查看: 2265|回复: 0
注释翻译---求助
发表于 2009-11-28 10:03:28 | 显示全部楼层 |阅读模式
1.THEN  REMOVE  ALL  OILS  ,MOLD  COATINGS, ECT. BY .SOLVEMENT  CLEAING ,FINAL   RINSE  CLEAN SOLVENT.0 e9 c, o9 R# ]% l  D' B
2.MASK  SURFACES  AS  SHOWN  ON  DRAWING .3 ?: `" `- p+ `
3.ABRASIVE   OUTER  SURFACES  PER  SSPC-SP10. 0 ~& E. @4 q$ \3 P+ ~1 `) U: [" X
NOTE: IF  THE  REQUIRMENTS  FOR  DISCOLORATION  AND  TO  A  SURFACE   PROFILE  OF  1.5  MILS  CONFLICT  CONCENTRATE ON  PROFILE.
4 K  c6 _% m; H/ [6 f7 UNOTE : MUST  SIGN  AFIDAVIT  .NO  MORE  THAN  12  HOURS   ELAPSED  BETWEEN  GRIT   BLAST  AND  PAINT.
1 O* Q; M+ c) v1 p3 {. i4.CLEAN   OFF  ALL   DUST   WITH   A   VACUUM.6 X4 v) x" J+ @7 x( Y
5.APPLY  ONE  COATING   OF   TNEMEC    140-1255(BEIGE)  POLYAMIDOAMINE  EPOXY ,PRIMER  COAT  ALL   OVER  4   MILS   DRY   FILM   THICKNESS  7   MILS   WET   FILM  THICKNESS& h8 j  ?, k, ]: q
6.FILL   OUT  PAINT  QUALITY  ASSURANCE   FORM  .. K( F+ f5 h. t7 Z% N' r/ E+ ~3 @5 P5 I  W
7.AFTER  PAINT  IS  DRY  REMOVE  THE  MASKING.
9 k) {( c- h5 _6 k大家好,上面7句是关于油漆的说明,有哪位仁兄能帮忙翻译以下,特别是第3,4,5,6条。小弟在此感激不尽
GMT+8, 2025-4-25 17:45 , Processed in 0.074517 second(s), 14 queries , Gzip On.
