楼主: 沈阳田野
关于42CrMo钢焊和冷裂缝热裂缝的问题---讨论
 火.. [复制链接]
发表于 2010-7-25 20:32:17 | 显示全部楼层
我们用R307焊接过,效果也不错
 楼主| 发表于 2010-7-25 20:41:04 | 显示全部楼层
回复 21# 林123 1 V- V% I( g# d" w2 V
) k+ `( S$ Y" S( F, k* w5 {) n% \( \/ Q/ j" F$ t2 ~
    说说你的焊接工艺。。。。。我知道这个材料有很多种办法能够焊接,........................................在质疑声中需找技术的真谛
发表于 2010-7-25 23:36:02 | 显示全部楼层
我只觉得你OUT了
 楼主| 发表于 2010-7-25 23:41:03 | 显示全部楼层
回复 23# 渃梨梨
9 n" S1 G7 r- C+ r2 h. P! d% }* v7 b. J" ?+ D6 ^. _
9 d/ |; d! j) T* Z. a# m) I' T    那是你用不正常的心理来看待问题。谁OUT都无所谓。) t. m* Z  R, q; g4 S- p+ f: p% m
                                                  多于少,得于失In human life: It should be a little more compassion and less nausea. Should be more good and less malicious. It should be a little more truthfulness and less abusive. Should be more good deeds and less evil deeds, do more good deeds, to do less evil, more product of some German, some less evil. In the attitudes of people: we need to have the friendship and less hostility. For the mistakes of others, to forgive more and less blame. When someone difficult time, more help and less apathy. When people feel embarrassed when some more face and less to some ugly. When the others when the mental inequality, more persuasion and less burn some primer. When the views of others when they have more exchange of ideas and less misunderstanding. When people appreciate their time more modest and less pride. When others criticize their own time, more reflective, less resentment. Issues in more than fame and fortune to the other person that their struggle a little less.................................
发表于 2010-7-26 09:22:39 | 显示全部楼层
很明显,这段文字不是一个一个字敲出来了,其中有很明显的“如像楼上所说”。楼主自己码的文字,哪有什么楼上不楼上的?那别人的东西来讨论,无可厚非,但非要说成是自己的东西,就有些不厚道了。1 w) E4 {' v% a/ V, s
( Y6 m1 c# d' q窃书不能算偷的话,俺无话可说。  J' G8 b/ K+ V+ ~4 k8 Q$ h
; y6 E5 D- f% Y5 F% H3 Q0 D( f俺只是一小兵,经不起大阵势,闪人!
 楼主| 发表于 2010-7-26 23:22:06 | 显示全部楼层
回复 25# 贝氏弧线
# F' P& _8 {7 M( y' r: {6 d
6 k" q- A9 A) j+ X4 E& t; C, I
6 v# P- E1 R; j* N    哈哈,我的知识从哪来,都是学出来的,我从何处学的,当然是书里的知识。如果高手一看就能看出问题的所在,J507焊条也不是最理想的,我希望你能在我发的文章里挑出毛病,而不是挑谁的产权问题。这样说明一个人的肚量太狭隘。以前我看到很多人发的文章,都是我发表过的,但我从他发的文章挑出文章哪地方需要改进,哪地方需要在修整下。而不是争论产权问题。* o, x3 k8 E4 [5 |/ [, V* ~
  你们啊,要用长远的眼光来看问题把。。。。。。。。。。。。。
 楼主| 发表于 2010-7-27 00:45:45 | 显示全部楼层
既然我敢发出来,就不怕争论,................
发表于 2010-7-27 07:35:37 | 显示全部楼层
哦,明白了,原来是别人“引用”你的。
发表于 2010-7-27 14:31:23 | 显示全部楼层
学习中,积累威望值中.....
发表于 2010-7-27 19:08:08 | 显示全部楼层
我们用R307焊接过,效果也不错: r7 a7 ^8 `* @
预热350度,用红外线枪测温& S8 B4 P" W4 q' Z
用预热的4mm焊条焊接,层间温度不低于300度
' M2 M% k/ j6 E焊后立即消氢处理(若立即做消应力热处理可不用消氢)
GMT+8, 2025-10-19 01:00 , Processed in 0.071036 second(s), 13 queries , Gzip On.
