楼主 |
发表于 2021-2-2 22:39:23
显示全部楼层
程序如下:
# d7 Z6 O2 h% y, B1 E( B/ O3 q; x4 @1 e+ o) \7 Q; i
操作系统: win7 64位
5 D# n5 a# A0 N/ v! u9 |IDE:VC++2010旗舰版
E% ? {0 B6 `! J" Y" f/ L视觉软件: OPENCV 3.0% F, B b/ q$ s! z, l5 R! ~* _
' p: T$ ]' ~* }* H$ }4 X
/ [- \+ W5 H# E2 G( s) s" w7 ^9 ^) v# I//#include "stdafx.h"
' L+ _% C$ H+ t1 q$ P& c" o#include "core/core.hpp"
/ A2 Z; I$ Z* u$ @2 {' f#include <opencv2/imgproc/imgproc.hpp>+ } ]+ ?( @/ q1 ]& n
#include <opencv2/highgui/highgui.hpp>* g ?/ h6 R1 t: P3 U2 r& @
#include <iostream>
3 j& M+ o. T. @ j' o r3 E7 Y2 I#include "highgui.h"
* C) H& N' L: m# i- s#include <set>
: d2 g3 L1 ]. d1 @2 Y5 |& {7 e#include <opencv2\opencv.hpp>
! H1 Q5 V/ a" R/ `: n5 t#include<vector> //包含所需要的类文件vector,还有一定要加上using namespace std。: _- W* X+ A6 W" j' K; G5 c9 W* V
#include <stdio.h>
4 |; @/ s! \% T, O1 e% `( l#include <conio.h>
0 o `" A5 j7 n% {. P1 R2 D8 m#include <opencv2/highgui/highgui_c.h>( v2 n) g$ E" |9 t
#include <math.h>
+ D/ w& Q% D2 z1 A' l2 M#include "iostream"
, T, n. M1 N- e( T, L! O4 W2 Z/ F0 ?9 Q#include "cv.h"
. ]$ L5 |3 I1 m& R6 p0 V5 d6 z% U8 V#include "highgui.h"
6 s4 C( i! t7 \* `7 z. E& m) Cusing namespace std;
6 |3 `" u5 Z- \( S9 }+ q6 O; _using namespace cv;; X& _2 F5 L* l+ p
! ], L% M+ p- X# x. P: k% _; h* p6 U# P, Y
4 u/ k4 j6 [9 P0 d) d0 [
//-----------------------------------【main( )函数】--------------------------------------------
2 K' X9 t$ w% J9 W// 描述:控制台应用程序的入口函数,我们的程序从这里开始) J# L; T0 g; c% p) @# y% Q
//-------------------------------------------------------------------------------------------------! v& q) c8 ?7 y2 z: r
. C9 u( D$ e* c. dint main()
% G# Q% t4 p$ z
! `4 |7 C8 B1 e{- W7 _$ E8 U/ ^9 N3 x
int chufa=1;
) s, a- s' {+ n! y7 a ?7 \% r //【1】从摄像头读入视频
- |1 y, Y6 z/ n3 A! p
6 \* r R3 e/ T& v! J' _, W+ w; u VideoCapture capture(0);% R; K+ v& R8 a4 Z
' V+ m4 c8 W: ?- V1 L' H9 a: Q( Z/ V Mat edges; //定义类
% p% P1 e. }8 ]" o2 M* L6 ]3 d9 S4 {1 m! i+ L1 `! r
namedWindow("预处理后的视频", 0);
+ p; o% E2 c. I9 V8 Z
6 \1 L) l- [, y# L7 h // Mat frame; //定义一个Mat变量,用于存储每一帧的图像,将该项至于循环之外,不要重复定义Mat,增快速度;5 e( @9 O3 X* ]9 H; j& `9 j
6 ]4 Q. N9 S) z! K! `& a9 e* ~//定义轮廓和层次结构(这个不是很理解) p1 h; _$ h( g9 C* g
9 {2 S$ a4 B7 r0 z1 e2 U `5 [* a
//vector<vector<Point>>contours; //其中contours 应该是一个变量,可以用在后面的轮廓查找的函数中,定义点的向量$ u% |7 E$ Y* J! M
- d* h% d1 A$ S! F- M4 L//vector<Vec4i>hierarchy; //定义四维向量???+ T$ ^9 y3 C9 v6 M. l4 q0 s
& }* e0 T. J* p C8 | i//【2】循环显示每一帧
/ i B$ \3 i( l3 @/ z0 F2 J* c( D2 A0 r. {! T% N1 n
while (1). d8 W! ^+ x4 K& n U
% }1 Q+ Q3 N) z8 G
{! R7 d: T( w5 ^ P4 N" A
: v+ y; M! M" R! S6 j# f
//读入图像
& v- _5 F, k2 d+ E* t: Y# C8 u
0 ^$ R: [, a8 u0 a Mat frame; //定义一个Mat变量,用于存储每一帧的图像,将该项至于循环之外,不要重复定义Mat,增快速度;9 c1 w0 B% r' t# i8 P% s
" L: a" y! I8 i( j) R' T
if (chufa=1) //当取样信号为1时,开始取当前帧,然后进行识别
8 A* J2 V/ R: a* D3 T
* Q3 W" v: O1 U! W: ]/ ]8 F {- x8 }) B/ j+ u( ^" l
% l! E: s5 y! G9 u
capture >> frame; //读取当前帧,videocapture函数是不断读取外界的视频,需要一个类来读取当前帧,& k; ?2 u6 Q* f! o9 Y
chufa=0; q, H+ h4 N5 G: Z' P, d1 P
/ s" Y3 g4 F" o6 y //对于只需要一副图片来进行检测的操作来说,每个循环只要出发某个取样信号,取样一次就好了。因此用IF语句& Y1 @; c( c! h% O" T
& D% ?6 l3 T9 o5 p
cvtColor(frame, edges, CV_BGR2GRAY); //灰度化 --如果说需要使用颜色检测蒜瓣的底部和头部,可能还需要颜色来判断
. p0 y: k% C$ f/ e6 y& W. `9 m' K8 e' R- g. f1 ?2 `
threshold(edges, edges, 120, 255, CV_THRESH_BINARY | CV_THRESH_OTSU); //二值化,将其变成黑白两色的图样3 @% X4 Q& V/ s' T& H4 u4 w) i
! @+ s4 q* ], u1 q
blur(edges, edges, Size(3, 3)); //进行模糊,使用3*3内核来降噪
; j! q2 T) W% X3 [ w: Y7 o9 M! p6 h+ M/ J: r
Canny(edges, edges, 0, 30, 3); //进行canny边缘检测并显示6 T i2 n. _# Z* q
) _. D. U6 Z$ ^ // findContours (edges, contours, hierarchy, CV_RETR_EXTERNAL, CV_CHAIN_APPROX_NONE); //要求原图像为8位单通道图像;其中edges是源文件,contours是轮廓函数??( C# ^1 T) J1 `# J- p5 ?
% c$ y e" R- e# u) z2 V. q, ^
//CV_RETR_EXTERNAL,仅需要外侧的轮廓用于识别, V$ m6 }& T4 E: m1 b$ V
, E% H8 J* {$ n. r //CV_CHAIN_APPROX_NONE,获取每个轮廓的每个像素,最好是连续的,
1 Y( Y4 |- _: q! t. A, F& b3 @ A9 i, M- p
% V6 R# J1 f0 h6 `$ E" R% G0 A; H) _. C0 g
imshow("蒜瓣轮廓图", edges); //显示当前帧
4 Z- f% x& `) v8 M2 S9 U3 k4 H# T6 Y/ X. X4 I w' i% a0 K- _0 E1 u
if (waitKey(30) >= 0)
7 a5 r- t3 ^. D8 f$ O c& X6 A8 e- c2 h8 z0 i/ j8 {: s
break;" |* I m+ u2 u7 m& ^
, L D9 R+ S8 l3 ? ' ]3 A- H/ f. x
$ C" ]' X. n( w/ p K1 L* N }8 u8 G8 y+ F3 Y4 Y' q8 ~
5 @1 o5 ^) [* i( F1 W& |, ^
return 0;7 U D1 O4 [8 h H; E
$ A3 }9 j4 y* J x6 N! Y
