发表于 2024-9-27 21:36:48
显示全部楼层
: Y- H* C# c+ }- H4 f" u
Dim swApp As Object+ | A7 y$ K. n* g2 c1 Q. l' n
Dim Part As Object! z0 y: U7 b; P% f
Sub main()( d; Q1 b; F0 ?# l- {
# @0 y8 {3 w J/ Q# wSet swApp = Application.SldWorks t" N, i2 T' m1 @% ~" c- @' W
Set Part = swApp.ActiveDoc4 t2 a3 y3 ~0 J9 @
& m* f4 m+ O$ n- ^Set swSelMgr = Part.SelectionManager
7 l. o# F9 ^/ ?Set swComp = swSelMgr.GetSelectedObject(1)! D. @) D9 Z1 O4 s% c
9 T& }+ h& V) R9 holdpathname = swComp.GetPathName! t: i S9 z% v% S$ R$ _# x
+ G% X$ V7 f+ h2 xPath = Left(oldpathname, InStrRev(oldpathname, "\"))
8 v3 R8 i! M- V+ w+ Q7 f. J- z5 ?2 W3 D: Sntype = Mid(oldpathname, InStrRev(oldpathname, ".")): f% I; o3 ^. B# V/ i N- Y( I5 s
& t z/ K/ ~2 M, coldfi = Mid(oldpathname, InStrRev(oldpathname, "\") + 1)& _! r& R0 n4 o% L+ f6 O4 ~! ]' t) ^- t
oldname = Left(oldfi, InStrRev(oldfi, ".") - 1)2 d! N5 r1 [/ I# B M" H6 j! L, i& D; K# v% ?0 \: V
mip = InputBox("changename", "name", oldname)$ e* \5 I$ z- t; B" w/ i# P3 ]/ Q: ]$ u
If mip <> "" Then2 @; A( v# X L1 K
Part.Extension.RenameDocument mip8 b: X. F' n' y w
$ u+ c1 @0 p. b: U- P Part.Save
0 i$ e7 u2 A/ B( f tmpfi = Dir(Path & "*.SLDDRW")# B0 x4 V& j' G- H+ L
Do Until tmpfi = ""- v4 j; l6 {8 v9 h# M5 [
& U2 X2 `9 K: Z; T7 I$ a vDepend = swApp.GetDocumentDependencies(Path & tmpfi, False, False)
. C/ n( |' d: c If Mid(vDepend(1), InStrRev(vDepend(1), "") + 1) = oldfi Then% I+ Y3 @) [4 D" ]
" }- L+ E1 H; F8 w: _ Name Path & tmpfi As Path & mip & ".SLDDRW"3 X g) c) \% K
bl = swApp.ReplaceReferencedDocument(Path & mip & ".SLDDRW", vDepend(1), Path & mip & ntype)9 s+ K- S$ t8 i9 a& j' E0 B4 o2 @% w) y3 s# w3 a. O5 E7 x: d- I$ o
Exit Do
% a" R0 b2 s4 ^* l3 v2 l End If; i: v! K( A# ?8 [
tmpfi = Dir* @: D+ V& b H3 |; B+ J* }& P) r, B8 a `& } H) u0 |/ `
Loop
! c1 d7 J0 v- p+ A, AEnd If @/ K' \6 k [/ y
5 D3 X5 l7 _# T0 ]End Sub2
3 U& y& @; ?8 r! N- ^, L
5 z6 g0 G8 S+ X6 _6 k( ?5 C1 v6 M `* V( S
你好 我就是按你这提供的代码写的宏 |
