23.2.10" f+ |( y( v& g; J
Being brave means knowing that when you fail, you don't fail forever.( Q' b3 G$ ^; x$ K, U! q8 t
勇敢就是知道即使你失败了,你也不是永远失败。 ----Lana Del Rey
! s; r3 d H3 p每日一点专业英语:
0 a4 }% u9 F& j5 C1 [8 \Screw drive 螺纹传动5 J3 m- P% A/ ?$ g; g
Axial force exerted 受轴向力时
/ V) T) u$ @4 c4 w: ~' dRadial force exerted 受径向力时
' o$ H- v" o: h7 d) @& J/ a" T# v; Z, v4 q
23.2.11" J$ s4 E _. x3 m( _
Nothing great in the world has been accomplished without passion.; |$ F5 x& O* o& H5 L* c' u- O
世上没有任何伟业的成就能够离得开激情。& W7 N# n" F0 M* q' i! L
每日一点专业英语:5 c7 I I9 ], D: z
Bearing balls 滚珠
1 q9 i4 |" S0 ]* @" sBall nut 滚珠套
, ?; }9 _) R3 H1 l4 F0 ZBall screw 滚珠丝杠2 v+ d# J' k& O/ |1 @) [ k
4 `9 o: S& X2 f7 K* E! P
23.2.12
7 n. }/ `# h/ E; x2 kInstead of wondering when your next vacation is, maybe you should set up a life you don't need to escape from.* k& ]. G+ @, x' f( C( U% A9 P
与其期盼下一次假期,不如创造一种不需要逃离的生活。
6 z' v; `; h4 _8 g% j9 U4 L每日一点专业英语:
) f; p: u/ V& N; U& H5 dWasher 垫片
5 w, ^3 s$ \% }4 c( p% OFlush 凸起垫片
7 r7 V! u( v" Z* r8 DRaised 卷边垫片) w- b! p$ K+ `) ]/ \( @; f
Slotted washers 开槽垫片
' n* h! l& d5 h' |$ ~" F) }+ rSpring 弹簧垫片6 e! Z! }5 {7 N: O" u. ^8 o
Spring-locking 弹簧锁紧垫片
4 x- T' |' X" |- ~5 W. cPlain 普通平垫片
8 D1 X/ ]9 ^, P ?1 g1 P& i
! A/ j; p, u# _23.2.13" }- d- J( l' y- L/ {# ]2 y
It's never too late to be what you might have been.
# ?+ E/ {- a: h# P& C, J; R: T成为你所要成为的人,永远都不嫌迟。* g4 C7 L8 G$ Z, f$ W* l2 a1 W
每日一点专业英语:
6 R3 c4 ]+ _& | zBelt drive 带传动
4 C7 L9 Y! v8 Z: y- f5 K0 J+ `/ mFlat 平带
2 L5 U/ f2 m8 {' PVee type V带* H3 s% m' O A
Round 圆带& {! U( [4 ~4 z7 w- M
Multi-edges 多楔带' N; Q/ [4 u0 ], ]: y+ K
Synchronous belt 同步带
& m1 c4 q1 \5 w% X; ?
. `* K# @5 e% y7 D4 O( E; a23.2.14
) s% o4 k5 d& fPure love and suspicion cannot dwell together: at the door where the latter enters, the former makes its exit.+ \6 f6 K6 V" [9 J; o5 ?8 {( {/ K
纯洁的爱情和猜疑水火不容:起了疑心,就会丢了爱情。+ L. A% h0 o7 e$ x# r6 y! n
每日一点专业英语:
! d2 F) u; A7 L' a/ p7 ySolid wheel 实心轮( |- _. V, {! x5 r! R
Solid rim 实心轮辐条
( u* k, p" `( o$ v+ zOutside dia 外径2 f" Y" t+ i: [
Pitch dia 节径
$ t+ ^6 k2 X v. \7 W5 EGroove angle 槽形角
2 O* H: V& h% D$ ?" ^& aWidth 宽度+ O) G* Z# _4 }) u
Depth 深度
2 r1 m: O+ ^% L2 E8 \; B( ~" }! A5 r' M$ G+ q& f4 _
23.2.15* i4 a+ B; Q0 M
Growth is the only evidence of life.
4 G9 M' L6 R3 S8 d" v8 S Z; x# k* C成长是生命的唯一证据。
3 ]( n# _; P6 z& {; b8 Z每日一点专业英语:
# b+ f) G1 }; a6 F6 rGear drive 齿轮传动: d4 }% h0 ~* m, @8 B7 {
Spur gear 直齿圆柱齿轮传动1 t8 }7 M7 \: S6 v- Z
Helical gear 斜齿圆柱齿轮传动
2 ]4 o" A5 ?0 R0 nHerring-bone gear 人字齿轮传动
( p6 [3 O) X4 V1 E( e+ p+ tSpur bevel gear 直齿圆锥齿轮传动: J( p3 ~% u1 z& p( t7 A
Helical bevel gear 斜齿圆锥齿轮传动
; [( _4 g6 G' HCurve bevel gear 曲齿圆锥齿轮传动, h! F/ w$ u$ z4 K# b8 c
External mesh 外啮合
- ^( _, @! B% w3 ~! E9 oInternal mesh 内啮合/ j# z: _/ O4 U5 u5 @9 l/ l
Mesh by rack and pinion 齿轮齿条啮合/ E {* w+ T" n7 ?6 ?$ }! n+ j, }
7 R9 A0 _7 _* N$ Y
1 |4 U0 o/ X2 r- N4 d% U( @ t# j3 ^$ {9 s
- [9 o6 `" m+ ^' m/ u
1 Q8 ~ B4 W7 d/ f, } s6 x+ p2 ` l$ `7 r5 p( {" v* W
