机器像是这台一样的:* `9 u5 @: \8 @
http://bbs.cmiw.cn/viewthread.php?tid=118429&extra=page%3D2
: C9 T5 n% Y0 h
+ i3 ?3 g( M" d: O% V: J% _8 tpassing width: 80 - 600 mm
/ u! g0 C9 ?: E) S4 S, T( ypassing height: max. 250 mm; D1 n X# s% N u) z& f, ^9 h
8 f! z4 A& [# _7 N$ [+ a: h1 J
length of product: min. 80 mm, not limited8 e1 p. T' F7 D; r! _
6 T- \1 r4 J5 c5 `9 T4 u! ?( x% G
width of film reel: max. 750 mm, centre folded film, reel diam.350mm
* I1 F$ o; j$ x1 t( `) o+ Q9 C! C0 M3 W6 _# O0 N
film trim strip: max. 100 mm width% P, r2 v& D+ y4 j2 t4 \$ F% X5 Z5 S
) }3 ]: m- e' | j4 W( umains connection/: 400/230 Volt +/- 10%, 3 Ph, N, PE, 50 Hz& ^# S3 I" H f, g2 O
standard version with marking of leads for identification
6 V# p$ z" Y) m, W! c" ^ (transformer for local power suppply to be added.)
' m1 i2 k! d, E4 h3 Hcontrol: type Siemens S7
, K: }7 k: Z/ k" A, C1 X6 i- U# R; }6 n* ~ ^
electro construction: according to VDE regulations
: w/ _9 D" f! ]7 I% @1 _- Wcurrent supply: approx. 3 kVA
8 b& d! _3 S4 x0 e
! J2 u/ f/ g# O4 ?6 Yworking height: adjustable from 800 - 900 mm" V# |- B- c' R, S
operation side: on passing direction right2 B6 P% `& K& w7 z3 R
* W( q% g( {0 e2 X' u% u6 fdimensions of machine: approx. L = 2.980 mm, B = 1.660 mm
1 I* I8 n/ }( ~& u9 R0 N* O% i: h% F+ }1 a- C0 ~( D1 X
panel instruction: english |
