查看: 21057|回复: 30
模型改名同时改工程图
发表于 2023-6-9 13:46:29 | 显示全部楼层 |阅读模式
先在模型树选中所要修改的模型,再运行宏。宏内容如下:
% d7 |  a  o4 v" G. {& W6 a4 w2 U
  1. Dim swApp As Object& ?/ n4 E* @* G# C3 x
  2. Dim Part As Object9 T* T  o* G8 X3 R8 |9 A$ g
  3. Sub main()% I  d  [" \4 @* C) J8 Y% U. i2 r
  4. Set swApp = Application.SldWorks
      ~: o, e: V7 x5 e
  5. Set Part = swApp.ActiveDoc# a' q  j) Y1 q
  6. Set swSelMgr = Part.SelectionManager- h6 I, D4 p1 w3 T: G
  7. Set swComp = swSelMgr.GetSelectedObject(1) / h8 Q5 p9 O! d8 @  o$ q
  8. oldpathname = swComp.GetPathName
      E- U  l2 B; N8 @+ c6 B
  9. Path = Left(oldpathname, InStrRev(oldpathname, ""))! v+ ?2 W+ y6 ]- o
  10. ntype = Mid(oldpathname, InStrRev(oldpathname, "."))
    / r" N; L6 O# b. x: Q7 V
  11. oldfi = Mid(oldpathname, InStrRev(oldpathname, "") + 1)& q4 M/ }* ^7 O, B( F* y
  12. oldname = Left(oldfi, InStrRev(oldfi, ".") - 1)2 v( l( a7 u5 @
  13.      mip = InputBox("changename", "name", oldname)
    3 w' s# H- R: J& e; h4 {
  14. If mip <> "" Then
    6 J9 @8 l- P0 c+ g# q0 ^
  15.   Part.Extension.RenameDocument mip # j$ G! j5 R$ T8 R! i: S0 R
  16.   Part.Save
    ( B% c' R$ b9 x/ F! C
  17.   tmpfi = Dir(Path & "*.SLDDRW")$ [5 D: Y& V# N" u" B+ A5 ~
  18.   Do Until tmpfi = ""
    # h% t8 `8 {  c  r
  19.     vDepend = swApp.GetDocumentDependencies(Path & tmpfi, False, False)
    5 `* f8 Q4 ?* p6 B# ]. x
  20.     If Mid(vDepend(1), InStrRev(vDepend(1), "") + 1) = oldfi Then
    . g  L1 D; u- x, ?  l: F8 Y9 s
  21.      Name Path & tmpfi As Path & mip & ".SLDDRW" 9 d" E) O4 a, g& v0 A* B
  22.     bl = swApp.ReplaceReferencedDocument(Path & mip & ".SLDDRW", vDepend(1), Path & mip & ntype)
    1 J; P' y/ M5 Q+ I# R
  23.      Exit Do2 W, p* y8 U* r% T1 `, S, c- K
  24.    End If3 X3 |; ~0 n9 |% e3 c
  25. tmpfi = Dir
    5 o3 L! t# D9 h
  26. Loop
    3 L! X( i1 w3 k4 p
  27. End If
    ' ?1 _" H3 Z* X* R* s
  28. End Sub
复制代码
% E; m" L& A1 E9 ~9 V
- f; D, u% E$ p& K! R6 N
参与人数 2威望 +6 收起 理由
怕瓦落地2011 + 5 问题描述清楚,显得很专业!
happilly + 1
 楼主| 发表于 2023-6-10 09:20:42 | 显示全部楼层
本帖最后由 steve_suich 于 2023-6-10 09:21 编辑 5 S9 i1 k7 i0 j- U, \% [
shentu 发表于 2023-6-9 22:21
2 ~+ Z/ K& B' X同样运行出错。。。。。
Dim swApp As Object
# r* C4 V3 G2 k9 M. cDim Part As Object8 z: z! D5 `- R& ?; Q4 ?
Sub main()* J0 N8 g& I# Q  P3 |
- U3 G- @; g' n+ v% c% h5 r, ^+ `Set Part = swApp.ActiveDoc
2 r$ x/ j( O$ p# S( m. W7 ySet swSelMgr = Part.SelectionManager6 h0 \4 w% r  ]2 T, G; T
+ S" \6 t+ d" [7 ^5 noldpathname = swComp.GetPathName, }) G( [3 g/ R  Z% v5 T6 f, C7 M: G
Path = Left(oldpathname, InStrRev(oldpathname, "\"))
9 \2 ?8 ]: d- P: o' x& e' a3 n2 [ntype = Mid(oldpathname, InStrRev(oldpathname, "."))- m9 L( r+ x3 c. t; V& j1 X
oldfi = Mid(oldpathname, InStrRev(oldpathname, "\") + 1)
3 J9 J& Q. `, Z# m+ ?# ?) l( T7 toldname = Left(oldfi, InStrRev(oldfi, ".") - 1)
  y' F- g- L  R: f8 J% y. y: k. P     mip = InputBox("changename", "name", oldname)2 b/ L& r* q7 Z! }4 {: Z1 r
If mip <> "" Then9 t8 B& r; M+ \+ U0 F
* j1 \9 W+ r4 L* C+ D# o2 R  Part.Save
- K. E+ D5 ^9 o  d  tmpfi = Dir(Path & "*.SLDDRW")
; s# [4 f8 p* V& D( s; o  Do Until tmpfi = ""
7 Z0 H) m" E+ s  p" O    vDepend = swApp.GetDocumentDependencies(Path & tmpfi, False, False)+ O' G7 X- B7 m2 Y, S/ H
# o1 l0 `- p2 R" U     Name Path & tmpfi As Path & mip & ".SLDDRW"
6 s  \6 G/ g3 e- a  R# O    bl = swApp.ReplaceReferencedDocument(Path & mip & ".SLDDRW", vDepend(1), Path & mip & ntype)
5 _' a* f7 R2 O  G5 p& w7 e     Exit Do+ ?# h  Y4 `: y3 h$ l  G' S
   End If
6 C; ~; e3 v4 x  K8 W. Otmpfi = Dir1 G. B, o9 Q. G. X! m; _
Loop
# h, D3 s/ Z# h: n* X- ?: nEnd If
2 u3 ~, v. x* B) D5 VEnd Sub5 j5 J; Q' \2 F) J7 ~
' T4 N2 F+ E. l
  1. 6 Z' K; B0 C# {  t1 c
复制代码
! K0 V+ ?* {8 B4 ?0 R1 F
+ l- c+ `! d, E/ V+ R
If Mid(vDepend(1), InStrRev(vDepend(1), "") + 1) = oldfi Then正确的应该是If Mid(vDepend(1), InStrRev(vDepend(1), "\") + 1) = oldfi Then  发表于 2024-9-30 10:41
前面发帖是用代码方式,发现"\"符号缺失,所以运行有错。按以上文本方式就没有问题。  发表于 2023-6-10 09:24
发表于 2023-6-9 14:14:20 | 显示全部楼层
sw嘛?.
发表于 2023-6-9 14:24:40 | 显示全部楼层
你是chatgpt搞的?
 楼主| 发表于 2023-6-9 14:28:38 | 显示全部楼层
happilly 发表于 2023-6-9 14:14
' l0 ~- Z" t1 ^9 |  J# isw嘛?.
1 U8 L0 h" E' s# Z- n% qsw的宏3 l5 Z1 ^+ F! z3 f
发表于 2023-6-9 15:21:17 | 显示全部楼层
能说一下怎么用吗?
 楼主| 发表于 2023-6-9 17:21:12 | 显示全部楼层
行云亦 发表于 2023-6-9 15:21
2 u4 ^' ?( w0 ]) f$ R能说一下怎么用吗?
3 J% z! D" @& k7 H7 e1、sw 新建一个宏文件,内容按上面的代码。2、打开一模型文件(装配体或者零件)  W6 B/ m- ?& z, N
3、在打开的模型界面的模型树结构里面用鼠标点选所要改名的零件(或者子装配体)2 x8 `. W4 y3 C  X4 u% L& {
; b1 j! q& I' Z7 f3 o4、运行刚才建好的宏文件,---弹出输入框--输入新的名字--点确定---完成。. o; k: k" ?$ h
; C9 W, g8 C; ~/ d# G$ p$ t
% ^3 [3 q' Z5 y) W
发表于 2023-6-9 21:52:39 | 显示全部楼层
运行出错,08行有问题。错误91,对象变量或with 块变量未设置
发表于 2023-6-9 22:21:02 | 显示全部楼层
同样运行出错。。。。。
发表于 2023-6-19 10:59:33 | 显示全部楼层
steve_suich 发表于 2023-6-10 09:206 R8 n/ v2 {* ]5 ^
Dim swApp As Object
* r0 v4 K9 z( K- pDim Part As Object
6 x7 o; i0 }" @Sub main()
1 N4 t6 x) b7 h- m, b0 }4 l" [试了下,只改了part文件名,图纸没变,问题出在哪呢?% x) B5 i) `% M, \& Y/ u  S
/ ]9 L8 f6 v( ~8 g# u6 C9 h
要改的零部件不能轻化状态。  发表于 2023-6-19 14:50
GMT+8, 2025-10-18 14:43 , Processed in 0.066506 second(s), 17 queries , Gzip On.
