楼主: cwenm
钻头加工,怎么处理这种铁屑?
发表于 2009-5-17 23:21:44 | 显示全部楼层
卧加还是立加啊?# r& b/ D5 l) P4 j+ |5 u1 ~, @
7# cwenm
发表于 2009-5-17 23:51:05 | 显示全部楼层
不断屑阿,冷却压力提到30bar可以?越高约好: I1 A5 d0 Q! }' l, d" {( p
提高进给到0.4,降低线速度保证F不变,加工到120深停顿0.3S,这应该对节拍影响不打。
8 f3 {6 a5 q0 G9 z. f6 u8 i若还不行,观察钻头槽型是否利于断屑$ K; ~" P; U* F( ^
GUHRING对于深孔钻很有研究和实际成功经验。
发表于 2009-5-18 00:17:35 | 显示全部楼层
Sandvik有10倍径以上的钻头吗?麻烦告诉一下型号。
/ ]2 u6 c" d% H, O4 s3 o 16# xiaojunfang4
发表于 2009-5-18 09:19:25 | 显示全部楼层
要尊重科学,不要为了节拍而盲目提高切削参数。
6 A- `, z4 [/ Z4 [* f0 l老学员 发表于 2009-5-17 21:50
* }0 o! |" W" p' v
8 K8 `! p- X$ g* O4 K5 X6 n说的对
发表于 2009-12-20 12:50:49 | 显示全部楼层
VC 设置到80   内冷加个 保证你搞定
发表于 2009-12-20 14:22:14 | 显示全部楼层
看看是不是钻头刃口倒棱太大了,
发表于 2009-12-21 11:42:42 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2009-12-21 23:23:22 | 显示全部楼层
建议选用可换刀片的钻头,刀片磨成群钻形式。
发表于 2009-12-24 00:02:04 | 显示全部楼层
Since we do not know the detail of your drill we assume it is good for cutting A3 steel. We also had this problem before. Below is our solution: 1. drill a precise pilot hole, 2. increase your coolant pressure ( you can use high presssure coolant system), 3. selet a good drill for deep hole ( currently many tool makers have launched a similar type of drill like Mapal Mega Deep Drill (http://www.mapal.com/en/products ... ls/mega-deep-drill/), Walter Titex XD Bohrer drill and even OSG and Mitsubishi also developed this type of drill
发表于 2010-1-15 22:04:18 | 显示全部楼层
提高进给
GMT+8, 2024-11-26 07:23 , Processed in 0.052733 second(s), 15 queries , Gzip On.
