Severity 严重度(S) | Detectability 可探测度(D) | Occurrence frequency 发生频度(O) |
高
10 | Hazardous without warning 危险没有预警
May endanger operator (machine or assembly) without warning.可能对机器操作员或组装员工造成危险没有预警
May cause customer serious or fatal injury without warning可能引起顾客严重或者致命的伤害没有预警 | 无
10 | Almost Impossible几乎部可能
The product is not inspected or the defect caused by failure is not detectable 产品没有检查或者缺陷引起的故障是无法察觉的(例如 无法探测,无检测方法) | 高
10 | 失效率大于和等于50% |
9 | Hazardous with warning危险有预警
May endanger operator (machine or assembly) with warning可能对机器操作员或组装员工造成危险有预警
May cause customer serious or fatal injury with warning. Product not complying with legal requirement可能引起顾客严重或者致命的伤害有预警,产品不符法规要求 | 9 | Very Remote非常轻微
Random manual visual final inspection done before shipment 出货前最终检验随机的目视检查(例如 FQC/成品QC抽检) | 9 | 失效率大于和等于40%小于50% |
8 | Extreme极度严重
100% of batch may need to be scrapped, production stop, delivery stop.整批次货物可能需要报废处理,停止生产,停止交付
Product does not at all function, is not possible to assemble or for reason not possible to use 产品无功能,无法组装或者其他原因不能使用 | 8 | Remote轻微
100% final inspection 100%最终检验(例如 拉上100%包装外观检查) | 8 | 失效率大于和等于30%小于40% |
7 | Major 严重的
Part of batch needs to be scrapped. Deviation in primary process include decreased line speed or added manpower.批次货物中部分需要报废处理。在生产过程中的缺陷包括降低拉线速度或者增加人力。
Product has major customer dissatisfactions by being almost impossible to assemble, it has major apperance defects or function is not fully working产品有使顾客不满意的重要缺陷,如几乎不能安装,有严重的外观缺陷或者功能不能完全工作 | 7 | Very Low 极低
Random manual visual inspection after/before process加工前后最终检验随机的目视检查(例如 IPQC\QC巡检) | 7 | 失效率大于和等于20%且小于30% |
6 | Significant明显的
100% of batch need to be reworked off line and accepted.整批次货物需要返工才可接受
Product is usable but it is significantly below the customer expectations of being well designed and functional产品可用但明显低于顾客的精心设计和功能期望 | 6 | Low 低
Product is 100% manually visually inspected after the process加工后100%的目视检查(例如 拉上100%自检) | 6 | 失效率大于和等于10%且小于20% |
5 | Moderate中等的
Part of batch need to be reworked off line and accepted.批次货物中部分需要返工才可接受
Failure creates enough customer dissatisfaction that it result in a customer complaint 故障足够造成客户不满导致客户投诉 | 5 | Moderate 中等的
Product is 100% manually inspected after the process using Go / No go gauges or other mistake proofing gages. Some Statistical Process Control (SPC) is used in process and product is final inspected off-line.产品加工后使用GO/ NO GO 计量或者其他 错误校正措施 进行100%手工检查 过程中使用统计过程控制(SPC),产品离线后有检验(例如 制具、量具、通止规检验) | 5 | 失效率大于和等于5%且小于10% |
4 | Low 低的
100% of the production run need to be reworked in-station before it is processed.生产运行中所有都需要在加工之前返工处理的
Product has a clear apperance defect 产品有明显的外观缺陷(例如 A面即主要面,外观面) | 4 | Moderatley High 中高
Downstream process step has a 100% automatic detection system and will not accept the defected part before starting processing. SPC is used and there is immediate reaction to out-of-control conditions.下游工序有100%的自动检测系统,加工处理前将不接受缺陷部分。过程中使用统计过程控制(SPC),对失控的情况有应急反应。 | 4 | 失效率大于和等于2.5%且小于5% |
3 | Minor 很少
A part of the production run need to be reworked in-station before it is processed.生产运行中部分需要在加工之前返工处理的
Failure direct apperant to customer but will not be in disturbance in the daily use顾客可察觉的故障,但日常使用中无影响(例如 B面即是安装面,在安装零件时所看到的零件面) | 3 | High 高
Automatic process control which automaticly reject the defected part, it is sorted out and can not be sent further to next process. An effective SPC program is in place自动程序控制不接受有缺陷的部分,挑选出来后不能被发送到下一个工序。有有效的SPC系统 | 3 | 失效率大于和等于1%且小于2.5% |
2 | Very Minor极少
Sligt inconvinience for process, operation or operator.对过程,操作或操作员造成不便的
Failure not direct apperant to customer and could have minor effect on the total apperance of the product顾客不可察觉的故障对产品的整体外观有一点小影响的(例如 C面即看不到的面) | 2 | Very high 非常高
Automatic control detection in process that will detect error and prevent defected part from being made.过程中自动控制将检测出错误并防止在生产中产生错误 | 2 | 失效率大于和等于5‰且小于1% |
低1 | None 没有
No effect on process, performance, equipment or people. 对过程,性能,设备或者人没有影响的
Failure not noticable to customer 对顾客没有可识别的故障(例如 C面即看不到的面,内部零件) | 全部1 | Certain肯定
Defect part cannot be made because item has been error proofed by process/product design缺陷部分不能被做出,因为项目被过程或者产品设计证明是错误的(例如 防呆结构) | 低1 | 失效率大于和等于0.1‰且小于5‰ |
4.Assement Table 评估表格 | | | | | | | | | | | | | | | | | | | | | | | |
Pos | Parts Pictures | Subsystem | Potential Failure mode | Effect | S | Potential Failure Cause | O | Existing control | D | RISK | Corrective actions | Resp/date | Results of Corrective actions |
| 图片 | 子系统 | 潜在失效模式 | CEPQ潜在
失效后果 | 严重度 | 潜在失效原因/机理 | 发生频度 | 现行设计控制预防 | 现行设计控制探测 | 探测度 | 风险序数 RPN=SXDXO | 改善措施 | 负责人/完成日期 | S改善后严重度不变 | 改善后发生频度 | 改善后可探测度 | 新风险序数 |
1 | file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image3.png | 灯罩系统 | file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image4.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image8.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image16.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image32.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image64.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image128.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image256.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image512.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1024.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2050.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2049.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1023.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2048.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2047.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image511.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1022.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2046.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2045.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1021.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2044.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2043.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image255.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image510.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1020.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2042.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2041.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1019.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2040.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2039.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image509.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1018.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2038.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2037.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1017.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2036.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2035.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image127.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image254.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image508.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1016.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2034.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2033.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1015.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2032.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2031.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image507.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1014.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2030.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2029.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1013.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2028.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2027.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image253.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image506.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1012.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2026.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2025.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1011.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2024.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2023.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image505.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1010.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2022.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2021.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1009.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2020.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2019.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image63.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image126.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image252.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image504.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1008.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2018.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2017.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1007.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2016.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2015.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image503.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1006.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2014.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2013.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1005.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2012.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2011.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image251.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image502.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1004.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2010.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2009.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1003.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2008.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2007.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image501.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1002.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2006.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2005.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1001.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2004.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2003.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image125.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image250.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image500.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1000.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2002.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2001.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image999.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2000.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1999.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image499.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image998.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1998.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1997.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image997.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1996.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1995.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image249.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image498.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image996.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1994.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1993.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image995.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1992.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1991.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image497.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image994.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1990.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1989.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image993.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1988.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1987.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image31.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image62.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image124.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image248.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image496.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image992.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1986.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1985.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image991.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1984.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1983.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image495.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image990.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1982.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1981.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image989.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1980.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1979.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image247.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image494.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image988.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1978.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1977.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image987.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1976.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1975.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image493.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image986.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1974.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1973.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image985.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1972.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1971.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image123.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image246.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image492.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image984.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1970.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1969.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image983.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1968.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1967.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image491.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image982.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1966.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1965.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image981.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1964.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1963.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image245.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image490.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image980.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1962.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1961.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image979.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1960.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1959.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image489.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image978.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1958.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1957.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image977.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1956.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1955.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image61.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image122.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image244.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image488.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image976.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1954.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1953.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image975.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1952.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1951.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image487.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image974.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1950.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1949.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image973.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1948.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1947.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image243.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image486.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image972.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1946.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1945.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image971.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1944.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1943.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image485.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image970.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1942.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1941.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image969.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1940.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1939.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image121.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image242.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image484.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image968.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1938.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1937.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image967.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1936.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1935.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image483.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image966.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1934.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1933.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image965.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1932.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1931.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image241.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image482.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image964.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1930.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1929.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image963.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1928.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1927.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image481.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image962.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1926.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1925.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image961.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1924.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1923.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image15.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image30.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image60.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image120.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image240.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image480.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image960.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1922.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1921.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image959.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1920.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1919.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image479.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image958.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1918.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1917.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image957.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1916.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1915.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image239.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image478.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image956.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1914.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1913.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image955.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1912.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1911.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image477.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image954.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1910.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1909.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image953.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1908.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1907.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image119.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image238.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image476.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image952.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1906.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1905.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image951.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1904.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1903.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image475.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image950.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1902.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1901.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image949.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1900.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1899.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image237.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image474.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image948.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1898.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1897.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image947.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1896.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1895.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image473.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image946.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1894.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1893.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image945.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1892.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1891.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image59.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image118.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image236.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image472.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image944.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1890.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1889.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image943.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1888.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1887.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image471.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image942.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1886.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1885.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2318.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2317.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2316.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2315.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2314.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2313.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2312.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2311.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2310.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2309.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2308.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2307.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2306.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2305.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2304.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2303.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2302.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2301.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2300.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2299.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2298.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2297.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2296.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2295.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2294.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2293.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2292.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2291.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2290.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2289.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2288.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2287.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2286.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2285.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2284.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2283.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2282.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2281.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2280.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2279.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2278.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2277.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2276.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2275.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2274.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2273.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2272.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2271.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2270.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2269.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2268.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2267.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2266.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2265.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2264.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2263.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2262.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2261.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2260.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2259.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2258.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2257.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2256.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2255.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2254.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2253.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2252.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2251.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2250.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2249.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2248.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2247.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2246.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2245.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2244.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2243.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2242.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2241.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2240.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2239.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2238.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2237.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2236.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2235.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2234.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2233.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2232.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2231.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2230.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2229.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2228.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2227.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2226.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2225.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2224.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2223.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2222.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2221.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2220.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2219.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2218.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2217.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2216.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2215.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2214.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2213.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2212.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2211.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2210.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2209.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2208.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2207.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2206.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2205.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2204.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2203.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2202.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2201.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2200.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2199.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2198.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2197.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2196.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2195.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2194.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2193.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2192.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2191.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2190.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2189.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2188.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2187.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2186.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2185.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2184.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2183.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2182.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2181.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2180.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2179.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2178.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2177.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2176.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2175.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2174.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2173.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2172.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2171.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2170.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2169.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2168.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2167.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2166.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2165.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2164.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2163.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2162.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2161.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2160.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2159.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2158.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2157.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2156.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2155.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2154.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2153.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2152.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2151.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2150.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2149.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2148.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2147.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2146.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2145.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2144.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2143.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2142.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2141.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2140.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2139.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2138.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2137.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2136.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2135.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2134.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2133.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2132.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2131.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2130.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2129.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2128.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2127.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2126.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2125.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2124.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2123.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2122.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2121.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2120.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2119.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2118.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2117.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2116.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2115.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2114.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2113.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2112.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2111.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2110.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2109.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2108.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2107.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2106.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2105.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2104.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2103.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2102.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2101.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2100.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2099.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2098.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2097.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2096.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2095.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2094.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2093.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2092.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2091.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2090.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2089.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2088.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2087.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2086.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2085.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2084.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2083.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2082.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2081.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2080.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2079.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2078.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2077.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2076.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2075.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2074.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2073.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2072.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2071.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2070.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2069.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2068.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2067.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2066.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2065.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2064.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2063.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2062.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2061.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2060.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2059.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2058.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2057.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2056.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2055.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2054.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2053.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2052.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2051.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image941.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1884.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1883.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image235.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image470.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image940.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1882.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1881.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image939.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1880.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1879.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image469.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image938.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1878.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1877.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image937.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1876.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1875.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image117.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image234.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image468.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image936.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1874.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1873.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image935.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1872.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1871.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image467.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image934.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1870.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1869.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image933.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1868.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1867.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image233.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image466.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image932.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1866.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1865.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image931.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1864.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1863.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image465.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image930.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1862.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1861.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image929.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1860.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1859.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image29.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image58.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image116.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image232.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image464.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image928.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1858.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1857.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image927.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1856.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1855.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image463.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image926.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1854.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1853.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image925.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1852.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1851.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image231.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image462.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image924.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1850.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1849.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image923.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1848.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1847.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image461.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image922.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1846.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1845.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image921.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1844.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1843.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image115.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image230.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image460.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image920.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1842.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1841.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image919.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1840.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1839.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image459.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image918.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1838.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1837.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image917.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1836.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1835.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image229.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image458.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image916.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1834.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1833.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image915.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1832.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1831.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image457.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image914.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1830.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1829.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image913.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1828.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1827.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image57.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image114.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image228.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image456.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image912.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1826.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1825.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image911.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1824.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1823.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image455.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image910.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1822.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1821.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image909.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1820.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1819.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image227.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image454.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image908.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1818.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1817.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image907.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1816.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1815.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image453.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image906.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1814.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1813.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image905.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1812.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1811.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image113.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image226.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image452.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image904.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1810.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1809.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image903.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1808.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1807.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image451.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image902.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1806.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1805.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image901.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1804.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1803.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image225.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image450.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image900.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1802.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1801.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image899.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1800.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1799.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image449.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image898.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1798.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1797.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image897.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1796.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1795.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image7.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image14.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image28.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image56.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image112.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image224.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image448.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image896.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1794.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1793.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image895.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1792.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1791.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image447.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image894.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1790.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1789.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image893.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1788.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1787.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image223.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image446.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image892.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1786.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1785.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image891.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1784.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1783.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image445.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image890.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1782.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1781.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image889.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1780.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1779.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image111.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image222.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image444.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image888.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1778.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1777.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image887.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1776.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1775.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image443.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image886.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1774.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1773.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image885.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1772.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1771.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image221.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image442.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image884.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1770.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1769.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image883.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1768.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1767.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image441.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image882.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1766.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1765.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image881.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1764.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1763.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image55.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image110.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image220.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image440.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image880.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1762.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1761.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image879.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1760.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1759.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image439.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image878.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1758.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1757.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image877.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1756.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1755.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image219.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image438.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image876.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1754.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1753.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image875.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1752.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1751.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image437.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image874.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1750.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1749.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image873.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1748.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1747.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image109.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image218.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image436.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image872.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1746.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1745.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image871.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1744.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1743.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image435.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image870.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1742.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1741.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image869.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1740.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1739.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image217.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image434.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image868.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1738.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1737.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image867.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1736.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1735.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image433.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image866.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1734.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1733.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image865.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1732.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1731.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image27.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image54.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image108.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image216.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image432.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image864.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1730.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1729.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image863.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1728.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1727.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image431.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image862.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1726.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1725.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image861.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1724.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1723.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image215.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image430.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image860.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1722.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1721.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image859.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1720.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1719.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1718.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1717.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1716.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1715.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1714.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1713.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1712.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1711.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1710.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1709.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1708.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1707.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1706.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1705.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1704.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1703.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1702.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1701.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1700.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1699.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1698.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1697.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1696.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1695.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1694.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1693.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1692.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1691.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1690.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1689.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1688.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1687.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1686.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1685.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1684.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1683.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1682.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1681.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1680.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1679.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1678.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1677.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1676.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1675.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1674.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1673.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1672.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1671.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1670.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1669.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1668.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1667.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1666.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1665.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1664.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1662.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image429.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image858.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image857.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image107.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image214.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image428.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image856.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image855.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image427.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image854.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image853.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image213.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image426.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image852.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image851.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image425.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image850.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image849.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image53.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image106.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image212.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image424.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image848.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image847.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image423.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image846.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image845.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image211.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image422.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image844.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image843.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image421.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image842.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image841.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image105.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image210.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image420.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image840.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image839.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image419.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image838.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image837.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image209.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image418.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image836.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image835.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image417.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image834.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image833.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image13.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image26.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image52.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image104.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image208.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image416.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image832.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image831.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image415.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image830.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image829.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image207.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image414.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image828.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image827.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image413.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image826.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image825.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image103.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image206.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image412.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image824.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image823.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image411.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image822.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image821.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image205.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image410.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image820.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image819.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image409.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image818.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image817.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image51.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image102.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image204.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image408.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image816.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image815.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image407.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image814.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image813.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image203.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image406.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image812.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image811.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image405.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image810.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image809.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image101.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image202.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image404.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image808.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image807.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image403.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image806.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image805.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image201.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image402.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image804.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image803.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image401.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image802.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image801.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image25.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image50.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image100.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image200.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image400.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image800.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image799.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image399.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image798.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image797.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image199.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image398.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image796.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image795.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image397.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image794.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image793.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image99.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image198.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image396.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image792.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image791.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image395.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image790.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image789.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image197.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image394.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image788.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image787.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image393.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image786.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image785.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image49.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image98.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image196.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image392.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image784.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image783.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image391.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image782.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image781.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image195.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image390.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image780.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image779.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image389.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image778.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image777.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image97.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image194.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image388.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image776.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image775.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image387.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image774.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image773.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image193.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image386.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image772.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image771.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image385.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image770.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image769.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image6.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image12.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image24.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image48.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image96.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image192.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image384.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image768.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image767.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image383.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image766.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image765.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image191.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image382.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image764.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image763.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image381.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image762.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image761.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image95.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image190.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image380.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image760.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image759.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image379.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image758.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image757.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image189.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image378.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image756.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image755.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image377.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image754.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image753.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image47.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image94.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image188.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image376.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image752.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image751.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image375.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image750.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image749.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image187.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image374.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image748.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image747.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image373.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image746.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image745.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image93.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image186.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image372.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image744.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image743.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image371.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image742.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image741.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image185.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image370.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image740.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image739.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image369.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image738.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image737.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image23.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image46.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image92.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image184.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image368.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image736.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image735.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image367.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image734.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image733.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image183.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image366.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image732.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image731.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image365.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image730.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image729.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image91.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image182.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image364.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image728.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image727.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image363.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image726.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image725.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image181.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image362.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image724.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image723.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image361.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image722.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image721.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image45.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image90.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image180.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image360.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image720.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image719.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image359.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image718.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image717.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image179.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image358.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image716.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image715.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image357.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image714.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image713.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image89.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image178.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image356.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image712.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image711.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image355.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image710.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image709.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image177.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image354.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image708.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image707.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image353.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image706.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image705.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image11.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image22.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image44.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image88.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image176.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image352.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image704.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image703.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image351.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image702.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image701.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image175.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image350.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image700.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image699.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image349.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image698.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image697.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image87.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image174.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image348.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image696.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image695.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image347.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image694.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1332.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1331.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1330.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1329.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1328.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1327.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1326.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1325.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1324.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1323.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1322.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1321.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1320.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1319.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1318.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1317.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1316.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1315.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1314.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1313.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1312.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1311.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1310.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1309.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1308.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1307.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1306.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1305.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1304.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1303.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1302.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1301.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1300.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1299.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1298.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1297.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1296.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1295.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1294.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1293.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1292.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1291.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1290.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1289.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1288.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1287.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1286.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1285.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1284.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1283.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1282.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1281.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1280.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1279.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1278.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1277.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1276.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1275.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1274.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1273.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1272.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1271.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1270.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1269.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1268.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1267.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1266.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1265.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1264.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1263.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1262.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1261.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1260.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1259.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1258.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1257.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1256.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1255.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1254.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1253.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1252.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1251.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1250.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1249.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1248.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1247.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1246.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1245.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1244.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1243.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1242.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1241.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1240.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1239.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1238.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1237.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1236.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1235.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1234.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1233.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1232.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1231.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1230.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1229.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1228.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1227.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1226.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1225.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1224.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1223.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1222.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1221.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1220.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1219.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1218.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1217.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1216.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1215.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1214.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1213.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1212.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1211.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1210.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1209.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1208.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1207.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1206.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1205.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1204.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1203.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1202.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1201.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1200.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1199.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1198.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1197.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1196.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1195.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1194.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1193.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1192.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1191.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1190.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1189.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1188.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1187.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1186.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1185.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1184.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1183.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1182.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1181.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1180.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1179.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1178.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1177.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1176.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1175.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1174.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1173.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1172.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1171.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1170.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1169.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1168.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1167.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1166.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1165.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1164.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1163.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1162.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1161.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1160.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1159.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1158.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1157.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1156.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1155.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1154.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1153.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1152.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1151.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1150.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1149.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1148.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1147.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1146.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1145.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1144.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1143.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1142.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1141.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1140.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1139.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1138.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1137.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1136.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1135.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1134.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1133.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1132.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1131.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1130.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1129.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1128.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1127.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1126.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1125.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1124.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1123.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1122.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1121.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1120.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1119.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1118.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1117.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1116.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1115.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1114.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1113.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1112.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1111.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1110.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1109.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1108.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1107.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1106.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1105.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1104.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1103.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1102.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1101.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1100.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1099.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1098.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1097.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1096.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1095.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1094.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1093.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1092.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1091.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1090.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1089.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1088.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1087.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1086.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1085.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1084.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1083.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1082.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1081.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1080.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1079.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1078.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1077.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1076.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1075.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1074.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1073.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1072.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1071.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1070.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1069.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1068.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1067.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1066.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1065.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1064.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1063.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1062.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1061.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1060.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1059.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1058.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1057.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1056.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1055.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1054.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1053.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1052.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1051.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1050.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1049.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1048.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1047.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1046.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1045.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1044.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1043.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1042.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1041.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1040.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1039.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1038.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1037.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1036.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1035.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1034.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1033.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1032.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1031.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1030.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1029.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1028.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1027.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1026.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1025.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image693.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image173.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image346.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image692.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image691.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image345.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image690.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image689.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image43.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image86.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image172.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image344.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image688.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image687.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image343.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image686.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image685.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image171.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image342.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image684.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image683.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image341.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image682.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image681.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image85.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image170.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image340.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image680.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image679.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image339.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image678.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image677.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image169.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image338.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image676.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image675.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image337.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image674.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image673.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image21.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image42.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image84.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image168.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image336.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image672.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image671.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image335.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image670.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image669.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image167.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image334.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image668.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image667.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image333.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image666.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image665.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image83.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image166.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image332.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image664.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image663.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image331.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image662.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image661.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image165.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image330.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image660.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image659.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image329.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image658.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image657.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image41.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image82.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image164.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image328.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image656.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image655.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image327.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image654.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image653.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image163.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image326.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image652.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image651.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image325.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image650.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image649.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image81.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image162.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image324.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image648.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image647.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image323.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image646.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image645.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image161.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image322.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image644.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image643.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image321.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image642.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image641.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image5.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image10.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image20.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image40.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image80.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image160.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image320.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image640.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image639.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image319.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image638.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image637.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image159.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image318.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image636.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image635.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image317.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image634.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image633.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image79.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image158.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image316.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image632.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image631.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image315.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image630.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image629.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image157.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image314.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image628.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image627.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image313.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image626.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image625.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image39.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image78.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image156.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image312.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image624.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image623.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image311.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image622.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image621.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image155.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image310.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image620.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image619.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image309.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image618.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image617.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image77.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image154.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image308.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image616.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image615.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image307.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image614.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image613.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image153.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image306.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image612.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image611.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image305.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image610.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image609.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image19.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image38.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image76.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image152.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image304.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image608.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image607.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image303.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image606.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image605.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image151.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image302.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image604.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image603.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image301.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image602.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image601.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image75.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image150.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image300.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image600.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image599.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image299.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image598.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image597.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image149.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image298.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image596.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image595.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image297.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image594.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image593.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image37.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image74.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image148.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image296.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image592.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image591.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image295.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image590.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image589.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image147.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image294.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image588.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image587.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image293.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image586.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image585.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image73.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image146.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image292.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image584.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image583.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image291.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image582.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image581.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image145.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image290.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image580.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image579.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image289.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image578.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image577.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image9.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image18.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image36.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image72.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image144.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image288.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image576.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image575.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image287.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image574.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image573.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image143.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image286.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image572.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image571.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image285.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image570.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image569.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image71.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image142.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image284.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image568.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image567.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image283.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image566.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image565.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image141.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image282.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image564.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image563.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image281.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image562.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image561.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image35.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image70.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image140.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image280.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image560.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image559.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image279.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image558.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image557.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image139.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image278.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image556.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image555.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image277.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image554.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image553.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image69.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image138.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image276.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image552.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image551.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image275.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image550.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image549.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image137.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image274.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image548.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image547.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image273.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image546.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image545.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image17.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image34.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image68.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image136.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image272.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image544.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image543.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image271.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image542.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image541.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image135.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image270.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image540.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image539.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image269.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image538.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image537.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image67.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image134.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image268.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image536.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image535.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image267.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image534.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image533.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image133.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image266.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image532.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image531.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image265.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image530.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image529.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image33.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image66.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image132.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image264.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image528.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image527.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image263.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image526.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image525.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image131.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image262.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image524.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image523.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image261.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image522.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image521.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image65.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image130.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image260.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image520.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image519.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image259.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image518.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image517.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image129.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image258.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image516.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image515.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image257.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image514.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image513.png消费者装配压环比较困难 | 客户体验差 | 6 | 灯罩口部尺寸为50mm太小 | 2 | 灯罩口部尺寸由50mm增大到54mm,压环装配方便 | QC量具检查 | 7 | 84 | | | | | | |
塑胶灯罩边缘有明显的缩水痕,气纹 | 外观不良 | 6 | 模具设计不合理 | 2 | 增加模具排气 | QC目视检查 | 6 | 72 | | | | | | |
塑胶灯罩边缘有披锋,利边 | 外观不良 | 6 | 后模模芯有0.03MM左右的加工间隙
| 5 | 1.提高模具精度,使其无加工间隙;
2.采用320T的注塑机加工 | QC目视检查 | 7 | 210 | 采用650T的注塑机加工,灯罩边缘会比较光滑 | 张坚/刘丹2023/9/12 | 6 | 2 | 7 | 84 |
file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2645.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2643.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2639.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2631.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2615.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2583.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2519.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2581.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2345.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2365.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2461.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2341.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2324.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2606.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2598.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2617.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2569.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2584.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2471.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2563.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2416.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2556.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2442.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2517.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2457.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2492.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2638.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2539.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2398.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2333.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2363.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2332.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2330.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2413.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2618.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2630.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2628.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2623.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2578.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2499.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2435.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2397.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2329.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2326.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2634.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2347.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2474.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2389.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2601.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2386.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2614.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2612.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2608.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2607.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2599.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2597.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2592.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2582.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2580.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2576.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2568.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2575.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2567.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2565.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2560.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2551.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2549.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2545.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2544.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2536.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2534.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2529.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2518.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2516.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2512.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2504.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2488.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2511.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2503.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2501.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2496.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2487.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2485.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2481.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2480.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2472.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2470.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2465.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2455.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2453.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2449.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2441.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2448.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2440.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2438.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2433.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2424.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2422.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2418.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2417.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2409.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2407.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2402.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2390.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2388.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2384.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2376.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2360.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2328.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2383.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2375.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2373.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2368.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2359.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2357.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2353.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2352.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2344.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2342.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2337.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2327.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2325.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2321.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2637.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2320.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2633.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2616.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2622.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2602.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2585.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2586.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2591.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2574.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2571.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2554.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2577.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2605.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2477.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2600.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2478.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2579.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2537.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2548.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2350.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2456.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2493.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2473.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2410.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2446.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2421.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2437.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2540.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2535.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2528.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2510.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2479.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2524.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2506.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2489.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2495.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2475.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2458.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2459.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2464.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2447.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2444.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2427.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2412.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2395.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2396.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2377.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2401.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2382.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2379.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2362.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2351.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2348.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2340.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2331.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2632.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2641.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2625.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2547.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2562.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2550.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2514.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2450.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2603.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2566.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2521.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2513.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2507.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2482.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2454.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2443.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2432.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2423.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2385.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2355.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2367.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2543.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2319.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2610.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2587.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2538.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2505.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2460.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2486.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2404.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2322.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2343.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2358.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2613.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2559.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2439.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2595.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2546.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2467.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2498.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2405.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2370.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2532.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2646.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2426.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2369.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2642.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2636.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2635.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2604.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2593.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2466.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2624.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2621.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2620.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2596.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2589.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2572.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2541.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2552.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2561.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2558.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2557.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2530.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2527.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2509.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2526.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2508.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2500.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2494.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2469.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2462.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2445.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2414.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2349.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2425.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2434.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2431.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2430.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2403.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2400.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2381.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2399.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2380.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2372.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2366.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2338.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2335.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2391.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2588.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2334.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2644.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2629.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2619.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2520.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2553.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2531.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2555.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2392.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2490.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2502.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2428.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2346.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2371.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2626.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2354.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2429.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2356.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2408.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2361.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2364.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2323.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2640.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2609.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2523.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2522.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2491.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2411.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2476.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2378.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2594.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2570.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2394.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2339.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2451.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2468.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2336.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2483.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2419.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2525.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2420.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2374.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2436.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2627.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2590.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2533.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2406.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2387.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2611.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2573.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2542.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2564.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2515.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2484.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2393.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2497.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2463.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2452.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image2415.png 纸灯罩中间孔不居中,边缘切边不均匀 | 外观不良 | 6 | 在设计冲孔和切边模具时,没有固定好灯罩,灯罩移位 | 2 | 改善冲孔和切边模具增加固定灯罩的夹具 | QC目视检查 | 7 | 84 | | | | | | |
file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1641.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1606.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1639.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1633.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1573.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1398.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1594.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1512.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1549.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1474.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1521.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1497.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1517.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1466.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1501.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1486.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1487.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1539.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1453.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1437.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1443.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1405.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1428.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1411.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1384.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1467.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1396.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1380.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1369.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1358.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1362.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1359.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1657.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1586.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1608.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1626.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1627.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1600.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1612.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1597.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1593.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1554.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1579.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1566.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1562.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1541.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1547.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1529.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1534.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1560.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1481.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1499.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1500.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1472.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1485.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1469.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1465.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1426.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1451.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1438.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1434.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1413.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1419.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1401.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1406.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1571.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1388.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1375.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1371.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1349.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1356.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1337.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1342.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1587.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1354.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1596.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1650.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1468.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1624.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1613.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1478.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1543.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1661.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1640.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1615.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1622.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1589.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1592.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1515.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1545.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1513.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1538.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1457.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1503.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1351.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1461.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1430.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1417.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1385.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1410.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1334.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1370.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1357.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1333.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1454.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1653.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1609.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1522.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1531.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1395.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1482.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1495.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1479.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1402.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1338.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1336.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1464.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1585.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1548.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1448.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1339.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1514.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1652.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1647.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1632.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1631.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1621.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1616.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1575.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1598.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1588.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1583.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1568.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1567.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1557.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1552.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1528.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1535.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1525.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1520.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1505.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1504.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1494.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1489.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1553.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1470.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1460.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1455.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1440.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1439.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1429.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1424.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1400.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1407.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1397.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1392.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1377.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1376.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1366.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1361.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1595.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1343.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1476.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1510.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1629.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1644.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1620.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1614.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1533.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1580.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1556.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1550.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1508.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1518.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1490.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1493.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1341.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1432.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1422.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1421.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1374.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1389.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1365.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1656.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1619.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1625.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1611.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1601.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1569.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1570.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1551.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1537.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1458.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1498.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1484.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1473.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1441.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1442.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1423.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1409.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1363.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1379.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1360.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1345.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1651.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1445.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1602.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1607.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1617.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1630.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1604.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1546.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1480.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1491.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1488.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1391.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1352.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1367.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1355.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1582.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1618.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1563.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1394.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1523.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1372.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1576.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1526.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1346.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1654.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1636.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1623.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1591.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1590.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1572.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1559.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1536.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1527.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1509.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1496.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1456.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1462.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1444.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1431.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1408.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1399.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1381.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1368.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1660.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1335.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1645.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1628.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1565.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1564.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1524.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1502.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1347.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1425.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1390.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1373.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1634.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1610.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1578.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1555.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1492.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1483.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1450.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1427.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1378.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1364.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1530.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1637.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1635.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1561.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1506.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1418.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1382.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1642.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1558.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1477.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1658.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1403.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1638.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1599.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1574.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1540.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1511.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1415.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1446.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1412.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1383.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1344.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1648.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1581.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1532.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1404.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1393.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1643.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1577.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1507.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1449.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1387.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1544.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1340.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1433.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1649.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1353.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1655.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1603.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1542.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1447.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1414.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1348.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1584.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1436.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1646.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1516.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1416.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1386.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1420.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1605.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1463.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1350.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1452.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1435.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1519.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1471.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1475.png file:///C:\Users\liuq\AppData\Local\Temp\ksohtml\clip_image1459.png 纸灯罩有色差 | 外观不良 | 6 | 灯罩原料采用回收料的批次不一样,颜色不稳定 | 2 | 与供应商签订颜色板,来料检查 | QC目视检查 | 7 | 84 | | | | | | |
