之前遇到过以下问题,看看对你是否有帮助: ( v2 l9 X& ^% e3 x, n* z/ ]
SolidWorks 2021 Pack and go 功能无法启用的解决方法: . x7 R, x# s, R3 b& R
Pack and Go Nothing Happens 用户 GordonKistlerSOLIDWORKS User Forum2022-05-05 I am using SW2021 SP5.1, freshly installed by my IT department.When I try to do a Pack and Go from within SW, nothing happens. When I try Packand Go from within Windows Explorer, I get the spinning circle but nothingelse. Suggestions? & M7 R' s0 b+ F. w
Gordon Kistler - 2022-05-09 Resettingthe registry and then restarting SolidWorks took care of the problem. Thank you! ( L% [! ~! }( d2 f5 g8 ]
From<https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:yUw32GbYTEqKdgY7-jbZPg/iquestion:e_-F0_riRuKyo78xKK3bgQ>
8 C2 R- q: `% |% F5 H/ R, |' S$ N. }1 \
可以看到是因为注册表有问题,那怎么更改注册表? How to Reset SOLIDWORKS by Resetting the Registry Entries(javelin-tech.com) In SOLIDWORKS youcan make wide array of customization to your user settings and also the userinterface. It can be hard to keep track of these changes if you are editingthem on a daily basis like I do. Also, we all know that system updates havebeen known to damage registry files that SOLIDWORKS needs to be able tofunction correctly. So if you would liketo fully reset all of your SOLIDWORKS preferences, or if you have noticedstrange behavior or missing icons since a recent Windows update. One option toresolve your issues it to reset SOLIDWORKS registry entries. WARNING: Be very carefulwhen making modifications to the registry as this may cause serious instabilityon your system. As such, you will need full administrative permissions on your computer to be able to editthem. Note that Javelin is not responsible for any changes that you maketo your system, the following is just a guide. ResettingSOLIDWORKS Windows Registry steps: 2 ^% V) Z' r2 y3 k, |, V# {
- Close all instances of SOLIDWORKS A% D/ f; R. q- C5 D& {! Q9 O. B
- Launch the Windows Registry Editor. (In Windows XP go to the Start menu and click Run and type: regedit ; In Windows Vista or Windows 7, or Windows 10 go to the Start menu and type: regedit)2 y9 ~# ^; w0 E1 x8 g# b
5 w& P9 _; |% b( S
- In the Registry Editor expand HKEY_CURRENT_USER\Software\SolidWorks1 L4 f0 Q$ J( a/ H
- Expand the SolidWorks folder. This folder contains multiple folders that control different aspects of SOLIDWORKS on your machine. There are separate folders listed here for each different version of SOLIDWORKS that is installed on the machine. In the image below you may see that I have multiple versions (2016, 2017, and 2018).9 s+ a( p3 s# V. P
- It is always advisable not to make permanent changes to the registry without first checking that they will not damage your system. As such, at this point you can right-click the folder that represents the version of SOLIDWORKS that you want to reset (in this case 2018), and select to Rename the folder.
8 {, G) x. D/ M4 y; ~4 x - Rename the entry something like SOLIDWORKS 2018_Backup.& Z" V Y( A. a
WARNING: Do not rename SolidWorks registry key at the top level if you have SOLIDWORKS PDM installed on your system.; o: H/ m+ g( ^" J
" K0 w+ H3 R; |% C* P$ h - Launch SOLIDWORKS 2018. When the program starts it will create a new registry entry in this location called SOLIDWORKS 2018. Once SOLIDWORKS opens. You will be asked to agree to the end user license agreement and treated like a new user.
% A) g3 }3 H- K5 z5 @3 o
SOLIDWORKS Initial Startup How to undothis operation If the problem you wereexperiencing is gone, great! If not, and you want to undo the process ofresetting SOLIDWORKS Windows Registry, no problem, that’s why we only renamedthe SOLIDWORKS entry and didn’t delete it. Simply go back to theRegistry Editor, refresh the display by pressing F5 to show the new entry, andrename the new SolidWorks entry (again best not to delete it until you aresure everything is back exactly as before) then name the old one back to SolidWorks. If the issue is fixedyou are now left with essentially a fresh copy of SOLIDWORKS, meaning anycustomization you have performed will be lost. ' L# C' p/ K& a; O8 E8 p. |, \
From<https://www.javelin-tech.com/blog/2019/01/reset-solidworks-registry/>
: U7 U' ?) x7 Q- W# M# D3 F { |
* Y/ b a0 G0 p, ~8 G% ^5 J1 W% m; s# R8 w" D0 `
+ f. m& C1 X; X0 F$ H, y
( j0 k+ T! Q# \2 Z5 X' h
- i. }; s2 [& }6 J4 K, w5 T, J8 w( y7 j5 L% O8 t6 U
