Option Compare Text/ ]! k G# `0 v: ~8 p3 r. a1 H7 @/ k
9 T7 `/ ]) ]7 C, l% {9 E4 v2 K
Public Function GSXS(Ref)( |3 n& k3 S$ v. Z
: d7 n* A) R @. { G& }! p GSXS = Ref.Formula
4 y# u( D4 w0 K
/ h2 y& a5 F% E# n) GEnd Function
! ?1 t4 V( F' n& n @. _& i4 D- C. E$ _ @( J/ e
Public Function ZZL(RowHead, ColHead, Dummy)
" J$ D3 ?) ^8 ^/ }& J' @0 r/ ^- |" T* m# ?0 |" R# s2 L
Dim Values(20) As Variant
2 r2 L. _3 r; lDim PrevData(20) As Variant
! T" U4 j4 D3 P$ s' kDim LE(20) As Integer
" m# S2 W: z6 ~5 g' R) K( v7 G$ Z& Y7 i( G7 g+ v
On Error GoTo err_handler1
. z% ]* E* x! _' Do the vertical selection from rows1 T( N2 n* ]9 ?
If RowHead.Rows.Count = 1 Then5 t; F/ e/ c Q6 J3 I; b l
rindex = RowHead.Row ' first argument is any cell on the row of possible values. n. \. y1 ], i& M' P# P' v; L
Else
0 j% t+ }- P2 d* Y1 w ' Store the values to be compared with each column. R$ b4 @( X* @6 |
For ii = 1 To RowHead.Columns.Count) S9 e: W- Q( G, @5 F) b& C' A; I
rngname = RowHead.Cells(1, ii)6 G. ~2 l* g' W& I3 {( W$ [
LE(ii) = InStr(rngname, "<=")
; v- f, m$ A$ Q. Y- y: S# v8 e7 d9 J& E. ~ If LE(ii) > 0 Then2 F, {* b8 n( z# { s* B, H3 W
rngname = Mid(rngname, 1, LE(ii) - 1)
- Z6 X. l: V% M w6 O/ N End If8 v4 n2 N- g2 [- L; F: l
Values(ii) = Range(rngname). h6 C# U4 t7 T7 l" Z& a! }/ o) q9 h
'debug.Print "Variable:" & rngname & " is:" & Values(ii)! i8 f+ L2 o3 t# E
PrevData(ii) = "" ' initialise) a. U3 ^" u: j/ G: o
Next ii
' O3 X# z; W3 M: F& k) D3 C$ ]/ y6 x8 U1 f. Z J/ k6 S- K/ b# t7 _# Y
rindex = 2- {/ O) I% f4 M w# H) \
'debug.Print RowHead.Columns.Count) g( d5 r% z. Z
Match = False% n, u; M' t2 C% c/ \1 K
For r = rindex To RowHead.Rows.Count1 i( l0 ~& |- g
For c = 1 To RowHead.Columns.Count ' for each dimension3 V h* D8 n9 S6 B
data = RowHead.Cells(r, c)
* ~$ Y: P% O0 W* S/ m( t If data = "" Then8 m* r1 z# ?5 a3 `* \* e+ w- a# S
'debug.Print "Empty cell found: using " & PrevData(c)
% L1 P$ c! }9 V3 m% [+ c- b ' use the last valid cell in this column
+ M- X, \5 ~) b6 \1 o/ \ ' (this is to handle merged cells)
+ V% a4 I7 q+ c" h1 p data = PrevData(c)
8 w/ Z8 [$ T. B/ d) S8 h% h End If4 H# E6 y% I' s8 }# B, O
'debug.Print "data:" & data
& |+ n b. r @ PrevData(c) = data ' save for use by empty cells0 |( _' t* M0 P/ O
If data = Values(c) Or (data > Values(c) And LE(c) > 0) Or data = "*" Then
3 Q r- Z' t4 l If c = RowHead.Columns.Count Then ' All columns match - It's a go" p5 c; d* `) k, B- y' z
Match = True
6 w4 }: _( v& b4 q4 W$ p End If
) V( E Q) V* P/ l9 T ^7 p; b Else ' This column doesn't match - go to the next row
+ N/ @) H& @) V" Z7 [ Match = False
# c# i" p% ~+ `; e' X Exit For
% w4 {: [9 B" r! b End If* F: T! q) }2 Q7 t, o. I4 p
Next c2 F- i1 l0 S& r" j/ r; D4 A( g
If Match = True Then ' Don't search any more rows2 D: H$ @6 S/ i) A) K
rindex = r
) J# i) i" W1 U% D; ?5 h Exit For
+ H A) X' |% ~1 ?0 T End If
6 b4 P7 t/ S" m Next r
1 Y [! O' Q3 s* b( g
+ _. M* s( I3 Q8 v8 b5 [ If Match = False Then ' Didn't find a matching set of values
4 e; S2 V' L4 ~6 i' j ZZL = "No match for rows"
, n( [2 k) N6 g& f& z1 f1 L5 I: ?/ D Exit Function8 I" E* W) L+ B' y0 M
End If
4 t" Q. {: L! M3 K+ Z E, \: ?- A. X
E/ j. h3 M, o- g8 f rindex = rindex + RowHead.Row - 1 ' make absolute index' s3 | T X. t
End If0 G- F: s" ]) g: j1 e7 V- M
' T6 e0 N; c% g; O' Do the horizontal selection from columns6 n+ k$ O; X s9 H3 A# [$ J
If ColHead.Columns.Count = 1 Then1 N. s$ j) @$ h4 Z7 Y" g
cindex = ColHead.Column" S6 |8 ]. k* a$ X. ~+ d
Else8 Y/ n8 @1 q( u; X" I, n6 Q
' Store the values to be compared with each row of the header- S3 Z" I9 H6 M4 G6 \3 c
For ii = 1 To ColHead.Rows.Count& x& C* i7 k) _: c' r
rngname = ColHead.Cells(ii, 1)3 w3 z$ O0 s t) H' Q
0 y' P0 v. Q' i& t9 E1 d, W If LE(ii) > 0 Then) |2 s( l* h5 O9 y+ @' e; b
rngname = Mid(rngname, 1, LE(ii) - 1); p. J: N, q) m( \0 l1 N* x1 L! T9 c2 \
End If! y( I; s1 d. `* b n4 _* {$ L, C
9 q- r1 Y: M0 E 'debug.Print "Variable:" & rngname & " is:" & Values(ii)- |! Z/ V3 T# o5 s
# j/ \& `9 Z" Q# c# |. X% e6 c/ H Next ii
3 d4 T6 v) T0 n1 W, f; D6 d. x9 n% r' F. D$ D
cindex = 29 [/ Q& T( c$ \. ^
'debug.Print ColHead.Columns.Count
5 u) g; H D& W Match = False. R( j! v! o* \( T E6 r( N
For c = cindex To ColHead.Columns.Count
9 D; }& X, C; _, }/ U For r = 1 To ColHead.Rows.Count ' for each dimension4 }# F& I; W1 M* {2 P
data = ColHead.Cells(r, c): s! L! b' L7 I7 X7 l( `
If data = "" Then* X4 \6 m b! ~0 U% r
'debug.Print "Empty cell found: using " & PrevData(r)
; ?2 h& R1 e: Y' b$ h5 {% a ' use the last valid cell on this row
+ B g- C; S% [ ' (this is to handle merged cells)1 g, m+ ~2 Y; @, W: i3 S% W; m
data = PrevData(r)' X) p) M1 m' H$ a2 e* Q& [
End If# B) }6 X7 N7 F6 q9 D
/ s! f3 v$ b; O/ [2 A PrevData(r) = data ' save for use by empty cells7 {7 a5 q; l! Z( w7 |
If data = Values(r) Or (data > Values(r) And LE(r) > 0) Or data = "*" Then
) e& |+ N q% T7 I6 z' c% C) f If r = ColHead.Rows.Count Then ' All rows match - It's a go
$ E( Q$ J3 r7 V8 u' C Match = True
# E0 f& D5 `* h8 y" N1 L% M/ a End If4 b' z* d$ p) v* Q
Else ' This row doesn't match - go to the next column
4 z6 ^7 g4 j$ Y) F1 N J) s, [ Match = False3 \* p! `# _2 @+ r
Exit For
4 J% l5 }8 K X End If) l- T1 a' e4 O) E. F- {% D% S p
Next r
( U, r+ x" O" a7 d Y/ K7 ? If Match = True Then ' Don't search any more columns
! @2 R$ B( d& U m cindex = c
" Q: y/ ^, f1 [ Exit For2 I. R8 t4 V8 A1 e
End If
- p& Y, X9 M& d Next c
/ j2 b$ h1 w8 [* p; j. m
; t& Q- K- {8 A8 X If Match = False Then ' Didn't find a matching set of values9 h7 b/ \/ x4 g4 S2 y; }* A
ZZL = "No match for columns"6 [/ P3 q$ s: V7 f U9 B) L% m: E" X2 V
Exit Function
3 t# Y) K6 y% T! Y End If
& `+ I! g5 l1 ?/ ~: A2 r& B1 n/ V! F( E2 c% S
cindex = cindex + ColHead.Column - 1
9 M$ j: ]( z1 J4 dEnd If! [2 I: ~5 C) b3 m9 Z0 Q' T
$ G" @9 x5 l7 A0 @7 z5 @0 ?; Q) E' Return the cell value from Table1 W: U0 c4 Z, p3 [: Q4 D
'debug.Print "Answer is in (R,C): " & rindex, cindex# _) D4 K, C" Y, k
ZZL = ActiveSheet.Cells(rindex, cindex)
: i- L. @- `# c: `'debug.Print "Answer is : " & ZZL% c5 I5 {4 S+ G# q
Exit Function
. P0 R1 ^' a9 W( E
# P m p8 F4 q- [0 ? ierr_handler1:
9 F- D5 c$ Y' N+ _- o" FZZL = "Error on range '" & rngname & "'"; T! s4 F, Z% X+ Z, ?% w& I; ?0 J5 @: j6 n
0 G1 a2 C8 r4 G+ E& k3 L. PEnd Function" |! |. N: w* X8 L0 ~$ C- u
/ G& J6 z3 E1 W+ [! D
