technical characteristics! j3 m0 H) @' p7 e
; T% g" N l1 }4 U
1/intended for transportotion of barreis with titanium sponge Q4 l2 g7 N ?8 _- w1 I2 G
2/width of operation zone,mm-860
7 @- c, g( W' n P. `" [ O& f/ z6 q3/length of operation zone,mm-2600/ b# v% F/ X0 Z2 S
4/type-powered conveyor" \: t6 `! d, O0 j3 a" ~
5/reverse operation mode/ W" Q1 {- `0 u9 G- x- w
6/roller material-structurai steel) O7 u0 `1 } G" A
7/conveying speed of a unil load m/s-0.02-0.25% b) v5 [& e, M7 e2 ]* a2 b
8/drive type-geared motor
3 f* W' I* S; X' Y# [5 L/ v9/drive installed power-1.1KW0 A$ e1 }7 e% U' O
10/overall dimensions,mm:
& V8 z5 n. _7 f+ h. u' R9 G length-1000
/ }% F7 G; y. d3 \ width-1250
+ V/ W! @7 M' r U2 C+ w4 A height-470
. J0 f: ~( L, z& o% y6 ` + o3 x6 ~7 v" x% a0 h
technical requirements; g% r0 d/ @( s( y
1/roller conveyor(roll-tabie)shall comprise the following equipment:, p: I' G" j6 Z9 `1 A, M
1.1limit switches
1 N& \: T; t( Z1.2emergency stop switches
, Z, Q5 _ [* u* W/ M2/start-up and protective equipment shall be supplied in a set
% R3 L- N( r$ N3 p3/start-up and protective equipment shall be mounted on a frame(panel)8 X# ]* C+ q9 u' X0 F+ u
frame size shall be provided to mount frame with equipment in the switchboard room cabinet * D7 s) o7 ^& u- X# S
4/local manual contral and remote automatic contral shall be provided in the start-up equipment control circuit. equipment status signais shall be issued in party B APCS! g0 [4 `- I0 I; z$ G8 x8 d
5/provide local contral desk, IP54 equipped with mode switch for "L"(local)and"R"remote operation modes.
- }1 B2 j+ m$ \8 Y+ U) D, u
" F9 Q. v. [) A3 W7 D3 x$ d2 Z' X- {' j8 s1 Z( [; v
累死我了 字好小,打了有半个多小时& \6 S0 D! G" T# y( V. F
好象是皮带机上面的 我估计是清扫器7 X7 T7 Y& ~8 {7 K/ H+ w
还请大家帮忙啊 |
