查看: 1645|回复: 1
请教,子程序中,形式参数ldr10的值来自哪里?
发表于 2021-12-26 18:41:38 | 显示全部楼层 |阅读模式
一西门子840D系统子程序部分内容如下:: V1 A8 s1 W4 H
* X% P& n$ x4 V7 N, k
+ h+ g3 ^8 J& O5 A4 \1 ^' CPROC L3104 (REAL ld_r10,REAL ld_r20,REAL ld_r40,REAL ld_r42,REAL ld_r0,REAL ld_r1,REAL ld_r5,REAL ld_r6,REAL ld_r65,REAL ld_r66,REAL ld_r67,REAL ld_r68,REAL ld_r70) SAVE ; v8 X9 j4 @$ K6 I
DEF AXIS LV_X,LV_Y,LV_Z,LV_HEAD,LV_TABLE
! p. E8 F6 f2 m& GDEF REAL LV_RZE,LV_SHE,LV_MTA,LV_SHA, LV_SPADD1,LV_SPR,LV_MWX,LV_MWY
+ a8 f* o# d$ W, B* {8 b/ J; NDEF REAL LV_STAWI,LV_XAFA,LV_YAFA,LV_XMES,LV_YMES,LV_P155,LV_SPADD2,LV_SPADD35 Q( ~+ X" X2 }8 d; H+ r/ \4 q
DEF REAL LV_X1,LV_Y1,LV_Z1,LV_X2,LV_Y2,LV_Z2,LV_ZWRZ
4 S- a. D- {0 h( y% VDEF REAL LV_NPALTX,LV_NPALTY,LV_NPALTZ! l' [- X4 C1 p
DEF REAL LV_SPST,LV_EIW* |" u. P. m+ _. N6 ^) M
DEF INT  LV_WDH,LV_ANZ,LV_NPV,LV_GROUP8
# t0 C, X8 h# j! q5 o5 l/ J: h" P6 CDEF BOOL LV_MIT_ROT1 B# V, B6 U8 y' g5 M
DEF REAL LV_XX6,LV_XY6,LV_XZ6,LV_YX6,LV_YY6,LV_YZ6,LV_ZX6,LV_ZY6,LV_ZZ6
/ d( b4 {7 I. V/ NDEF REAL LV_V1,LV_V2,LV_V3,LV_V4- g2 K! S8 D& F* s
DEF INT  LV_V10,LV_V11,LV_V139 F+ \0 M, ^+ L7 V$ D: y6 f$ V
DEF STRING[10] MASCH_TYP
3 c+ f$ f! D7 t' q1 |DEF STRING[2]  MASCH_ORI8 Z+ ?# M$ x$ r& p" E
DEF REAL LV_ALFA,LV_HEAD_POS
. H# T; C- Y" D/ BDEF REAL LV_MXS0_X,LV_MXS0_Y,LV_MXS0_Z,LV_MYS0_X,LV_MYS0_Y,LV_MYS0_Z6 R: Y+ B' s* A9 k; L- z# a
if (($p_subpar[1]==false) and ($p_subpar[2]==false) and ($p_subpar[3]==false) and ($p_subpar[4]==false) and ($p_subpar[5]==false) and ($p_subpar[6]==false) and ($p_subpar[7]==false) and ($p_subpar[8]==false) and ($p_subpar[9]==false) and ($p_subpar[10]==false) and ($p_subpar[11]==false) and ($p_subpar[12]==false) and ($p_subpar[13]==false))0 J9 r$ }2 M- I6 a2 i+ [
else
; m/ I! D! ~0 p1 ?( Q& ^  R10 = ld_r10
# L. R8 Y, V8 G* M  R20 = ld_r20
; B' h0 B4 }; ?! r: J5 A  R40 = ld_r40
- o% \9 V- r$ J4 y# z" B! G2 L  R42 = ld_r42
5 u, @+ @) y8 U( B: x* G" H  R0  = ld_r0
4 |% Z# O9 x- x# J  R1  = ld_r13 l" {' G9 i( y( N$ E
  R5  = ld_r5
. h* N$ d+ S6 w( U! M& {  R6  = ld_r6
- \# J3 c! E) w  f+ d) Q  v) s" a  R65 = ld_r65
7 r; n; K  N/ T8 }0 G' c# O$ t* _  R66 = ld_r66
' L- r& U( [& Q0 G3 S, c( g0 a  R67 = ld_r67
# s$ m3 A" A. \3 c5 T" ?, a1 @" g" z  R68 = ld_r683 Z% r- O. b5 }+ `
  R70 = ld_r70
8 @  z" `1 ]0 Y7 D& O/ h8 tendif( S* |8 Y% A2 e
…………1 ~  N% t" R' G9 ?% a4 E$ c
; u# [& g" F8 J& L- X4 Q1 M& M
请教,子程序中形式参数 ld_r10等的值来自哪里?
 楼主| 发表于 2021-12-28 08:28:17 | 显示全部楼层
期待高手
GMT+8, 2024-11-23 12:12 , Processed in 0.055655 second(s), 15 queries , Gzip On.
