查看: 5161|回复: 11
液压油使用注意事项
 火.. [复制链接]
发表于 2010-7-20 19:31:02 | 显示全部楼层 |阅读模式
最近注册了一个国外的网站(网址见文后),经常通过Email给我发送液压领域内的各种注意事项。现共享一封我翻译的邮件,与朋友们共同学习……, C. g' G/ }; @
" y/ T+ M$ l4 s- A
Here's four quick tips for you to get the most
/ v7 p2 V$ s# u% Y' Z% zout of THE most important component
3 W& @- j4 o3 _  D  G3 L9 F& mof every hydraulic system  - the oil:
0 i9 ~) j  O7 d% O& p9 R( m: ?& M1 [  v; H' A
1. Don't change the oil - filter it.$ D5 t. \" |9 p* K. S* A- t
Water or particle contamination rarely necessitates an oil change7 l! t" G% `9 H% r" Z
- unless the contamination has resulted in additive depletion or
0 N0 H+ o# H# O5 Vbase oil degradation. These contaminants can be removed from
& |! x1 e/ v* n0 Zhydraulic fluid by filtration. 1 @, |) Q' P0 {6 `4 q' h9 ]
! v4 U: O: p7 C4 T; O2. Eliminate particle contamination to reduce breakdowns.../ [4 M! C. \1 }  E. J" W
Research has shown that maintaining fluid cleanliness at ISO 44064 Z0 f( A5 A) ~5 q
16/14/11 will result in a tenfold increase in the average time 0 K, H8 X4 O' K% V
between breakdowns when compared with a fluid cleanliness level 9 F9 L" ?" S' J; O6 d7 I
of 24/22/19. This is based on the findings of a three-year study of
7 ~4 [, c' o3 _  @3 o2 b9 ~4 A117 mobile and industrial hydraulic machines to determine the ' e# Q! E% l0 t1 y6 p! }
correlation between fluid cleanliness and breakdown frequency.
7 e) H1 m! m( ~! o: i/ n& h' B, O2 u) I
1 z( [, u( h7 q* j0 Q; L* k3. ...And extend fluid life.
- }3 M. i" I( g4 t3 \' U3 cParticle contamination reduces the service life of hydraulic oil
& B# Q! C$ g# G% G# Pby stripping additives and promoting oxidation. Additives attach ! ~5 C6 Q0 s" a  I6 s
to particles, which are then removed by the filters or settle to
5 ^4 u' g) w. {  H) Z  k  u1 Xthe bottom of the reservoir. Wear metal caused by particle & {7 a$ N7 L' n) w/ n5 d
abrasion is a catalyst for fluid oxidation.
" U7 G) X# u7 J" n( b6 R/ X4. Keep it cool.
/ e0 T' O: H* ~7 g* ]1 B1 IElevated operating temperatures increase the rate at which the 1 N1 M4 o: n: J( M! i4 E3 \6 F
oil oxidizes and this decreases its service life. By-products# i8 p) _  q4 s$ e% i8 l
of the oil oxidation process - varnish and sludge, can cause0 q& H7 o' p( X7 R0 G1 O. m. E
reliability issues such as valve spool stiction and
- p# ?. Q6 n+ h2 o' D1 l9 _filter clogging.( W7 ?* t1 n7 b. y+ P
/ S0 q4 ]/ Z% |, w1 A0 x* o& `; f6 o6 ~2 j* G3 ]+ L
# p3 Q# l6 L& k! a, n, a我的翻译
# j0 W6 ~1 ]8 E2 M) v1 E* z- q. y7 I
下面是四个快速提示,从中你可以以最快的速度了解每个液压系统最重要的组成部分——液压油的使用注意事项
) H$ C: z) l" `' v1。不要更换液压油 - 而应该过滤。
, x# H2 t* y! v2 r+ K2 e水或颗粒性质的污染很少导致必须更换液压油——除非污染已经导致添加剂耗尽或使原本的液压油降解。这些污染物可以通过过滤的方式从液压油中去除。
# Q% [$ X7 ^' U4 Z. \# N: n! ~2。消除颗粒污染以减少故障……$ Y. {% m2 Y! t* {8 A2 k
研究显示,保持油液的洁净度在ISO 4406 16/14/11标准下,相较于保持在标准24/22/19下,将导致两次故障的间隔时间平均增加了10倍。这是根据一项为期三年的、关于117个移动和工业用液压设备的研究所得出的结论,该研究用以确定油液的洁净度和故障率之间的关系。
$ y! g9 J* y2 O4 @8 r1 v; c3 Q- y: O3。 ……,延长油液的寿命。 : N. W' {" z# U* Z9 F/ d& M
颗粒污染通过剥离添加剂和促进氧化降低了液压油的使用寿命。添加剂附着在颗粒上,或者被过滤器滤除或沉积在容器的底部。由于颗粒摩擦所造成的金属磨损是液压油氧化的催化剂。 3 d( X* ]; b" B/ \
4。保持液压油冷却。
5 ]% n+ W2 h; t9 V3 H过高的工作温度加速了液压油的氧化速度,降低其使用寿命。油氧化过程中的副产品——涂料和沉淀物,可能会导致可靠性问题,如滑阀运动的粘滞和过滤器堵塞。
发表于 2010-7-20 20:45:51 | 显示全部楼层
洁净度在ISO 4406 16/14/11标准,,具体什么意思
发表于 2010-7-20 20:51:43 | 显示全部楼层
您好:译得真是很专业!
 楼主| 发表于 2010-7-23 12:47:25 | 显示全部楼层
% l& `5 j+ Q/ L浪漫满屋 发表于 2010-7-20 20:45
4 d7 \- |; c6 d" J2 P3 Z, F1 w2 n8 U' S6 d  |7 `
% Q* C) b- s% b- r7 x 估计这是ISO的标准,只要知道ISO4406文件,一看便知……
6 ]* j2 W+ x+ n/ b. ?: O9 ?
$ a# h, p! g1 P6 ~我翻译的时候也想找到这个标准原文,可是网上的都是付费下载,暂时还没有得到标准原文。! X6 E" s% I7 p3 ]
& n" |# L$ l! W: W6 f, F/ b
你想了解,可以参考国内的标准看看。
发表于 2010-7-23 23:23:42 | 显示全部楼层
液压油的过滤产品挺贵的
发表于 2010-7-24 21:06:31 | 显示全部楼层
液压油清洁标准也可采用 NAS1638标准
发表于 2010-8-10 20:45:16 | 显示全部楼层
买油有时候很难买的哦
发表于 2010-8-11 22:53:12 | 显示全部楼层
译得真是挺好的!像楼主学习!
发表于 2010-8-12 07:57:05 | 显示全部楼层
英语搞不懂,不过汉语还是挺明白的。呵呵
发表于 2010-8-12 11:57:00 | 显示全部楼层
varnish and sludge是指沉积物及油泥。0 Z' D  }# M, u. q, q
ISO 4406 16/14/11是指系统中大于4μm的颗粒计数为16级(相当于320至640个/ml),大于6μm的颗粒计数为14级(相当于80至160个/ml),大于14μm的颗粒计数为11级(相当于10至20个/ml)。
GMT+8, 2025-10-27 19:55 , Processed in 0.072574 second(s), 14 queries , Gzip On.
