楼主: im7
每日英日(24.10.29~25.10.29)
 楼主| 发表于 2024-12-6 08:33:12 | 显示全部楼层
2024.12.5( {) ^0 |  q! j1 K  }1 V: c
To accept ourselves as we are means to value our perfection s as much as our perfections.
所谓接受自己,意味着重视自己的完美,也珍视自己的不完美。0 C$ \; A( ^% {9 q  H
8 X# `1 y  C0 A  \ATC (Automatic Tool Change) 自动换刀装置
* {5 b2 E* f, ]ball screw 滚珠丝杠
; N6 N& e5 W: {% ^4 v2 ]boring ['bɔːriŋ] n. 镗孔+ B* P) ^5 m; h& r3 a/ j8 Y& B
broaching ['brəutʃiŋ] n. 拉削;扩孔; N6 b. Z6 E. c( ?
cast iron 铸铁' d' V7 |. [. _8 g8 H* w
characteristics [ˌkæriktə'ristiks] n. 特征,特性
! v. i. Y' D6 `& B4 xcolumn ['kɔləm] n. 立柱
+ s3 i1 U( S) w8 I# ccontrol panel 控制面板
+ U7 m% r. Y: E5 e6 u) w& b2 P& pdedicated manufacturing lines 专业生产线
8 \% \9 q* ?% hdesirability [diˌzaiərə'biliti] n. 客观需求;愿望5 \9 @% L0 E8 `- F+ i' Z/ I
drawbar ['drɔːˌbaː] n. 拉杆;导杆, C3 c; e( v2 A' A3 Z/ @+ C
emphasize ['emfəsaiz] v. 强调;着重. P9 r% T5 m& v5 v/ h. f
evolve [i'vɔlv] v. 使发展成;使形成;演化;进展
  W/ r' D8 K# s1 a/ E' Textrusion [ekstruːʒən] n. 挤出;推出;压出5 X5 S3 }6 Q% V$ U* [% k6 a& t
feasible ['fiːzəbl] adj. 可能的,切实可行的
& G$ N! ?" s1 y+ X6 t- efemale die 阴模
  s5 w  g, b& @; P8 O0 [4 o; rflexibility [ˌfleksə'biliti] n. 柔性,弹性;灵活性
6 J3 i- W2 Z( I: j" o% u$ d5 @9 p' U
' j/ Z- ]& U3 H( E! D5 S% M/ E
 楼主| 发表于 2024-12-6 08:35:07 | 显示全部楼层
2024.12.6# h/ k$ I" R0 C: v
An animal's eyes have the power to speak a great language.
2 K& N% B( C0 q7 \动物的眼睛有一种神奇的力量,诉说着千言万语。/ u5 C4 C- e; g; v
+ B# Z! d; X# |& D# k7 q& Q& D2 S  Y- `$ P+ V5 E' M* I
frame [freim] n. 机架
# i2 F6 X# `6 ~gasket ['gæskit] n. 衬垫;垫圈;密封垫
7 Y* J0 x/ f7 U6 A; khigh-volume or mass production 大(批)量生产* B3 P0 g. |! ^$ i$ ?0 G
horizontal machining center 卧式加工中心
3 f  Y3 f  f  Z0 F, }0 phorsepower ['hɔːsˌpauə] n. 马力; n, a, u4 ]& D' K
hydraulic and lubrication system 液压和润滑系统7 A: l$ m2 f0 C
indexer [in'deksə] n. 分度器- h$ v. y& ]9 e7 U( j# F7 f
individual [ˌindi'vidjuəl] n. 个人,个体,独立单位 adj. 个人的;个别的;独特的' Y3 i- Z8 Z! C4 o$ ?9 B6 Q4 b* t
male die 阳模+ b! d6 s) @2 o$ ]0 H/ v# j$ b+ L
MCU (Machine Control Unit) 机床控制单元
6 H* ?7 x% p3 hnet-shape 终形- _% h8 j) F1 }  p( x+ f9 W' O/ f& e
observation [ˌəbzəː'veiʃən] n. 执行,遵守;(观察所得的)知识;经验;[常用复]观察[测]资料;观察值
- o" V# d' {; L/ H0 L5 W6 zorientation [ˌɔːrien'teitʃən] n. 定位;方向
8 ~  m/ H& x) I% t( X5 opallet ['pælit] n. 托盘) Z4 P% |+ Q" Z# u" t
powder metallurgy 粉末冶金
" v8 K  j6 Y  }" H; d) cprecision forging 精锻
4 e8 D  n  K) @! n* L* f; rradii ['reidiai] n. (pl) 半径
+ B( l# z( h' O# Z0 Sram [ræm] n. 冲压;滑枕;柱塞1 ~/ E5 Z- O1 g! m  j4 X: z
$ @  C# [# F0 [. y9 p/ i
GMT+8, 2025-4-25 04:18 , Processed in 0.054663 second(s), 14 queries , Gzip On.
