楼主 |
发表于 2009-5-28 16:24:52
显示全部楼层
: v% @5 P3 D. {( {+ a) @, m8 j& ~. K) k2 k" B) N/ F+ z2 A
从他们公司的网站摘录的其中最先进的一款5轴立式高速加工中心的技术数据。大家觉得他们的技术水平怎样?我认识的品牌不多。 O t B6 \' H! j, v
Basic technical data
& w6 s9 T0 x" c# o
' t( V! g( Z2 A' i- ]% u' ATable: Y& |" w$ Z& v$ `+ j
4 i2 G6 h" I% J( }+ {& E
- working surface! y0 q( v' Y, ]+ M: C/ k. B
Ø400 mm" b- _& X6 H/ V" m" E% M9 }
( m% I( \ s2 T# h y) D
- max. table load
9 d1 J+ n9 R- h$ t5 t+ s: ~600 kg
9 e" \6 ?9 [' A5 X& B9 c& \+ w, ?$ ]& e: {* w
Travels, v9 Q; `' K4 c# v% }7 s
" j5 H; P7 r* g( q- S+ |6 D
X - longitudinal7 Y( ^! q9 z1 ^. D* }: Z
500 mm
" Q; M% n5 C, ^+ @3 U5 V% m/ g# g+ [* J3 p$ c" \, v
Y - cross
3 {/ q7 x, Q. _' e* T- w600 mm2 z' g1 A: S. ]% p
% v3 z, m& K7 P9 E' _Z - vertical/ G! I& W/ c: n3 p$ w. z+ v
460 mm
. _* C0 g* R8 j- u! J# F* W/ ~" I* r, A6 S3 M4 @3 E
A - tilt5 s9 |+ z) M, F! z- v% K
+95° / -95°
2 e$ b7 @+ A6 q# _' S
. }+ R$ B& r( v) s; b; jC - rotation* e* j& R" s" f- z* d
n*360°+ I8 X) b# ~- x+ a$ E! ?8 B: R, j
* u$ j. a2 h% I0 ~# PRapid traverses
5 d+ ^4 g" Q; A6 ?1 i, Y( r l- m- u2 L- _- M3 o7 w* g5 i5 e l
- axis: X, Y, Z8 Q# H% w' K/ r& O
40 m/min$ D" [( d5 W" K% ]8 Y% P( Z
0 j, Y" }( Y- \9 e# C
- axis A, C
' L5 e! q2 g7 F( f100 rpm$ T; H% O, T, x5 c" z0 E+ ]1 w
R v l- h/ {7 B
Avaliable Spindles:
& L1 D# r1 g, l2 {) \& c9 f! K* G8 }0 H7 g5 s# i3 W
CYTEC electrospindle- s- n3 m- d4 O* Q& |/ q4 n* Y
, i6 @9 x8 V: l3 y2 q9 q
Max. Spindle Speed: 12 000 rpm
. @$ U4 o; G; Z+ s2 r& n+ y1 a! A- r; e- y7 V
Max. Power S1 / S6 (25%): 10 kW / 17 kW
; ]: J. \& m2 Z' }" j$ b) A% r
* A, M& R3 x7 D: }1 YMax. torque S1 / S6 (40%): 64 Nm /109 Nm0 \$ Q* G" t# ?# q. h% {. }
, Z- { N. d& q* B2 J5 q: PSpindle taper: ISO 40
5 i; f+ x. K: W* t% ]
- m( m% S, K4 h- D' MHolders acc. to 69871A
0 [1 {1 S" \) Z5 w3 Q! u& Z1 Y* m3 r9 f4 H
Pull studs for tool camping in spindle acc. to ISO 7388/2 type B
$ P! P9 @$ b* M7 Q& q
8 \' z, R5 ?7 v* K" D( tCYTEC electrospindle
) o# f0 e O! _# z& D8 S5 C+ r' \6 `
Max. Spindle Speed: 15 000 rpm
- Y ?; ^! n8 l6 p9 e0 |7 W) y0 U _
Max. power S1 / S6 (25%): 11 kW / 20 kW
$ F S& Q+ W3 R, f- A+ P
& z" m6 q& ^+ \0 _2 ?1 ~Max. torque S1 / S6 (25%): 70 Nm /127 Nm
! N, w3 z5 z4 @. b! Z: ^6 f2 ?& `
/ J" Q. Y+ f3 v) |
# [/ P2 x0 N N& p9 nHolders acc. to 69871A
7 l% n/ }8 J! V; I" ]8 d0 ?8 x- l0 X" z+ l( S
Pull studs for tool camping in spindle acc. to ISO 7388/2 type B7 {6 V9 [6 w' u" p/ u- [) P
) H b$ V3 x6 B2 x1 YKESSLER electrospindle" N g$ j7 `. U7 x8 R7 S* I% v/ b
: t* v2 v' x1 y3 i, `" FMax. Spindle Speed: 24 000 obr/min
1 A' b u( V8 T- @7 k
7 p2 `8 `0 c* y4 H6 h& v2 z: M) OMax. power S1 / S6 (40%): 20 kW / 25 kW; k1 [5 g5 C( W- U6 k! R
: q+ x0 Q8 n3 \/ k, WMax. torque S1 / S6 (40%): 32 Nm / 40 Nm % p) \) ?6 E/ G* P* B3 {
, r% }8 K" U/ \" s% e& _. p2 z
Spindle taper: HSK 63A8 Z7 V# T1 p! u4 l: k( ~0 d& Y
0 b% F; I: E5 ~' S0 ?
Holders acc. to DIN 69893-A! P+ X. W' ]; R I6 d9 C# M" V
: c& w! y' i6 V6 m7 sAutomatic tool changers& k) f0 ?8 w) H4 _1 U% \7 r
" Z; z$ @4 S; E- n/ g; N; [9 ?! P' X
Electrical, cam type, swing arm ATC& i/ {+ l) M d& _! r, M6 E
1 Z* L; t6 F# w7 L/ I* p9 \; b3 mCapacity
% v/ `1 I) u* [7 T; V4 [4 }+ x24
* w" J/ R9 D8 c( T( r: h4 u. D5 v7 N$ r, e7 ]2 U
Tool change time
- G2 H; S- p6 I; C% ~2,5 sec.
! A" ]& A# E* l7 Y
$ N( q' S; q6 b1 J" E4 i# N6 @Accuracy& f& I1 \3 w+ K- ]
0 o* ]" Y7 X+ N; I4 n6 [( g8 y3 t" o
- Positioning accuracy of linear axes
P0 l {* T/ r' L0 S+/-0,005 mm' ]6 c' C- T# K
( I5 `6 x0 Y( |
- Repeatability2 t9 J& T$ Y1 J4 V( i) R
0,005 mm
( d+ v5 m) K, G% D7 k+ S/ u
) {$ ], b# D) K) Y e8 S- Positioning accuracy of rotary axes4 _% B7 ~6 C# e# n* b! H" D' _$ J
+/- 2,5"% P9 q/ v/ z+ }" ]
2 Q) o2 O b7 f/ G
General
' S3 W$ F% G( ]1 u$ F' @8 R: O, G2 ~0 g1 P
Overall dimensions:
$ q' ?" e2 M! S$ W4 w, X
6 `2 \( p( ^" z6 |9 q, k E8 PWidth (along X axis)- \6 g& g3 g# ^% y7 S% u4 D
2360 mm
9 f3 Z) Z, H' Q/ h1 R+ `, T
& |3 p$ P `4 _ l! ]' B" {2 vLength (along Y axis)0 c2 x l' M4 l. g: A7 }+ n7 |% n
2500 mm# K5 ]2 S- R$ X) w
9 }7 Y& @! t; R; K6 p% I
Height/ y' P* D2 _0 d! ~+ M5 p
2850 mm
+ ~0 a ~& u* s
8 r$ |. b9 \, r' W g2 `0 R8 }Machine weight
' V- a7 L+ B" h5 ]+ r$ R- e- y4 U5000 kg
& g) c5 W7 e1 ~$ Z1 ~8 h8 {
: t! d2 ~5 L8 _" u% QCNC System:
0 F8 O2 Z8 D5 q9 @ k8 u# G8 A/ V6 S Heidenhain iTNC 530 with smart.NC (software option 1 and 2 included) |
