查看: 12505|回复: 32
机械外文文献
发表于 2009-6-13 12:38:14 | 显示全部楼层 |阅读模式
精品机械外文文献
发表于 2009-6-20 19:20:59 | 显示全部楼层
kankan
发表于 2009-6-21 11:53:31 | 显示全部楼层
那位高人能给翻译下
发表于 2009-6-21 19:28:48 | 显示全部楼层
有限元方面的?
发表于 2009-6-21 21:43:24 | 显示全部楼层
let me check it.
发表于 2009-7-9 13:31:50 | 显示全部楼层
那位高手帮忙翻译一下 ,整个中英文对照
发表于 2009-7-12 21:37:31 | 显示全部楼层
机械失效的分析
发表于 2009-10-7 22:29:29 | 显示全部楼层
too long to read it
发表于 2009-10-15 23:16:25 | 显示全部楼层
1A train can completely transform your wedding dresses look,   no matter what shape your wedding dresses dress is. It allows you to change the feel of your outfit from  ceremony to wedding dresses reception. The train is simply the elongated back portion of the  gown that lies on the floor and trails behind the bride,wedding dresses the added weight demanding a tall and majestic stance. Trains date from the Middle Ages,  when the length worn wedding dresses  at court wedding dresses indicated a person's social rank. The cheap wedding dress premise being the wealthier you were, the more fabric you could afford.wedding dresses  Today, wedding gowns with long chapel and wedding dresses cathedral trains  are considered the most formal, lending wedding dresses themselves to bustling following the ceremony.wedding dresses Watteau trains (which spill from the shoulder)   and court trains (which start from wedding dress the waist) are less formal. The sweep gently wedding dresses puddles about a foot wedding gowns behind the wearer, and the detachable   train - which can be any length and either wedding dresses a flat panel or gathers of fabric - is generally attached cheap bridal gowns, to the gown at the waist wedding dress with buttons or hooks,  then later removed wedding dresses to be a bit less wedding dress informal and not as imposing.plus size wedding dresses Also known as royal, this version wedding dress extends twelve feet flower girl dress or more from the waist.  Managing such a huge amount of fabric often requires pages (young boys), who hold up wedding dress the train as you walk down wedding dress the aisle - very regal.
发表于 2009-10-15 23:25:00 | 显示全部楼层
wedding dress chooseIf you are planning all of the details wedding dresses,glove,wedding dress,of your wedding down to the design on the napkins at the reception you really have your work cut out for you.wedding dresses, This can be a wedding dresses, very overwhelming task. Yet the rewards are also great. Having a wedding day exactly like you gloves, had always dreamed of is gloves, a huge reward. However knowing that  cheap wedding dresses,you planned all Wedding Gowns, of the details yourself makes glove, it that much sweeter. One of the things you will Prom Dresses, want to consider is Prom Dresses, wedding jewelry for bridesmaids.wedding dresses, This is not a have to and many times you can skip this.gloves, However, if you are wedding dresses, serious about choosing all of 2009 Wedding Gowns, the details and having everything come out just Prom Dresses, perfect then you glove, will want to wedding dresses, choose the jewelry cheap wedding dresses, for your bridesmaids. One of the biggest wedding dress, side benefits of choosing your cheap wedding dresses, wedding jewelry for the gloves, bridesmaids is it can also serve the second function of being a bridesmaid gift after wedding dress, the wedding.wedding dress, This article glove, will help guide your through making some gloves, of the important wedding dresses, decisions when choosing wedding dresses, wedding jewelry Wedding Gowns, for bridesmaids.
GMT+8, 2025-4-26 09:52 , Processed in 0.065429 second(s), 17 queries , Gzip On.
