查看: 2159|回复: 3
金属间表面磨损问题--请教
发表于 2009-1-12 16:39:01 | 显示全部楼层 |阅读模式
SS430不锈钢钢板和HQ SS302螺钉配合安装,拆下螺钉发现钢板接触面磨损--如图。" h! A, Y, ^# b' @* H; z9 a
磨损将产生颗粒,影响产品性能。0 w* y% s9 F6 w. V4 D/ e
不知道钢板换成铝合金板是否能避免表面磨损的问题?
 楼主| 发表于 2009-2-20 09:08:31 | 显示全部楼层
Galling is the welding of 2 mating parts due to excessive friction during fastenings. This can reduce the production yield of HDD. ) d' C7 R3 b5 |: v
8 X8 q9 r2 `8 L; ?) z/ b  I: b
来自网络:
2 Y5 f. x1 y' @- f: `- F( qAnti-Galling Fasteners 9 V) }3 T( G; [/ n. Q2 v- R
Unisteel pioneered anti-galling technologies in late 1999 to overcome what is termed as galling in the HDD industries. . O4 |6 z. ?. ]/ T. z
' c3 c% U4 Y1 l  [6 zGalling is the welding of 2 mating parts due to excessive friction during fastenings. This can reduce the production yield of HDD. Unisteel uses the CAMTRONIC and UNITRONIC materials to produce such anti-galling fasteners for HDD industry. Unisteel is amongst the leading manufacturer with technologies to produce such fasteners.
发表于 2009-2-20 16:14:48 | 显示全部楼层
只能减轻,不能避免
 楼主| 发表于 2009-2-20 16:32:20 | 显示全部楼层
原帖由 滕刚 于 2009-2-20 16:14 发表 2 i3 K% [& ^1 l: {& K0 d' u1 i- k  ~( |; e
只能减轻,不能避免
% D1 `. B/ M2 m- H
+ d- B* c# V- G  C绝对的避免是不可能的了,镀镍或者镀聚合物复合涂层能改善很多,只是成本问题又出来了..
GMT+8, 2024-11-26 20:49 , Processed in 0.051955 second(s), 16 queries , Gzip On.
