查看: 5889|回复: 5
[ansys] workbench求解的时候出现An error occurred while starting the solver
发表于 2023-12-22 00:43:54 | 显示全部楼层 |阅读模式
An error occurred while starting the solver module.  Verify that your solver directory does not reside on a network UNC Path.  Please refer to the Troubleshooting section in the ANSYS Mechanical User Guide for more information.出现这个,试了很多方法,都不行,列如以管理运行,tools-----solve process setting---advanced-----把use GPU……设置为None,还有取消勾选了Distributed选项。有大佬可以帮我看看吗?
& ?& O0 g; B) l
8 f% W8 |& Q7 ]& l8 A+ L$ }1 U2 Y
, ?; K+ O4 L8 X9 m
 楼主| 发表于 2024-1-6 14:29:38 | 显示全部楼层
我的好了,感谢各位大佬的帮助,感谢
发表于 2023-12-22 09:23:03 | 显示全部楼层
“reside on a network UNC Path”,是安装的许可证问题?
 楼主| 发表于 2023-12-22 14:56:16 | 显示全部楼层
这个是我跟这B站的up一步步来的,再说这个是2018版本的,应该不会出现安装许可的问题吧1 t9 {5 A) P! {) `
发表于 2024-1-5 15:46:07 | 显示全部楼层
An Error Occurred While Starting the Solver Module2 R) Q3 U9 F" Q) c1 f
To get further information on what the issue may be, insert a Solution Information object under Solution in the tree, and view the contents.1 x3 |7 V1 d, k; O% z
3 g; o& F, n$ t7 [% d- x( F. ~
Possible reasons that the solver may fail are:3 K$ V: ^& J9 r4 u" @# z+ Q! w+ j
+ j& r  j) V0 \$ h/ r, E
Insufficient memory - You may not have enough virtual memory assigned to your system. To increase the allocation of virtual memory (total paging file size), go to Settings> Control Panel> System (on your Windows Start Menu). Click the Advanced tab and then click Performance Options. Increase the size of your virtual memory.) b' q$ A8 ~$ E6 l7 R
5 y# O  F# n" C5 SInsufficient disk space - You may not have enough disk space to support the increase in virtual memory and the temporary files that are created in the analysis. Be sure you have enough disk space or move to an area where you have enough.% P1 ~1 x* X. F, j0 T
% s, Z/ Z: l7 _8 XCorrupt product installation
, o: x. d/ h$ G9 y9 Q$ i  i5 D4 c3 {2 p/ n, B
License request rejected
5 h( t5 Y# H) d7 F( |
" ~* C3 S; @! M6 s6 `- S  `0 \+ L4 IThe startup directory for cmd.exe has been overridden by the AUTORUN option and as a result causes the solver to be unable to locate the solver input files.* m  _! p4 x# R7 @( K- Z9 R9 x
6 h' x/ b+ `7 g
Solving and UNC Paths
# A" H4 y+ i6 k% K# s; _0 P! gIf a Workbench database resides on a UNC path (for example, \\pghxpuser\Shares) for which you have write permissions, the Ansys input file will be written successfully but will fail to start the solver executable. To solve, map a drive to the location and then reopen the project. If you did not have write permissions, Workbench will instead write the Ansys input file to your temp directory (%tmp%) and perform a solution from that directory.
这是帮助文档对这个问题的原文,可以自行翻译下  发表于 2024-1-5 15:46
GMT+8, 2025-4-12 06:23 , Processed in 0.059092 second(s), 21 queries , Gzip On.
