楼主 |
发表于 2021-3-21 09:53:43
显示全部楼层
不知道为什么,找了几个破解文件,都是这样的,到处是V170,从截图的图片上可以看出。下面的第4步搞不定,根据英文的意思貌似要运行SpaceClaim.exe,但是运行吧要输入序列号,破解说明中没有提供序列号,而且怎么怎么着也找不到SPACECLM_SSQ.dat,倒是有个SPACECLM_SSQ.lic
7 y6 z) H$ R/ e' h: r! O! Q2 O, K8 U: I/ j
( i7 W1 H# h0 h% ]8 Y( H: p
1. Install ANSYS Products 17.0. Do not install ANSYS License Manager. When asked for license server name input "localhost" (without quotes)
' l8 n3 N- Z% A, J; D8 S0 x& w S8 [% R" b& D1 P+ Q
2. Copy folder "Shared Files" to <ANSYS progdir> (by default C:\Program Files\ANSYS Inc\) and overwrite original files" I1 Y( g. g. P2 ]
" m8 C2 z- I: }, I# v9 G' [# a( m
Note: if you install ANSYS Products 17.0 in not default folder ( C:\Program Files\ANSYS Inc\) you need to open in text editor file ..\Shared Files\Licensing\ansyslmd.ini and edit path to copied from crack license file
0 z. p2 {5 [) O4 s9 e; |& b8 ] by default in ansyslmd.ini path is written as5 G r7 a6 ~" _% q
. N3 M4 Z4 o; w; y* ]+ ~, U
C:\Program Files\ANSYS Inc\Shared Files\Licensing\license.dat
[, R8 g; P X: l1 z; L" c2 h+ V6 W, ` e E7 ?
3. Unzip the ICEPAK NETEX-G crack to <ANSYS progdir> (by default C:\Program Files\ANSYS Inc\) and overwrite original files j0 M+ B* J s
Create environment variable ARTWORK_LICENSE_FILE pointing to <ANSYS progdir>\ARTWORK_SSQ.dat (by default C:\Program Files\ANSYS Inc\ARTWORK_SSQ.dat); S3 ^2 r& `- [5 Y7 G$ N! [
" P6 U% J. U8 v# @: ^" l
4. To run Dynamics for SpaceClaim in ANSYS SCDM embedded as a full standalone SPACECLAIM, rename the file <ANSYS progdir>\scdm\ansys120.ico (by default C:\Program Files\ANSYS Inc\scdm\ansys120.ico)+ X0 ]: a1 \: v
to _ansys12.ico. Copy the SPACECLM_SSQ.dat to <ANSYS progdir> (by default C:\Program Files\ANSYS Inc\).' i/ T) N8 s2 |- A" P
Create environment variable SPACECLAIM_LICENSE_FILE pointing to <ANSYS progdir>\SPACECLM_SSQ.dat (by default C:\Program Files\ANSYS Inc\SPACECLM_SSQ.dat)
8 C5 d$ E$ j/ [5 Z( ` W
/ n7 M$ \8 N1 ` C2 N# r5. Enjoy!
# |) Y% u4 v. D/ y3 u) N; t4 G% c5 y. P- h1 P( Q! q# v; t
/ H- l0 S9 v+ y. Z0 p% e; I4 E3 U6 T% \5 [$ q( R2 N1 f
Cracked by Team-SolidSQUAD (SSQ)
; S& W. [7 R/ h2 l
9 S1 G8 H8 |, w {6 i* y; `1 n! h; g' r) S3 F2 M( [0 x9 R
