Type BomPosition
* [0 ^. ~2 F! Q" T l- U( ` model As SldWorks.ModelDoc2: b2 i; @% d3 R4 x
Configuration As String. k& F3 f1 L* K% p
Quantity As Double
' c& `/ R H2 c3 lEnd Type- [7 v7 l$ \. b
9 L Y& H" F( p$ ZConst PRP_NAME As String = "数量"
3 r! q) q& S( g. _* ?4 PConst MERGE_CONFIGURATIONS As Boolean = True
# K9 c+ v d7 x) {. @" A- A! |Const INCLUDE_BOM_EXCLUDED As Boolean = False
6 n# j' B: }8 T. C
9 j0 J4 I; q" V# {8 i6 {( [9 Z8 K; VDim swApp As SldWorks.SldWorks
# ^" ~& K" l% a& }1 I* s, P7 B/ iSub main()
" P1 }2 ^8 W: G3 M Set swApp = Application.SldWorks
) k0 d& \" l1 O. ~$ w- Gtry_:
1 ~1 b2 w5 V4 ? c On Error GoTo catch_) D" _' G, d2 G0 P& w
Dim swAssy As SldWorks.AssemblyDoc
7 J3 x4 r. M7 Q; D, K0 n( X5 p4 G; ^ Set swAssy = swApp.ActiveDoc$ ?6 H) f* U8 O% H, f, [
If swAssy Is Nothing Then
0 }! h( @" x% s5 W" \( T3 H Err.Raise vbError, "", "Assembly is not opened"
+ d. `$ ~4 x0 _, i End If& K8 G* C$ ?* ~. ^( X( r0 y
swAssy.ResolveAllLightWeightComponents True' O: U" b4 b5 o2 c4 w2 Q
Dim swConf As SldWorks.Configuration
5 n" M4 j M# z9 e# y Set swConf = swAssy.ConfigurationManager.ActiveConfiguration* d& u& N1 }& a7 d4 x5 c% n
Dim bom() As BomPosition
; x6 ^$ g6 H+ k S- `2 }. C0 R ComposeFlatBom swConf.GetRootComponent3(True), bom
2 h3 _" c' m3 {/ k7 _5 z) n If (Not bom) <> -1 Then- Z1 u# ^7 A# k$ r0 S
WriteBomQuantities bom
0 |* L3 k# h3 u" @5 q& s End If
: A: `$ Q: r% y* U" ?0 A: i9 q3 ~ GoTo finally_
+ O( z4 p' L6 u/ X: ncatch_:
2 ^! n4 l Z6 B$ y( m5 q2 ^! n MsgBox Err.Description, vbCritical, "Count Components"
1 J- W- p/ I2 \2 ?' {' C. ]& ^2 afinally_:
/ c4 j' F& A+ i- \End Sub) C7 H0 Z/ }7 X, B
9 [* C1 V5 B0 L0 e# k3 O
Sub ComposeFlatBom(swParentComp As SldWorks.Component2, bom() As BomPosition)
1 J, n) p7 h3 o' ^# ~+ [' ` Dim vComps As Variant- K* Z) B' k v5 B
vComps = swParentComp.GetChildren; N+ b; S4 [* d3 E' ?; G3 m
If Not IsEmpty(vComps) Then
5 J% a& k. E; K7 Z$ G- b- r( | Dim i As Integer9 f2 _- v7 F6 P9 s4 H% s: Y
For i = 0 To UBound(vComps)
4 u; I3 O& T1 `- n1 K- T' ?! [" | Dim swComp As SldWorks.Component2% k$ b6 n0 B; v( r
Set swComp = vComps(i), I# U6 [1 b2 X0 z0 Q
If swComp.GetSuppression() <> swComponentSuppressionState_e.swComponentSuppressed And (False = swComp.ExcludeFromBOM Or INCLUDE_BOM_EXCLUDED) Then- A+ y8 k0 t! t5 O; ^9 U
Dim swRefModel As SldWorks.ModelDoc2) F8 U% a: u% x* S' B$ s
Set swRefModel = swComp.GetModelDoc2()
/ C6 U: `7 G) T5 s If swRefModel Is Nothing Then; h6 P0 r7 J! N. A
Err.Raise vbError, "", swComp.GetPathName() & " model is not loaded"+ R9 I. c: w3 T, Q2 Q
End If% _- c; D' l9 ]# T1 D% u. U
Dim swRefConf As SldWorks.Configuration
+ Y; v- f) D9 S4 i x Set swRefConf = swRefModel.GetConfigurationByName(swComp.ReferencedConfiguration)
1 `2 Z7 I2 a( H8 }9 }. ?8 K Dim bomChildType As Integer+ p8 R. z* N8 X* B
bomChildType = swRefConf.ChildComponentDisplayInBOM
' N1 \( Z5 t4 N2 a: N( g* { If bomChildType <> swChildComponentInBOMOption_e.swChildComponent_Promote Then x/ X: ?# V H4 u7 w7 H& f M
Dim bomPos As Integer
* n% b9 A! B" C0 F7 | bomPos = FindBomPosition(bom, swComp)" b9 y2 P1 j' q
If bomPos = -1 Then
7 {4 X" ^4 y5 }$ d7 B3 v4 {/ q) c N If (Not bom) = -1 Then0 x9 P! @: M( J# E
ReDim bom(0)
5 ]" q K1 n: l3 M: ]" S Else
! m) B) B& M4 ~2 G% w ReDim Preserve bom(UBound(bom) + 1)
1 N/ c4 P3 Z5 F: J! i9 I2 T7 |& A( k$ ~. R2 c End If% O: l& y7 `0 M- l* t, [* i3 G
bomPos = UBound(bom)
% w1 U- X. d3 _3 w2 E Dim refConfName As String: s' R; M3 b2 D
If MERGE_CONFIGURATIONS Then
5 Q) m6 K5 d, I5 {) d2 ~ refConfName = ""
, \6 c7 j- Q$ V: `6 H) O$ t Else
% k$ A: Z- u2 ]/ } refConfName = swComp.ReferencedConfiguration
/ n$ [+ l% g) E/ h4 e( @0 v2 d End If3 l, d z% P, `. ^1 S$ `; T
Set bom(bomPos).model = swRefModel4 ]+ Z2 U/ L) q5 j
bom(bomPos).Configuration = refConfName
# D O8 |. z( j& w; o4 e bom(bomPos).Quantity = GetQuantity(swComp)
6 \. q2 a* }8 K* } D, x; [ Else
% k; N' |& S+ h* f bom(bomPos).Quantity = bom(bomPos).Quantity + GetQuantity(swComp)
: @1 ^6 R+ y0 w6 w8 U; K End If2 V4 \8 q* }- g, x+ C; h( o
End If1 ~$ ~' H/ N( e% \0 G
If bomChildType <> swChildComponentInBOMOption_e.swChildComponent_Hide Then5 o- }4 @5 n( m6 ]8 t4 D$ F
ComposeFlatBom swComp, bom0 ]" [( J- n3 w$ w7 I2 x* u& C
End If
/ V) ~/ O7 L4 n2 F8 P' V: K End If
$ D! P% h+ M3 b/ G+ d- Q Next. X0 [7 l7 R3 j( B; h& S( @
End If& o1 o: b+ B" k: ?, k, ~6 z* }
End Sub, F0 \% U9 n- M- A
3 {3 |- D' v0 E3 b1 L
Function FindBomPosition(bom() As BomPosition, comp As SldWorks.Component2) As Integer6 `+ }/ ?# L% _; J
FindBomPosition = -1/ U) x$ p7 B3 J: i
Dim i As Integer% i# ]( ?3 I b8 W6 U" N
If (Not bom) <> -1 Then7 `& f- E' O/ e) A( j9 M
Dim refConfName As String U% {7 y m; g; J1 ^
If MERGE_CONFIGURATIONS Then, }& r& F2 c- t6 E0 b
refConfName = ""- W' R' P5 C+ b
Else# }) ]" \/ p5 p+ \$ Z5 U8 t2 U+ O
refConfName = comp.ReferencedConfiguration% q3 |, F$ `4 H" n2 r. g
End If
) C; w7 D! v9 y For i = 0 To UBound(bom)
6 E7 r1 u" v7 G5 R4 K If LCase(bom(i).model.GetPathName()) = LCase(comp.GetPathName()) And LCase(bom(i).Configuration) = LCase(refConfName) Then! T. s7 q" V' o# n- m- U: v
FindBomPosition = i1 y; \5 E% P6 J; j; f
Exit Function
7 \. b' i- g5 n( r6 M End If
7 B- H/ I7 p B6 M: I+ I# T Next8 z1 ?9 T* C9 J% e& n
End If( e4 E: |% J+ G1 |
End Function
3 y( W/ P: X3 f4 ^2 @; Z. k8 P7 G" Q, W5 }3 j
Function GetQuantity(comp As SldWorks.Component2) As Double
/ _9 q" E; C- @& AOn Error GoTo err_
+ l; O9 @7 W* i) B/ j. _ Dim refModel As SldWorks.ModelDoc24 ]3 x/ V& P& r* d0 n
Set refModel = comp.GetModelDoc23 ?. j: _* x5 {' g, I" [# o Q
Dim qtyPrpName As String/ x; I9 m" `2 q1 v6 | q* W% C
qtyPrpName = GetPropertyValue(refModel, comp.ReferencedConfiguration, "UNIT_OF_MEASURE")
2 L5 r, E; C2 l& v* x( ^+ O+ k/ b If qtyPrpName <> "" Then* }( `! n. s6 V
GetQuantity = CDbl(GetPropertyValue(refModel, comp.ReferencedConfiguration, qtyPrpName))
. ^6 J% w! c4 ?3 }( B Else
! \; W1 s7 l/ N: s; l+ l GetQuantity = 1
& q0 w& ]' X& g$ i% e End If6 c. `! ?7 \- O c: G+ @
Exit Function- I- P6 V$ f, A: N' B4 _; J# Z
err_:
7 u) |3 _$ K& K* O2 O' T1 p% K; i Debug.Print "Failed to extract quantity of " & comp.Name2 & ": " & Err.Description
5 e M$ b5 z! n. l1 p" b8 l; U1 A; S$ J5 d GetQuantity = 1
4 H* V% H& b$ t# p5 S" \6 jEnd Function, b1 a/ Q1 @4 X- _' o# I$ F
* H8 ~& s7 T) MFunction GetPropertyValue(model As SldWorks.ModelDoc2, conf As String, prpName As String) As String2 H/ x) ]$ x$ k( ?( g: b# Y
Dim confSpecPrpMgr As SldWorks.CustomPropertyManager
! \" l. g c' a, c9 Z, Y Q" G2 @+ H Dim genPrpMgr As SldWorks.CustomPropertyManager9 q. z& r* C! q4 h
Set confSpecPrpMgr = model.Extension.CustomPropertyManager(conf)
1 G8 l1 Q0 W0 h9 [! d3 |7 ?) `1 N; s Set genPrpMgr = model.Extension.CustomPropertyManager("")+ a0 m9 k" Z% a5 w K9 |
Dim prpResVal As String& a( ?8 y2 p+ ?0 x' V
confSpecPrpMgr.Get3 prpName, False, "", prpResVal" V$ {8 l& y0 D" ~6 x+ c4 _
If prpResVal = "" Then5 y! A2 ^: F* v# m1 G* @% a( A
genPrpMgr.Get3 prpName, False, "", prpResVal( G. m% v$ F* I
End If" d# J( Z% |0 I3 j# t) v7 x/ B
GetPropertyValue = prpResVal
2 T* l6 {/ Z7 B) t) `End Function7 k- a8 _2 _4 d! p" A
7 H8 f6 H* s; ~% D
Sub WriteBomQuantities(bom() As BomPosition)
& b" A' e2 l# w; ?+ ~1 j Dim i As Integer- j/ f, j$ r: k% E9 ~5 j9 `
If (Not bom) <> -1 Then6 b. P' ~7 e* A5 o6 p
8 T8 ~' h/ r9 y7 k. [' Q( [0 x5 W Dim refConfName As String
5 z) Q+ y2 f) l% k- y; m" j/ v Dim swRefModel As SldWorks.ModelDoc2% z- a+ P% m$ f- W- f. }6 G* \
Set swRefModel = bom(i).model
/ s6 Y+ ?2 l: u* ^$ e If MERGE_CONFIGURATIONS Then
8 x. N% Y3 E5 u& ` refConfName = ""
3 M: y- {2 ~/ g, ? Else
% ~) ?0 m* i* v* |, I- t refConfName = bom(i).Configuration4 H" k/ R) P) z
If swRefModel.GetBendState() <> swSMBendState_e.swSMBendStateNone Then" e+ b! k$ ~! b8 L! L0 U
Dim swConf As SldWorks.Configuration S+ ]" e+ H0 B; W9 D4 w, l
Set swConf = swRefModel.GetConfigurationByName(refConfName)
5 n5 E! H' n `5 G Dim vChildConfs As Variant
4 { D; b+ z: u vChildConfs = swConf.GetChildren()
7 v$ ]' C7 c- [- j If Not IsEmpty(vChildConfs) Then* a7 {* w3 ~" L, ~
Dim j As Integer
8 K( h0 ~0 A3 B O For j = 0 To UBound(vChildConfs)! Y' Q0 u0 [2 I0 s! Y' B
Dim swChildConf As SldWorks.Configuration
$ [5 s; P* L( P# |+ f Set swChildConf = vChildConfs(j)
+ k) Y D1 {( u8 t: g, w' z6 v2 Z- i8 J) D If swChildConf.Type = swConfigurationType_e.swConfiguration_SheetMetal Then
& D9 I/ p/ _" Y% w( M SetQuantity swRefModel, swChildConf.Name, bom(i).Quantity
" P2 ?7 p9 @/ Z z7 O1 O End If& o6 i1 P; H$ @2 G
Next
) G3 O6 F% j5 X1 g; L End If
/ C3 Q9 K6 I! u2 a7 ] End If
4 n' ~! }- P! o End If
* u% d0 {$ f! y- z( B: D' r SetQuantity swRefModel, refConfName, bom(i).Quantity
& b/ W4 Q4 b- E Next
! W& h# F* E% Z End If1 E( v! J7 u$ f9 M; O
End Sub \% |# q3 O) b5 \$ f" p* x# r
. q9 P) `% l- J$ h5 L% ?( F6 @
Sub SetQuantity(model As SldWorks.ModelDoc2, confName As String, qty As Double)
$ P8 q( W5 X' S7 ?/ @ Dim swCustPrpsMgr As SldWorks.CustomPropertyManager) ^- ?5 I' }, v! W+ @5 D9 x
Set swCustPrpsMgr = model.Extension.CustomPropertyManager(confName) o$ f$ M" V: u; f* r" c( b. Y
swCustPrpsMgr.Add3 PRP_NAME, swCustomInfoType_e.swCustomInfoText, qty, swCustomPropertyAddOption_e.swCustomPropertyReplaceValue
7 D) D# r8 M- P Z8 Z5 m# S5 m swCustPrpsMgr.Set2 PRP_NAME, qty5 B! D/ w0 k" W0 a# u1 a( C
End Sub
' j* B+ \5 [5 a' ^& o |
