查看: 8780|回复: 14
采购单中这样表达,是国内什么零件?
发表于 2009-7-4 11:08:54 | 显示全部楼层 |阅读模式
ELBOW
" A  x1 o/ B/ I; c+ [TYPE: BUTT WELDING / ELBOW ANGLE: 90 DEGREE
4 }0 j0 ~0 b- ZMATERIAL: STEEL / STANDARD: STPG38  O1 ]- T) W# D: F
ANGLE TYPE: LONG / NOMINAL DIA: 200A / SCH NO:80
ELBOW
& `4 P4 s5 h. g* T& M
APPLICATION: PIPING / TYPE:WELD; g8 [% M4 R- l0 u4 v. h
SIZE: 80A (3 in ) SCH-40 / ELBOW ANGLE: 90 DEGREE - LONG
$ }7 P; k: T) H) K/ |MATERIAL: STEEL / STANDARD: JISB-2305
采购单中其中几个,无图,谁能告诉我这是国内的什么产品?谢谢!
发表于 2009-7-4 20:49:13 | 显示全部楼层
弯头
9 E: V9 a& }2 p* a类型:对焊/弯角:90度7 V* p: U: l$ A6 v8 {' f3 p& o
材质:钢/标准:STPG38' C% `/ _! Z5 P' W5 M6 y. _3 S
弯角类型:长/公称直径:200A/SCH 80; l3 u: V% c$ s/ X
弯头( X  m& P5 h8 n9 ^$ V. s8 y" K
应用:配管/类型:焊接
3 J% W7 y) Y" I2 [' E6 `$ c- _) v* u尺寸:80A(3英寸)SCH40/弯角:90度——长
- n1 r# b" ^2 x$ u材质:钢/标准:JISB-2305. E; }! \; q/ o# w" I. K/ H
你要是实在不明白,就找个管件厂家问问吧。
 楼主| 发表于 2009-7-5 09:29:02 | 显示全部楼层
一共57项,共计5000多件产品。如有社友能生产这方面产品的,请联系!
 楼主| 发表于 2009-7-6 13:39:43 | 显示全部楼层
1        MC165030114        "ELBOW8 Q" Y+ Q" g2 O' S, x4 M
4 g. _4 T: l" f* EMATERIAL: STEEL / STANDARD: STPG38
  ^! w4 Y1 e, Z" ]4 D5 G, zANGLE TYPE: LONG / NOMINAL DIA: 200A / SCH NO:80"        3 y0 j9 x! Y$ B; @3 @
2        MC165030140        "ELBOW
8 h1 X* ?1 O  P7 bAPPLICATION: PIPING / TYPE:WELD) J- m% X6 M7 u# L. B' r
SIZE: 80A (3 in ) SCH-40 / ELBOW ANGLE: 90 DEGREE - LONG4 T+ I/ N* V* U# M
MATERIAL: STEEL / STANDARD: JISB-2305"
7 D, y, m( [/ M8 a( [  R+ {3        MC165030155        "ELBOW, SHOT RADIUS
# k; i1 n2 L, U% H8 |% U0 j3 qAPPLICATION: PIPING / TYPE: 150A BUTT WELDING# p0 Q0 M" ]1 G- w& z* Z' a  u' S
SIZE: 150A (6 in ) SCH-40 / ELBOW ANGLE: 90 Deg
" `$ l# c# n# {$ D) a1 |9 ]MATERIAL: STPG-38 / STANDARD: JIS"
% w; O! Z1 ?3 F" ^( Y" o) \5 b2 U5 k4        MC165050024        "NIPPLE, HEXAGONAL
/ c. m: I  R5 V. a& r- qAPPLICATION: GENERAL USE( o! t0 Y5 E: q& r3 l
TYPE: BOTH END MALE PT THREADED / SIZE: 1/4 in
4 ^; W; \! n: j& e+ y, JMATERIAL: FCMB / GI / STANDARD: JIS B2301 (125 psi)
( H6 N6 {  @! a7 iDescription: ALTERNATE MATERIAL : MALLEABLE CASTING"
, x: T  ?  r+ a. c, {5        MC165050053        "ELBOW NIPPLE* y2 [$ }. |: e
TYPE: KLN / SIZE: KLN8 x 1/4 in PT
' l9 l- q' K4 h& p  F* FMATERIAL: CARBON STEEL"
8 j9 ]' G' u  \6 E- z! p6        MC165110028        "UNION
. Y- d' ]* f* n2 R( LTYPE: KU-15S/KUA15-00) d2 w+ K0 Q; C% p6 g0 v
DWG NO: PSOM-005"        7 S- V3 u( Z2 e
7        MC165140013        "PIPE CONNECTOR% Y& M" F: @' T* R4 [* k
APPLICATION: LUBRICATION SYSTEM
+ `* r, ?/ B& _/ VTYPE: KC-8-PT1/8-S, (NEW KCT08-010E) / SIZE: 8 mm x PT 1/85 d1 Q% i7 _: p" T7 q2 l3 o
MEDIA: OIL / GREASE / TUBE OD: 8 mm"
9 A  _0 _, P( a) g8        MC165130013        "BUSHING, REDUCING (HEX HEAD)  _9 _1 n9 z" i1 H% b
TYPE: 3/8 in MALE x 1/4 in FEMALE PT
) [# H% d; P! O: S8 ]  d' jMATERIAL: FCMB/GI/MALLEABLE IRON CASTING
! I- s- @# K2 |# S- O& g4 V+ YSIZE: 3/8 in x 1/4 in (THREADED) / STANDARD: JIS (125 psi)"
) c. @, `. X7 q$ I# T+ T* u9 ?1 D7 z9        MC165070046        "REDUCER
% z' C9 h& R2 y8 R. Y9 c7 cAPPLICATION: PIPING / TYPE: CONCENTRIC WELD; J9 Y. m  H$ J& a; d7 {
SIZE: 2 in x 1-1/2 in / LENGTH : 76 mm  h$ u1 k3 F1 R, f
THICKNESS: t1 : 3.91 mm, t2 : 3.68 mm / STANDARD: DIN/ANSI (STD)"        : l' h9 _9 |$ i, a7 M
10        MC165050039        "NIPPLE, HEXAGONAL; y0 y9 f! N1 F, W
" T* C2 q; T! d. H( t3 o: n2 zSIZE: 1/8 in BOTH SIDE MALE THREAD9 P! {* u5 l6 a
MATERIAL: SUS / STANDARD: JIS (125 PSI)"
: ^. p$ p: \/ B: K! }# \11        MC165030175        "ELBOW ,SHORT RADIUS
  b& l7 H  M. O3 {; n* f5 N6 iTYPE: BUTT WELD WPB (SCH-160)
0 ^1 E) m  F7 HSIZE: 65A (2-1/2 in) / ELBOW ANGLE: 45 Deg.; e5 |* Z9 m6 F. ~1 D
MATERIAL: STPG-38/STPG-370/ ASTM A234"
- a8 o$ F. I1 _. N1 a: L( L7 K12        MC165030176        "ELBOW, SHORT RADIUS
6 _) q& M4 i: G1 ?; S9 JTYPE: BUTT WELD WPB (SCH-160)
# X7 X/ G9 B5 H) vSIZE: 65A (2-1/2 in) / ELBOW ANGLE: 90 Deg
: y4 Z& |( M) {3 n1 {! S9 B2 D+ Y/ {MATERIAL: STPG-38/STPG-370/ ASTM A234"
6 r/ u# k- G% R$ _" A13        MC165140039        "MALE STUD CONNECTOR6 H8 w8 y& W7 x: f9 U; D  y
APPLICATION: FOR GREASE LINE
3 U! ]: s2 ~4 s6 r4 ETYPE: NPT(SAE J476)/EO 24 DEG CONE& }( r8 G8 s! `0 X
SIZE: TUBE SIZE 8 MM X 1/4 NPT
+ u3 ~! ]" _7 }* dMATERIAL: STEEL,ZINC PLATED,Cr(VI)-FREE
. J: w) X; v4 f9 o4 A# n, w4 xWORKING PRESSURE: 315 BAR / PART NO: GE08L1/4 NPT CF"        ; p$ A/ i+ x! G) ~# Q
14        MC165140040        "MALE STUD CONNECTOR
6 P' q2 K9 u; e  kAPPLICATION: FOR GREASE LINE / MAKE: PARKER+ b5 @( ?5 C# m' i( C) z, k; N9 w
TYPE: NPT(SAE J476)/EO 24 DEG CONE( |9 @. _7 m# Z7 Y0 i& j8 o5 H
SIZE: TUBE SIZE 10 MM X 1/4 NPT% C* t" _# G  l) d4 Z
MATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE
* J- y- X6 C- X) C: E  WWORKING PRESSURE: 315 BAR / PART NO: GE10L1/4 NPT CF"
( r3 L; m0 U  u! D# e. S15        MC165140041        "MALE STUD CONNECTOR3 j5 C- N. |; Y$ [6 p) C  W5 c8 W  i
APPLICATION: FOR GREASE LINE / MAKE: PARKER$ A# C; h$ P2 b4 w  t) ?5 ?" b
9 G$ }. j  i& ~* E6 o. o1 O8 JSIZE: TUBE SIZE 10 MM X 1/8 NPT
" y" Z8 W, n9 q  I. SMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE
1 ?0 c! X, V" M  O" jWORKING PRESSURE: 315 BAR / PART NO: GE10L1/8 NPT CF"        . s! K  |- A% ?3 R
16        MC165140042        "MALE STUD CONNECTOR" W1 ?/ i- `4 r' _7 u5 O
APPLICATION: FOR GREASE LINE / MAKE: PARKER+ ?3 t; h& Z, j, N7 y) K& h) V
TYPE: NPT(SAE J476)/EO 24 DEG CONE) W9 P8 t7 \) K. T9 L
SIZE: TUBE SIZE 12 MM X 1/4 NPT! c# a& s; p; e0 _0 _- a
MATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE+ Z! _7 K4 [& Y/ r' M( H
WORKING PRESSURE: 630 BAR / PART NO: GE12S1/4 NPT CF"        0 u# v$ Z# b1 Q# d% S0 y. Y4 Y
17        MC165140043        "MALE STUD CONNECTOR) |1 S5 J( c* c9 h! R0 u' z4 C( `
$ p5 x7 a( S- d4 E) s5 R2 G( rTYPE: NPT(SAE J476)/EO 24 DEG CONE' f' t; A/ ?9 T
SIZE: TUBE SIZE 12 MM X 3/8 NPT
; l0 f8 `& E- X# ~1 wMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE
9 ^" v' i" @! {9 H* }( k+ q7 cWORKING PRESSURE: 315 BAR / PART NO: GE12L3/8 NPT CF"
" Y) M; l  T0 ~% {) c& b% }. R18        MC165110036        "UNION (ERMETO)
# H, K( Y/ t% QAPPLICATION: GREASE / PART NO: G12L CF
4 X# J( |, s' q3 d! h  UTYPE: EO 24 DEGREE CONE END G UNION 6 d& v; }; ^3 e# o
NOMINAL SIZE: TUBE SIZE 12 MM / STANDARD: 315 BAR- m% g7 u& V; f7 U/ ~
MATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"
0 a; L* \$ h% X" R19        MC165110037        "UNION (ERMETO)( L% b( D3 V3 X( D' H( w
APPLICATION: GREASE / PART NO: G16S CF6 ]5 c$ a( i/ Y: t6 N
3 {+ j2 u; k4 N# t9 h; ?2 zNOMINAL SIZE: TUBE SIZE 16 MM / STANDARD: 400 BAR
; [" b9 D. V6 S+ q8 m' e% lMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"        : f0 u& f/ K1 q6 b/ N
20        MC165110038        "UNION (ERMETO)
) g9 U+ L3 ]0 N8 Y* l5 ~APPLICATION: GREASE / PART NO: G20S CF+ d( Q/ I8 F3 m- j4 ]( m
TYPE: EO 24 DEGREE CONE END G UNION& `0 @* y8 n: w; g, q) c
NOMINAL SIZE: TUBE SIZE 20 MM / STANDARD: 400 BAR
" C5 e0 |3 d7 s/ YMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"        ; c4 ~( n5 G- G3 `0 q4 I
21        MC165110034        "UNION (ERMETO)
' M, p  i; V/ F4 |+ GAPPLICATION: GREASE / PART NO: G08L CF
+ J) n) v. q1 O. W/ _) {8 e/ p2 _TYPE: EO 24 DEGREE CONE END1 b9 C  ?0 |2 t' F7 V
NOMINAL SIZE: TUBE SIZE 8 MM / STANDARD: 315 BAR9 h6 U7 I: V/ l5 @- n( W. D3 R" [
MATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"        8 T* B3 a* ]; A$ p+ t
22        MC165110035        "UNION (ERMETO)
# n% a  S' y: d9 }APPLICATION: GREASE / PART NO: G10L CF
+ H. \- z# C& M7 [$ V$ QTYPE: EO 24 DEGREE CONE END
9 Q: H& ^) L+ ], B7 p3 J# [8 ~7 E2 M$ YNOMINAL SIZE: TUBE SIZE 10 MM / STANDARD: 315 BAR
# }( h' R3 k- A- R5 N2 d# YMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"
* B; B2 v& k9 y& B- v23        MC165030188        "ELBOW, UNION (ERMETO)3 i3 H0 @) u* K3 B; s% B/ N9 Y+ g
APPLICATION: GREASE / PART NO: W08L CF5 _. ?6 j/ W9 ^, h1 Q3 I, I9 Y3 i
TYPE: EO 24 DEGREE CONE END G UNION2 Y% J- ^9 y, ^7 L
7 T' Z* J& @$ i9 ?* fMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"
9 j; n  l' c8 o( g# C% e; ~' ]24        MC165030189        "ELBOW, UNION (ERMETO)
: p0 ]9 ]4 p) P) z! N+ tAPPLICATION: GREASE / PART NO: W16S CF& H% M1 G, A: R# A" G4 X
3 Y7 W" N. M9 c' F3 dSIZE: TUBE SIZE 16 MM / STANDARD: 400 BAR
2 N% L$ J& x7 b1 g/ ]# C+ B2 j; YMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"
6 ~0 e3 t6 y' w25        MC165030190        "ELBOW, UNION (ERMETO); C; f. b- T1 t2 k6 s8 M
APPLICATION: GREASE / PART NO: W20S CF
4 b, ^. C9 `  U. d9 |+ y4 a7 V$ eTYPE: EO 24 DEGREE CONE END G UNION4 @. L, b. f* ^" @
- e9 }) A; n/ j7 I& ^" IMATERIAL: STEEL, ZINC PLATED, Cr(VI)-FREE / MAKE: PARKER"        % P7 y& F5 o: @0 z9 U: c
26        MC165100100        "UNION TEE (ERMETO); O" X( v$ ^& ~$ e
APPLICATION: GREASE / TYPE: EO 24 DEGREE CONE9 c  X* K$ M; ~4 f$ r( }- N9 s
SIZE: TUBE SIZE 8 MM / STANDARD: 315 BAR# b" X0 E: {) T/ N3 `9 _
4 k' Z: ^# G8 c& f$ @6 n27        MC165100101        "UNION TEE (ERMETO)0 m/ c8 U4 U% N( G/ N
$ A1 w+ L8 f9 PSIZE: TUBE SIZE 10 MM / STANDARD: 315 BAR6 b2 Y4 f# }: O1 U3 }  L
' z: ~6 G$ r8 z28        MC165100102        "UNION TEE (ERMETO)
! x! B! M' d' r, T$ S8 @( QAPPLICATION: GREASE / TYPE: EO 24 DEGREE CONE, B$ o  P+ t, k* o, {
SIZE: TUBE SIZE 12 MM / STANDARD: 315 BAR2 i  ~( F/ C* n' w- \
: }8 n" ]# F0 x7 i/ y29        MC165100103        "UNION TEE (ERMETO)
. K' o# E( T$ e+ i( X- B5 S# TAPPLICATION: GREASE / TYPE: EO 24 DEGREE CONE
/ T+ d! u0 {# o2 ~. z, f' MSIZE: TUBE SIZE 16 MM / STANDARD: 400 BAR / PART NO: T16S CF% Q( k! D" s8 c" H! a! n& S( W1 M
MATERIAL: STEEL, ZINC PLATED,Cr(VI)-FREE / MAKE: PARKER"        9 E/ Q. _" ?: d& D$ [
30        MC165100104        "UNION TEE (ERMETO): e, s) I* p" z! D" j8 u. y
APPLICATION: GREASE / TYPE: EO 24 DEGREE CONE; N2 i4 e. [" c- R6 ~" _+ {
SIZE: TUBE SIZE 20 MM / STANDARD: 400 BAR / PART NO: T20S CF& l% a$ X% {. T* N0 G2 Y
MATERIAL: STEEL,ZINC PLATED,Cr(VI)-FREE / MAKE: PARKER"
发表于 2010-10-5 07:59:08 | 显示全部楼层
能不能翻译成汉语啊     大侠     我们做机加工有十几年的历史了,都是给国内做的没做过外贸订单。简单介绍下我们的机加工设备吧 。车床   铣床    无心磨床  冲床  焊接设备。加工强项 冲压件  焊合件  销轴  异型螺丝.   联系QQ778197103
发表于 2010-10-7 08:16:31 | 显示全部楼层
弯头,国外对这种产品的要求是很高的,用在不同的地方,所用的标准也不一样,有卫生级的,化工级的,食品级的,医药级的,有常压,中压,高压,超高压等等,还有什么船舶级的
发表于 2010-10-13 12:19:51 | 显示全部楼层
回复 4# 一角二水 & K! M4 ~# @& j
' R0 z; x, P, M9 E( h
; F( g+ N/ K" N    可能是用于润滑管道的一些管件,其中一些已经指明是“PARKER”的产品,找他们在国内的代理吧。
发表于 2010-10-14 08:58:38 | 显示全部楼层
弯头,想起以前公司里,经常有焊接管路用到弯头,外面买回来的弯头(图纸清清楚楚标的有哪个标准的),焊接师傅焊接的时候是在一堆弯头里面挑出来用,先在夹具上试装,能用就点上?否则就扔了。。。非常无语
发表于 2010-11-19 13:08:30 | 显示全部楼层
长见识,弯头得 种类如此多啊,有高手进来顶顶啊,我是不懂
发表于 2010-12-27 10:31:55 | 显示全部楼层
GMT+8, 2025-4-24 10:28 , Processed in 0.064700 second(s), 14 queries , Gzip On.
