本帖最后由 danielwang 于 2023-2-24 18:31 编辑 / D* ~( p3 Z# v% p* g6 L' [7 w% x
j3 J1 ]. Q- f+ I$ c长三角有加工加工中心床身的企业吗?技术要求如下:
2 a. a1 n9 S7 {0 V$ s
. p" ], C- Q; J. H4 p& l7 K% `$ }
0 }) W! u5 N8 A3 S( O0 A8 r_Work piece size/工件尺寸
' ?' g- V% V, @- A_4200 (length) * 2300(width) * 800 (height)
" `& J# o }. F' k5 q_Raw weight: 6339 kg / Netweight: 6135 kg/毛坯重量:6339公斤/产品重量:6135公斤- l" W" J! x0 h; N: T) q! A2 R
_Quality requirement/质量要求
6 z6 {5 N o9 N0 L_Critical accuracy -> X- and Z-guide rails with a total length of 2 meters
% f7 X9 h' K6 R3 I5 K9 V" e) d* k_关键精度:X轴和Z轴导轨2米长度内) ]' N. M" n" K! `3 `/ i+ n% a2 ^% R
_Straightness /直线度: 0.005mm! |6 p6 z$ p8 W u9 ^8 A9 z4 g
_Flatness/平面度: 0.008mm
3 I7 v/ C; k/ h9 o, ]$ j0 T5 C_Parallelism/平行度: 0.02mm5 Y) ~1 ?) F6 X* ?! z P
2 ]$ a" X+ z6 \9 x! S! x8 }& U
