查看: 2828|回复: 5
机械设计名词术语中英文对照表
发表于 2009-4-9 16:56:46 | 显示全部楼层 |阅读模式
扳手 7 A$ G+ L$ {3 T  G) r0 a( L5 s# `
wrench
板簧 ! ^& K. l5 u, N; h! s  ~7 F0 u" d# f
flat leaf spring
半圆键 9 q+ w5 \0 x" F6 F4 B
woodruff key
变形 $ s" j2 ~! G7 }$ T/ C
deformation
摆杆 . h3 q1 [- v' r2 d
oscillating bar
摆动从动件
$ B8 E7 j4 a8 N6 \, U$ ?; y) V
oscillating follower
摆动从动件凸轮机构 7 A7 t/ W4 N$ r  T
cam with oscillating follower
摆动导杆机构 ) C! E  [# L: ^$ s) }  L: B" h
oscillating guide-bar mechanism
摆线齿轮
7 M- ?& z9 c& A3 V! Q: V
cycloidal gear
摆线齿形 . h5 `4 U6 y) T* i4 U7 U4 Q; b
cycloidal tooth profile
摆线运动规律
1 Z) t4 h2 ]% f3 v+ W! s& ~  d, b+ c0 r
cycloidal motion
摆线针轮
' K! U- ]3 P+ T$ t
cycloidal-pin wheel
包角
% o  j4 r0 b+ j) X
angle of contact
保持架
7 c% T6 B9 [/ |) |/ B- F
cage
背对背安装
+ ?; ^; ]1 d) n) G
back-to-back arrangement
背锥 3 [2 L- Z0 l9 M. B) b  l" z
back cone ; normal cone
背锥角
4 s! i  a1 @& Z" z- x. y# ~7 T
back angle
背锥距
' J# ^, q6 ~/ ?$ u6 I
back cone distance
比例尺
4 I7 w7 Y5 G, Y+ `
scale
比热容
8 c( L" \! ?" H: \! f' N
specific heat capacity
闭式链
3 a  a" Q0 |% h0 n
closed kinematic chain
闭链机构
0 z- Q; H" J+ o/ r8 Q* O
closed chain mechanism
臂部 " `) [( E$ k4 N+ `0 g. ]  ]
arm
变频器
( q0 @& v. a4 H
frequency converters
变频调速 " f! x7 z2 k# H: W' ?% q! t2 e
frequency control of motor speed
变速 5 p% V9 Z( s# d+ M3 J
speed change
变速齿轮   M1 @: s: m2 r& b( Z2 F+ S
change gear ; change wheel
变位齿轮 / G* }) E  N3 \5 \. f
modified gear
变位系数 + W, M  D0 W2 E5 b; W1 O$ y
modification coefficient
标准齿轮
' I0 u+ Z, t2 \% X$ o
standard gear
标准直齿轮 ) d( a6 M, r: a; c5 {; m- |
standard spur gear
表面质量系数 : p1 G" ^! e8 ?" R0 [) a
superficial mass factor
表面传热系数
2 i( h( T9 d. }- G
surface coefficient of heat transfer
表面粗糙度 " S4 U+ u  b/ T
surface roughness
并联式组合
- ?" ~+ k% `1 p5 T# ]6 w2 r
combination in parallel
并联机构
4 W- K( V$ @& K" T$ D9 t
parallel mechanism
并联组合机构 / m8 V. ]" y. F4 k2 K# D7 v2 w
parallel combined mechanism
并行工程
, z9 Q, j% }! Y0 g; F" ]4 v
concurrent engineering
并行设计
  ^; [6 u1 d. g; ^
concurred design, CD
不平衡相位 ! q0 `9 g. z5 ~! D. s' @: Z/ Z
phase angle of unbalance
不平衡
# H3 ]* v( D; L0 I2 ~
imbalance (or unbalance)
不平衡量   z& C3 g# Q1 m
amount of unbalance
不完全齿轮机构
1 y, U( c6 s( s& Z" y) h. a" a' P
intermittent gearing
波发生器 % w  V% H3 m  I) E$ N  S3 r
wave generator
波数 & E. R% U0 Y- t5 ?
number of waves
+ J1 |4 P: |* P& r! v
3 x9 `; O* U' N, g3 L) R" a  P1 P
/ o: f8 T, ?  N' d4 G' D2 E. q0 {! E
发表于 2009-4-9 20:05:05 | 显示全部楼层
不错不错啊
 楼主| 发表于 2009-4-10 08:50:29 | 显示全部楼层
7 q% A2 [0 i( a$ x* n2 X; ^; J) v' _- g; K# C4 u
呵呵,好东东要和磨粉机网大家多多分享
发表于 2010-7-8 19:40:47 | 显示全部楼层
好。。。。。。。。。。。。。。。。。。。。。。。。。。。。。
发表于 2010-10-1 13:27:56 | 显示全部楼层
挺好的,谢谢楼主分享了~~
发表于 2010-10-22 10:23:59 | 显示全部楼层
THANKS A LOT!4 Z/ Q  L5 S, Q  P9 ?' g" n3 x; q
太棒了
GMT+8, 2025-4-25 23:54 , Processed in 0.055414 second(s), 14 queries , Gzip On.
