发表于 2009-12-20 19:42:08
显示全部楼层
根据下面的图标分辨:6 W$ F7 |. p! x7 [+ f' E0 v- h4 X9 {
/ y1 \: R3 s6 g: @6 J$ z: j帮助文件中对创成式外形设计的介绍:" h3 F P; B# a! i& s9 n
The Generative Shape Design workbench allows you to quickly model both simple and complex shapes using wireframe and surface features. It provides a large set of tools for creating and editing shape designs and, when combined with other products such as Part Design, it meets the requirements of solid-based hybrid modeling.
5 g3 f3 G% Z! V1 K! v# ~1 tThe feature-based approach offers a productive and intuitive design environment to capture and re-use design methodologies and specifications. * |; P8 U$ A4 f, b8 {
This new application is intended for both the expert and the casual user. Its intuitive interface offers the possibility to produce precision shape designs with very few interactions. The dialog boxes are self explanatory and require practically no methodology, all defining steps being commutative.
( L( r( w% T% N/ J ^% gAs a scalable product, Generative Shape Design can be used with other Version 5 products such as Part Design and FreeStyle Shaper and Optimizer. The widest application portfolio in the industry is also accessible through interoperability with CATIA Solutions Version 4 to enable support of the full product development process from initial concept to product in operation. |
