C4 \! m- Q: G6 w+ m2 r+ P        螺旋角:15.9355º
  D$ K" y; F. G1 z, ~, l; A9 _        在齿轮啮合中心距5.5118”上,侧隙要求在0.006” ~0.010”之间。4 D5 F, x, D, t9 G& ?8 \- w3 `
        齿轮材料:AISI 8620& u$ I! W$ {# p" E
        渗碳层0.025”~0.040”有效深度,表面硬度为57~61Rc,芯部硬度25~40Rc。6 F! s3 k& k# g0 k4 F
        残余奥氏体最大5%目测检查。
) g3 ?- O4 o7 |( K+ n$ t- l        每个周转盒内只能装一个齿轮组,周转盒外标记齿轮组图号,齿轮表面须按图示部位用电蚀法标记零件号和供货商代码,字高约0.25。4 Y3 e* A$ V' D1 w+ L1 J
        攻丝后,去除螺纹孔内的铁屑。
发表于 2010-11-11 17:02:45 | 显示全部楼层
楼上玩意的好专业,佩服!!!
发表于 2010-11-21 20:44:23 | 显示全部楼层
二楼挺专业的···感觉还不错,很值得学习。
GMT+8, 2025-4-26 10:32 , Processed in 0.068685 second(s), 15 queries , Gzip On.
