2024.11.26. w$ v# _; w9 b6 I" d- Y
/ h$ w5 d$ m8 a v. b5 Z! F
6 ~2 P* o& V) x0 GWe can't all be heroes, because somebody has to sit on the curb and applaud when they go by.
1 u/ m( L! n/ N' U* N我们不可能都成为英雄,总得有人在英雄走过的时候坐在路边鼓掌。2 V5 O1 b0 P9 ?, }: o2 |
% Y1 @+ D8 t4 n, P# h3 r( v3 s. J5 x4 F- e: E' O7 u) T
flowmeter [fləu'miːtə] n. 流量计;流速计
% k$ r U9 q) y- s" sfluid ['fluːid] adj. 流体的,流动的 n. 流体,液体9 Z3 E1 U7 |, A4 R: I# _
gear-type motor 齿轮马达
! u4 @: F3 [3 P. ^6 Qgenerator ['dʒenəreitə] n. 发电机;发生器
6 j6 q% y$ q! [, t6 L8 a# R+ Zherringbone ['heriŋbəun] n. 人字形(图案)
4 T% W3 O) { ]; h# n' thydraulics [hai'drɔːliks] n. 水力学;液压系统;液压技术
" U8 A) Z, {8 x7 `0 Nincorporate [in'kɔːpəreit] v. 结合;存入;包括, [0 x ]6 S# m+ [: n9 v0 g
inlet ['inlet] n. 入口,进口;进气道" M$ W C5 }* [4 u" ]! _3 W
integral ['intigrəl] adj. 整体的;完整的 n. 整体, ]& G* W4 f* N7 T$ |& _. P
jet [dʒet] n. 喷嘴;喷口 v. 喷射,喷溅8 E+ M6 Z/ R9 T- n
leakage ['liːkidʒ] n. 泄漏;漏损;渗漏
5 R. p- \. d9 `- e9 hmalfunction [mæl'fʌŋkʃən] n. 故障 v. 发生故障- R" }- Z; d) g7 z" }" |; I
master control valve 主控阀" d4 \' L& K) I/ D: G
meter ['miːtə] v. 节流;节制;控制(流量)
3 r# M0 W* ~+ ?# Z8 sneedle valve 针阀4 t# A- k9 b- \4 o$ z& z
nozzle ['nɔzl] n. 喷嘴;管嘴;筒口; J, |4 Y* j' x* x0 q$ l# ?8 w/ C
orifice ['ɔːrəfis] n. 小开口,小孔" @& G# K3 w, T1 b* `
outlet ['autlet] n. 出口;排水口;排油口;电源插座+ D, I. {; {0 w# Y
pilot-operated check valve 液控单向阀
) K d7 C' z4 Y5 `6 H- T( K& x' Spilot valve 先导阀
, N. a- b- E: ~4 u3 B. i' i4 [
! a3 D$ l0 Q% a" J8 r4 B, @5 D) G4 W |
