查看: 12773|回复: 8
数控车内孔尺寸逐渐变大---请教
发表于 2010-1-25 13:32:24 | 显示全部楼层 |阅读模式
数控车床,车铝合金工件40.5mm的内孔,公差0.03mm,一批车下来内孔尺寸逐渐变大大概四十件(一个小时)变大0.01mm。我们做了系统X轴的重复定位测试,一个小时变化在0.002mm之内。另外,内孔车得不圆,椭了0.005mm到0.01mm。请大家帮忙分析!
( R' ]6 I3 q+ i0 A# A+ r; [3 b; B6 }- Q
序号   左右位(mm) 上下位(mm)
3 [+ A: A6 L7 k3 Y8 r1        40.508        40.508- O0 o- {' _; L9 ~+ J( q
2        40.508        40.513
( g& s# D+ M2 x8 h' K9 y; ^/ y* B3        40.511        40.513* t8 k" C6 n( ~7 c7 A5 j! o) M5 r
4        40.51        40.512" c4 ~% g$ E6 [# k) w/ `
5        40.509        40.5092 s4 P: R" U0 H  [9 E* S8 n. ?4 w9 B
6        40.511        40.511. e& p2 e; g9 ^! y5 d
7        40.511        40.511
3 s  A# q; P- ^7 j& s' H2 B- B8        40.51        40.5121 b$ {" [: m0 {! v- L7 s
9        40.51        40.511  W& ^/ a; ~- B, E: u
10        40.512        40.513& ?' I# S( d8 o9 j2 s, _& @
11        40.51        40.513
9 I. V/ P7 H3 c% ^# ~8 J12        40.512        40.5152 p. n/ c( \& f6 f! O6 z1 p
13        40.511        40.514& a% O: \& n0 I! E
14        40.509        40.511& q+ p6 A5 E0 K  Y3 ]" O
15        40.51        40.511
! n0 ]( F7 B* y+ c/ a3 O8 J8 [16        40.511        40.513; V% d" ^8 c" M. e6 [
17        40.51        40.5112 s! ^( S# D$ Z/ A4 q* }
18        40.511        40.5131 ]8 ]" ~* M' ?2 t# J6 \9 z% g
19        40.512        40.514& y* Q+ y9 A9 E& L( f) V
20        40.512        40.516
& E' \( E1 A4 c' d! h" j+ f+ _21        40.513        40.515
4 U8 d+ k4 g' n# a6 Z! z1 x22        40.514        40.517
. F: X/ R: ?" U% J5 |, O3 N23        40.514        40.517
) j) ^0 I% ^; p. ~  Q* ~24        40.513        40.516( y. V& v3 u4 L# B& C
25        40.513        40.517
1 T5 }2 [/ G! D9 C/ C, W26        40.515        40.5180 x' k, L* R8 i3 S+ _+ j
27        40.515        40.52
1 U3 m! d) R5 N0 K3 n5 Y/ o# Y28        40.516        40.521/ o+ D* [" k9 ^; u, u" U
29        40.516        40.52
$ l: v$ `$ k+ \: k( o, k30        40.517        40.521, N! N* P7 W5 |7 ?
31        40.518        40.52* Y. a6 F& a# p6 \8 e
32        40.518        40.522
/ J' \' p6 G1 q6 B8 z33        40.517        40.5198 @- v! n3 U1 w+ Q1 x' z& G
34        40.519        40.521
9 w2 F3 s7 J8 J% j1 V. {5 G35        40.515        40.525
! |3 J: ^1 H" N& w, L# Z  U: T36        40.52        40.528 i' f7 ~2 V# Y
37        40.52        40.524
- B7 X$ I7 k1 a' A5 d38        40.521        40.522
, ]" i( S4 r8 W- H39        40.52        40.523# f. ~$ H! ^3 `- @& L$ E' g
40        40.521        40.523
 楼主| 发表于 2010-1-27 13:51:22 | 显示全部楼层
顶起。。。。。
发表于 2010-1-27 17:49:49 | 显示全部楼层
检查是否加工硬化, 震刀, 刀尖粘铝或积削瘤等.
发表于 2010-1-27 18:32:41 | 显示全部楼层
最后精加工余量放0.2毫米,使用金刚石刀具,精车转速快进给量小。考虑成本问题,可以使用硬质合金刀具粗加工,金刚石精加工。精车可以用高压空气或者用强力的切削油排屑,加工设备附近的温度尽量变化少点。另外装夹还需要考虑。产生不良的原因不一而足,楼上的说的也有道理,先也只能说这么多了。
发表于 2010-1-27 19:51:09 | 显示全部楼层
) E, B" b1 L, I* m; ]+ q建议粗车和精车严格分开
发表于 2010-1-27 19:56:16 | 显示全部楼层
工件是铝合金,由于铝合金的膨胀系数大,所以得看你工件的形状和装夹方式(铝合印硬度低!)
发表于 2010-1-28 12:51:41 | 显示全部楼层
是哦,铝合金不同的温度加工出来尺寸不一样。
发表于 2010-1-29 21:26:11 | 显示全部楼层
铝合金不同的温度加工出来尺寸不一样,注意冷却,还有就是铝合印硬度低,注意工件的形状和装夹方式
发表于 2010-1-29 21:42:01 | 显示全部楼层
精车要求高的内孔,精车刀具非常重要。排屑要好,刀具各角度面要求镜面(尤其是铝合金)。不知道你的产品内孔长度有多少。排除机床导轨与车头精度的问题后,剩下的就是刀具和冷却的问题了。
GMT+8, 2025-4-30 12:30 , Processed in 0.056871 second(s), 14 queries , Gzip On.
