本帖最后由 鳗鱼鸡汤饭 于 2009-12-6 19:24 编辑 5 X! Z1 `9 [, g. U% z5 H* d- T, j
' W, I. O( [% N: X( h用Tripet 的内孔磨,专门用来磨轴承内环的.效率高,精度高.当然,价格也高....3 E( [9 x3 d9 n# ^/ q4 @ U ~
: Q& H/ x3 p( \# V+ l" P
TST 1204 v( u7 v" J+ u
+ s% y+ o4 O% a3 f' V# u, S
0 D# i! X; t$ n- P
/ h6 c: W# w# B. _ |
& V$ q1 F# e" _4 {7 g4 t, Q o# QInternal Grinding Machine type TST 120, equipped with most modern
' A( ?3 t# T4 |$ S# K( H3 u9 KCNC GE FANUC 18i-T. ISO-Programming with specific grinding cycles, ' J9 \+ U8 D" e( o
graphic programming.7 `6 b2 |" L9 E7 D4 K; w& v$ W
! s- R! a0 w o7 l' t% UDeliverable with:
V C* r. B- w: w# X$ F
& ^. d8 n' i- }* ]) `- 4R turret for the reception of each 2 grinding spindles with max. 80 and 100 mm diameter.
7 g5 Z; r; E$ i4 O - 2R turret for the reception of 2 grinding spindles with max. diameter 120 mm.6 I q* ~, R# z
- 1R turret for the reception of 1 grinding spindle with max. 150 mm diameter.( x, y! ^6 X+ L! ~3 n
, g; Z' f$ V ~; o/ \% e
