" j J" Q% Z8 f [; X" o
工程图转格式:
, r" T7 F* j" ]" i$ M
% `7 E7 `& B. V4 O `" {* D! E3 I0 G! v4 b; }( l% h
Dim swApp As Object. r* H% u8 Q2 r. c9 ]3 M
Dim Part As Object
9 Y# F+ F/ ^( Z; w" J; ]Dim Filename As String
& v: E1 c k+ |9 m$ |1 v3 N+ [Dim No As Integer
. J# v9 @" j; {8 @% I* HDim Title As String '以上设定变量
* s+ v' X$ d; ^" k0 |8 p3 u8 JSub main()) }- p7 s) Z- [
Set swApp = Application.SldWorks
8 @( e/ E& r" N F. X- `Set Part = swApp.ActiveDoc '以上交换数据
: E. R: ]7 r& X( _6 fFilename = Part.GetPathName() 'Filename为文件名
- E8 a) z+ L) MNo = Len(Filename) 'no为工程图文件名字符串总数
8 l' ~; m; w2 `/ W! \$ Q7 `If No > 0 Then '当NO大于0时(转换格式名称是工程图名称,故要先保存工程图才可转换,工程图未保存无名称,无字符串,不可进行一下步). I4 \3 m: z5 z3 L
Filename = Left(Filename, No - 7) + "." + Right(Filename, 1) '字串符操作,no-7为去掉工程图后缀名,"."+ right(filename,1)为增加后缀名最后一个字母作为识别,用于区别客户来图,可不要" {1 Q" o. o# U1 v# n. u) ^
Part.SaveAs2 Filename & ".dwg", 0, True, False '输出需要转换的格式文件,已有文件则自动替换,不提示,(有些格式文件在打开状态中不可替换,替换不成功也不提示)
3 m# V& j/ x, i: H0 x+ S) kPart.SaveAs2 Filename & ".pdf", 0, True, False: n! w# o1 C5 O9 Y" T {
End If
) s. L* k% Y4 p' `5 {* H! y8 Q& ^End Sub( N# k5 J; p8 g& D- O
; t8 m8 s; j z& M8 K1 l
- ^. G, _3 {7 f8 @$ D9 D- Z5 Z6 L- o7 c5 y7 {
属性改写宏:( e. J h8 o7 [, i/ L, w! X
! t/ G! j. r. d4 |" p; I; e( w
# S/ m9 U2 M- z' E: z
% T9 ]1 F* ~( q/ P9 x' ?Sub main()# o0 E5 E- I- s1 X- N, g! H( p; P
( B% Q4 n2 C! y8 e1 ] J4 |
Dim swApp As SldWorks.SldWorks
: N* a0 Z5 s6 }' [4 [) ?Dim swModel2 As SldWorks.ModelDoc2( ^8 G0 h* d; a, V9 r
Dim SelMgr As SldWorks.SelectionMgr
' T( C1 ~( | S( q* KDim vCustInfoNameArr2 As Variant
" Z2 P# q. e3 m0 g* y: TDim vCustInfoName2 As Variant, [9 Y- G* i A! e$ i) b* g
Dim CurCFGname As Variant
: c5 C' |! r2 cDim CurCFGnameCount As Integer
' K' ]! _8 P8 C+ W8 D* U) {+ B/ W7 [Dim Vnamearr As Variant
* f3 h' A: N pDim CusPropMgr As CustomPropertyManager
d# B1 q3 T) E4 S0 U7 _Dim bRet As Boolean
, M% v+ K! x5 |/ VDim Vnamearr2 As Variant" V0 ~: P/ y! a& W2 P
+ P, w, n0 ^1 D$ w2 S. NDim strmat As String! ` w: {. y- l/ B/ O: K7 c
Dim tempvalue As String
`( Y4 i. q; _: u* N2 h4 F. k+ S
% H' O4 |. G1 V3 i4 i# k( bSet swApp = Application.SldWorks3 A: p, c. {; v! A4 ~: T: @
Set swModel2 = swApp.ActiveDoc
" @9 \; n& f0 Z6 T) lSet SelMgr = swModel2.SelectionManager '
$ u1 {0 p5 \8 E3 q! g# B+ ^3 k0 o# N6 x5 }: h0 {. J
Dim tg1 As String
2 C, x" N! C0 Y3 s8 H6 Q! KDim tg2 As String
7 }9 I3 |2 \& k, L9 ~( {Dim tg3 As String
+ q# R: W4 W6 D7 s+ S4 kDim tg4 As String m' J6 W' _/ F7 _+ P+ ~4 {" j
Dim tg5 As String7 S0 Y9 x! j6 a) k. K0 r: u
Dim tg6 As String
& u1 ~# P' l& i( W: O9 _' X# |! qDim tg7 As String
: H9 I( d/ ?4 Q9 ?/ A2 X( p I6 ?Dim tg8 As String( W0 S2 Y3 e! L8 G
Dim tg9 As String
: q6 a4 I1 {1 e& d! fDim tg10 As String' u) p8 E$ K: h- T+ {7 p/ U
Dim tg11 As String% K, Z& ^6 y+ f- ~; I: n
Dim wm As String
4 ?, R4 V/ \; l( O/ MDim wm1 As Integer C1 ^* W1 D6 u, |
Dim wm2 As String8 S' D0 s. e, N% o1 s& O
Dim wm3 As String. S2 ?6 v) K0 D' @ I
Dim wm4 As String
( s' a. ]1 [/ NDim wm5 As String
3 n# _/ |7 x$ w8 |2 KDim wm6 As String; u+ O7 U; Z7 k+ h7 ]
Dim wm7 As Integer3 o$ q- B- k z U
Dim wm8 As String4 L" u- [6 O3 E3 f# c$ H
Dim wm9 As Integer( S4 z" Y- [, g2 J) V# W" _" N
Dim lz As String2 z8 b& s' r9 s4 O2 B y7 O: q) T
Dim lz1 As Integer2 k* B6 }: C1 A8 @# n$ w# P* i9 ^$ m
Dim lz2 As String/ B5 x4 E9 ?9 i
Dim lz3 As String
: l/ [; a) K$ n4 q2 t" R8 J+ V5 HDim lz4 As Integer8 I L1 I& v1 }: h; P+ {
Dim lz5 As Integer) c+ u* F; \4 a ]( X
Dim lz6 As String
$ m6 k+ _$ Z+ Z N X$ I" F2 r* o GDim lz7 As Integer '以上为设定变量, |) G- |; J( ^; O- J7 o
9 A3 ~; V' O3 o
2 m/ p [/ u( T" r" J! gswApp.ActiveDoc.ActiveView.FrameState = 1; q" Q3 e V. H) T: }
vCustInfoNameArr2 = swModel2.GetCustomInfoNames/ U4 `! V; ?: V" I( b' Z! w
If Not IsEmpty(vCustInfoNameArr2) Then
/ z7 v* c E: j5 } For Each vCustInfoName2 In vCustInfoNameArr25 L6 b' L) j R6 }7 |4 b$ T
bRet = swModel2.DeleteCustomInfo(vCustInfoName2)
* u! ^! F8 B) S Next L! H. V7 C# c3 W2 o
End If '此段是删除自定属性中的所有项和其项值
# M! N* d6 g8 r3 d
. b& {" K2 g: e. L" G+ d: ^" t0 X# s
CurCFGname = swModel2.GetConfigurationNames4 F% j; m7 S( e% G C1 B% l
CurCFGnameCount = swModel2.GetConfigurationCount
9 e$ W9 \1 G7 F) V$ nFor i = 0 To CurCFGnameCount - 15 w @5 z: \0 P/ F' g# [& X; h5 K
Set CusPropMgr = swModel2.Extension.CustomPropertyManager(CurCFGname(i))3 M: D3 T$ G# r% B. L4 w, n# x9 Q
Vnamearr = CusPropMgr.GetNames* W6 d! T( M0 U. [
If Not IsEmpty(Vnamearr) Then
" w" E6 j" f& Y6 i' k For Each Vnamearr2 In Vnamearr
- y4 _: Q, F1 ^* _- i bRet = swModel2.DeleteCustomInfo2(CurCFGname(i), Vnamearr2)
) t& G" b! `7 b p: ? U! V$ p Next
. _- t* h* Z; [4 n% H End If
, S/ X9 |" X" E" r( E Next '此断是删除其他配置中的属性所有项和其项值
4 z" E1 U- @0 |2 G
4 x& g# K/ o0 r1 v: P7 E* L
6 U7 d7 X" z' G& w( ?( Mwm = swApp.ActiveDoc.GetTitle() '定义是文件名
# k* a, w' [! Klz = swApp.ActiveDoc.GetPathName() '定义为文件路径% h2 ?0 C. C1 ]3 ^- |+ X
tg6 = Chr(34) + Trim("SW-Material" + "@") + wm + Chr(34) '定义材料属性
6 @9 ?# }7 p+ R Stg7 = Chr(34) + Trim("厚度" + "@") + wm + Chr(34) '定义钣金厚度属性
8 R( H8 e/ u0 a# ltg8 = Chr(34) + Trim("SW-Mass" + "@") + wm + Chr(34) + "kg" '定义质量属性
, Z; m% O E9 J0 |, ytg9 = Chr(34) + Trim("SW-SurfaceArea" + "@") + wm + Chr(34) + "㎡" '定义表面积属性
9 K4 y# R5 j5 {( G6 @; m0 IbRet = swModel2.DeleteCustomInfo2("", "图号") j+ H7 P0 M2 \: E7 e6 _2 n
bRet = swModel2.DeleteCustomInfo2("", "Description")4 ?& C+ c! }7 F( m/ g# H* F
% @: ^- G% F. q( W% E# b! u
9 H# `6 l u5 Q5 f2 ywm1 = InStrRev(wm, " ") - 1 '引号内为空格,为图名分离符号 '从右向左搜索到第一个" "符号为第几个字串符
: h$ [. B* e, r9 n/ ~7 OIf wm1 > 0 Then '当mw1大于0量时
% Q1 J" A' S6 s. C8 q# E8 ~% h+ _ wm2 = Left(wm, wm1) 'wm2等于从wm的左侧开始提取mw1个字符
) }6 H7 w& {& m wm3 = Left(LTrim(wm), 3) 'wm等于wm去除左侧无效字符的左前三个字符6 b" S4 ^2 Q# W6 V, C* f
If wm3 = "GBT" Then '当wm3等于"GBT"时% F F+ N. k: u$ D
wm4 = "GB/T" + Mid(wm2, 4) 'wm4等于"GB/T"和wm2的第4个和后面的所有字符 '当零件是国标时添加国标号,文件名中/是非法字符- J6 y4 W5 Y* k9 D9 A5 |: E0 k
Else
2 K( ]0 m0 Z! G8 C wm4 = wm2 '否则wm4等wm2 '空格前面是图号
2 ~/ O, ?! [% g* I. h2 n, O End If. V* F; m: B; H$ @
2 g. f1 K' F3 B! T7 @7 r wm5 = Mid(wm, wm1 + 2) 'wm5等于wm中的第wm1+2个后面的所有字符3 k7 H* B: A" p) [8 B9 p
wm6 = Right(wm, 7) 'wm6等于wm最后面的7个字符0 \# ]% i/ }( M& s1 a
If wm6 = ".SLDPRT" Or wm6 = ".SLDASM" Or wm6 = ".sldprt" Or wm6 = ".sldasm" Then '当wm6等于这4个值时
; P1 C# ?, `6 B4 H: n wm7 = Len(wm5) - 7 'wm7等于wm5的所有字符数-7
% C' S e$ t$ D" Q: [ Else1 c3 F- v5 d+ O
wm7 = Len(wm5) '否则wm7等于wm5的所有字符数6 k7 y7 L& t/ Y' [. @
End If
: T! q& _3 `& p$ w# T1 F tg5 = Left(wm5, wm7) 'tg5等于wm5左侧的wm7个字符 ,空格后面是名称,有后缀名并去掉后缀名,无后缀后(文件未保存时)直接上档
3 ?6 k- r: d0 U& E; [
) \6 L: H% ?$ F2 DEnd If '此段为图名分离定义
, r3 W$ M4 k- S8 c/ X# H
1 ~ u" `% N, f) D% A
1 g- l8 C% J; `; Q) TIf wm1 > 0 Then '当wm1大于0时" \- \' X1 m/ e4 x% M* J
tg4 = wm4 'tg4等于wm4 '文件名有空格时,图号为分离出来图号
) ^8 r8 ?; E" _) O# s* [7 IElse2 T3 Y6 _/ N$ Q3 o
wm8 = Right(wm, 7) 'wm8等于wm最后面的7个字符3 \5 j3 B b; g5 U9 x2 q5 F
If wm8 = ".SLDPRT" Or wm8 = ".SLDASM" Or wm8 = ".sldprt" Or wm8 = ".sldasm" Then '当wm8等于这4个值时: X- `. ?6 p$ ^, c( `" J
wm9 = Len(wm) - 7 'wm9等于wm的所有字符数-7
5 m) N* J! F3 r I$ o( S Else
2 a" N0 Q) M5 O2 P: Y9 E2 ] wm9 = Len(wm); p6 v" C9 S R9 n" V ^% r" P
End If '否则wm9等于wm所有字符数-7
4 I8 t) @5 T2 [* M2 O" t, otg4 = Left(wm, wm9) 'tg4等于wm左侧的wm9个字符 '文件无空格时,文件名即是图号,并去掉后缀名,无后缀名(文件未保存时)直接上档0 o( G4 p$ N2 }+ e. j; n ~
End If '此段为非图号名称命名文件,将文件名加到图号属性- c5 f% o" l- R! r" J2 \3 o' T
'例,fgq01-001 前门板:分离后图号(fgq-001),名称(前门板)# E" K0 o1 [) Y- C! e8 Z) U
'例,fgq01-001 前 门板:分离后图号(fgq-001 前),名称(门板)! d6 j( ]# g2 u5 X( G# m% H
'例,fgq01-001-前门板:分离后图号(fgq-001-前门板),名称为空$ a( }* g0 e2 I% f7 U" g
'以最后一个空格为准分离1 Q! [7 y- h* N/ D/ `0 X% F
3 m1 G5 N- K! j4 W, k6 z% O" r
6 m1 F2 r O# a8 W6 I8 X
lz1 = InStrRev(lz, "--") 'lz1为lz由后向前搜索到第一个"--"字符在第几个, P# x- u0 g1 ^$ U
If lz1 > 0 Then '当lz1大于0时9 O6 I3 \- }3 L& T
lz2 = Mid(lz, lz1 - 8, 8) 'lz2等于lz的第lz1-8个和其后面8个字符
0 d: _4 k; A' |2 w- M6 x: J! P& mlz3 = Mid(lz, lz1 + 2) 'lz3等于lz的第lz2+2个后其后面所有字符
" C3 `" g' j( [4 [- Q z6 E8 {8 R* ]lz4 = InStrRev(lz2, "\") 'lz4为lz2由后向前搜索到第一个"\"字符在第几个% ? M; Q, S. s5 W Z. o7 e% t
lz5 = InStr(lz3, "\") 'lz5为lz2由前向后搜索到第一个"\"字符在第几个6 l5 y' ?" H, @! l
tg1 = Mid(lz2, lz4 + 1) 'tg1等于lz2的第lz4+1个后面的所有字符; m* F! c$ X. S/ ]' ?2 w
'tg1 = Right(lz2, 8 - lz4) 'tg1等于lz2右侧的8-lz4个字符(lz2总字符为8个)$ d1 o& g( l4 Y# g9 U, | q
tg2 = Left(lz3, lz5 - 1) 'tg2等于lz3左侧的lz5-1个字符7 E1 v% t6 ~. ^; p2 Z& i6 N9 w
7 b, ~. }8 t% J' V" Q& p0 J; C! v' hlz6 = Mid(lz3, lz5 + 1) 'lz6等于lz3第lz5+1个后面的所有字符
0 C& L. }) O0 |; N- V0 ~lz7 = InStr(lz6, "\") 'lz7为lz6由左向右搜索出第一个"\"字符在第几个4 u0 c; m4 y' H- j/ `0 J2 L
If lz7 > 0 Then '当lz7大于0时( I4 Q |! O: c6 \3 B
tg3 = Left(lz6, lz7 - 1) 'tg3等于lz6左侧的lz7-1个字符
! @: F' p8 u- [0 j2 gEnd If
2 x# K- D" J. Z5 n; ^9 r4 AEnd If '此段为文件路径提取项目号2 m; k% l9 t$ {6 X& [
'例,零件文件完整路径为:E:\工作文档\B-非标产品\非标--F类\FGQ--定制角架\2020版\前门板.SLDPRT
) b7 V6 U) Z: n3 N" r) c/ o'由后向前搜索“--”,第一个“--”向前到“\”间为产品编号(FGQ),向后到“\”间为产品名称(定制角架),向后的第一个“\”和第二个间“\”,为版本号(2020版)。7 t3 C- ?# o; G4 c4 _* o
5 Z1 e+ ]# x9 X( h3 e
: F1 {% Z6 n8 d/ M0 [! g# q
0 P* i# L7 v1 o1 PbRet = swModel2.AddCustomInfo3("", "产品编号", swCustomInfoText, tg1)
- U. T$ G; P4 B; N; vbRet = swModel2.AddCustomInfo3("", "产品名称", swCustomInfoText, tg2)
; U9 e. a: e6 V' V' P3 y6 k) s; BbRet = swModel2.AddCustomInfo3("", "版本号", swCustomInfoText, tg3)
6 L+ h' U) T: c7 }8 H. X8 jbRet = swModel2.AddCustomInfo3("", "图号", swCustomInfoText, tg4)6 O. D7 Z& p9 i4 e# I
bRet = swModel2.AddCustomInfo3("", "Description", swCustomInfoText, tg5)
. ?3 T' w- F4 T9 W$ l+ ?bRet = swModel2.AddCustomInfo3("", "数量", swCustomInfoText, "1")7 u4 b1 Y& w* j# f$ V
bRet = swModel2.AddCustomInfo3("", "备注1", swCustomInfoText, " ")& j. [* m( y% e$ A
bRet = swModel2.AddCustomInfo3("", "备注2", swCustomInfoText, " ")* Z) i3 Z. w$ C6 q) [6 B. U# W3 L
bRet = swModel2.AddCustomInfo3("", "备注3", swCustomInfoText, " ")1 |* a1 {/ P+ }) z
bRet = swModel2.AddCustomInfo3("", "Material", swCustomInfoText, tg6)
j* J/ j/ h5 s! xbRet = swModel2.AddCustomInfo3("", "SH", swCustomInfoText, tg7)
6 q# u0 `$ e: `2 M$ IbRet = swModel2.AddCustomInfo3("", "重量", swCustomInfoText, tg8)5 O7 \% b4 ^0 C# J9 z# d& u
bRet = swModel2.AddCustomInfo3("", "表面积", swCustomInfoText, tg9) '此段为填写自定义属性项与其值/ O* D0 b4 U2 t3 B, l/ z$ `' f
5 e. i" |; P2 I0 e& M# r( p3 \
Dim thisFeat As SldWorks.Feature '另外增加一段宏,取读取切割清单数据,并添加到属性项。0 o1 o$ e+ k" H- |, _7 b6 J! w$ O
Dim thisSubFeat As SldWorks.Feature$ @2 u' l" ?5 O
Dim cutFolder As Object# ]8 [4 ^4 i' |9 r( b' N
Dim BodyCount As Integer1 O' a& u4 _* C: v/ X
Dim custPropMgr As SldWorks.CustomPropertyManager5 Z) J8 o* ?" G0 L
Dim propNames As Variant' J0 d$ k* k% R. ~1 _$ s4 L1 K
Dim vName As Variant
8 x& q, F) o. f- H7 ]. RDim propName As String
/ l) o9 D: r9 P" y ^6 K7 xDim Value As String
0 P$ T* u! r+ j5 Z( x' ZDim resolvedValue As String
: l P# T9 N5 s7 HDim bjkcd As Double
( B- S" Y, s+ e1 k9 }( RDim bjkkd As Double4 f0 j: |' y; L
'Sub main(): b; x1 \$ h8 ~$ ?1 l) j4 R' Q
'Set swApp = Application.SldWorks
/ d- `( j" |9 v. z0 C$ PSet Part = swApp.ActiveDoc, ~4 z5 l z: J% c
Set thisFeat = Part.FirstFeature
* H, L9 K9 r5 X4 B5 t- fDo While Not thisFeat Is Nothing '遍历设计树& U+ U; A0 R- ?5 V& \3 {
If thisFeat.GetTypeName = "SolidBodyFolder" Then2 w, Z& _4 |. Q( w* r
thisFeat.GetSpecificFeature2.UpdateCutList
5 A! k; J3 ~) Z* LEnd If
5 q' i5 z- L. ?6 w6 LSet thisSubFeat = thisFeat.GetFirstSubFeature) [- l0 x0 N; x- I
Do While Not thisSubFeat Is Nothing
b( K% j* c# \* u7 Z$ n4 K* B8 uIf thisSubFeat.GetTypeName = "CutListFolder" Then '查找切割清单. e y; {, F) p. l; v; A) p
Set cutFolder = thisSubFeat.GetSpecificFeature2
. r7 T7 Q* X5 e8 u6 ^* y, ?+ Z5 ]* gEnd If ]3 \9 p; F( r0 i# Z+ M$ P
If Not cutFolder Is Nothing Then
* S4 |! g, |0 a6 v, U5 f+ IBodyCount = cutFolder.GetBodyCount
' l4 b, i% s+ p' B" pIf BodyCount > 0 Then
& V1 j7 F9 l, ~Set custPropMgr = thisSubFeat.CustomPropertyManager5 A% m; F, J: i2 _8 @
If Not custPropMgr Is Nothing Then$ Q$ H( D# p9 s# Z" ?8 s% R3 G0 D
propNames = custPropMgr.GetNames '获取切割清单属性的数据全部名称并放入数组8 O6 \) I) @" `# ?- q) @
If Not IsEmpty(propNames) Then) V! c; R8 k# [1 f% W& f" }) T& W0 ?
For Each vName In propNames- | q0 e4 r- _( f9 C/ a/ y
propName = vName
" X$ J7 Y# }8 o+ c* qcustPropMgr.Get2 propName, Value, resolvedValue '获取全部属性名称 ,数值和评估的值
. u, x! l* B$ N& P, G4 zIf propName = "边界框长度" Then bjkcd = resolvedValue '判断是否是自己所需要的数据,如果是就获取$ W5 a0 ^) U! y; O* b2 i. u
If propName = "边界框宽度" Then bjkkd = resolvedValue
6 Q& i8 b8 }, O4 Y- d7 d' L: ]Next vName
& }1 x ?; c/ f, u& x& I3 l' IEnd If
]7 V1 p# C1 [2 y) x" n0 yEnd If8 H2 c1 h$ ]0 p- ^
End If
* a' y- ~& W% a1 b* s) t; y; `4 aEnd If2 _4 ]& c7 t( ]8 O
Set thisSubFeat = thisSubFeat.GetNextSubFeature
( ]5 t- @: k! R9 ]7 vLoop J% o+ K+ D6 W* ~& `3 Q$ x
Set thisFeat = thisFeat.GetNextFeature
- T0 U3 I, Z) |; ]Loop
/ S4 X) w' p4 N7 `'blnretval = Part.DeleteCustomInfo2("", "边界框长度") '删除属性栏上摘要信息的数据
" ? V/ I' g: g" K'blnretval = Part.DeleteCustomInfo2("", "边界框宽度")
/ X& W& k) Z& d6 ~1 @blnretval = Part.AddCustomInfo3("", "开料长度", swCustomInfoText, bjkcd) '添加数据到摘要信息
\: I* f7 I7 I# Y$ \7 H) pblnretval = Part.AddCustomInfo3("", "开料宽度", swCustomInfoText, bjkkd): z3 O' ~" y; Q( {
/ P6 o- V0 Q) ~, ^# j- G% y" ?% n! P
End Sub% d! n3 d. j: c; ~
* }: F+ e' Q' }! r( @ |
您需要 登录 才可以下载或查看,没有账号?注册会员
