发表于 2009-3-26 19:14:54
显示全部楼层
1 blots the pipeline to be too thin.# C6 C7 k, Q! [$ j
2 hydraulic fluid too dirty, blots the mouth not to install the filter. the " c/ `: S1 G' ^. V- y3 a
3 electrical machinery and pump's proper alignment is not good, the junction box shaping installs improper., M$ N6 P3 K/ l! x+ _$ |/ x
4 gear pump pump housing low pressure side attrition. the 5 circle matches the oil disk attrition. the common gear pump has not repaired the value, trades one newly to pull. Asks a skilled worker to enter the stage spends also wants 150. , showed off meager skills before an expert. |
