有时候在程序里见到的都是缩写很不懂,小弟自己把刀具的名称整理了一些,希望于诸君共享。刀具: `/ ~% T5 u$ l/ w6 U0 G) y
FM :Plane PL
6 m$ F3 X- t, Q7 M Shoulder SH
- Y% c+ C" y3 ?; z5 }) H1 d: H" E Shellend mill SM
" K. p" {- _- a! S
, d/ ?- A, n9 @! j( @8 i, W EM: straight ST/ x7 K6 z! ?) h
Spiral SP h( Q' S1 H! d
Solid SL
: q8 }1 J; J4 s4 S" H2 S- m Throw away TA
( J2 o- S: t% b/ M2 e6 \ Counterbore CB
3 d; m$ X7 S4 y0 a$ R Igel IG; K. l( [7 A' |8 m
Herical mill HM5 x( V" v1 I3 g7 p
2 ]6 l9 D+ Z$ g) I4 C
CD: centerd rill CD0 e7 j1 g- _4 ^9 ~' [- C
Sinking drill SK& i+ ?; g% D; s( o& n$ S
; J2 H! h% R% E8 J3 q0 V; c
Stanelard SD: Z( G& \0 s% N- v5 r5 U
DR: spaderdrill SP- s, E" |+ g6 V* }- S% R
Throw away TA
( z _/ z/ @9 b4 b6 m; D Flat drill FT
7 X }; \+ S+ `/ b l; n2 j
! m* L1 J* w. o! c8 VBB: standard SD+ I* x6 E3 d! l$ z' R9 L
Countersink CS
6 J+ c j' y D' W( y/ O2 I Chamfer CF
) B! `) i( F" F9 x Back facing BF
# _3 I9 k' ~% Y* L Back chamfer BC! f! a" Q- u4 C
Combination tool CT
2 \5 q, c L, w0 }' ~, J: }$ Z% l8 t& j) T# J# ]
RM: straight ST
' v8 H! m! G6 V5 H( B3 G. X- N. f Spiral SP4 o8 O/ ?6 l" z/ Y: q8 A
Striker reamer SR8 _1 [5 P/ R" U! f t* m) J- O# p" `
) Q+ Q* h( `! L8 T/ C
TP: metric coarse MS# O5 B8 k: v: p# K0 K. g
Metric fine MF
& t* A: m" {7 _' y7 d pipe parallel PS
# M% }& ~" P! c- D7 W8 ], w# `7 w Pipe taper PT* E# J' e$ D/ b8 d) L, c( l& @1 m
Unified course NC
" s6 e# A {1 V# G5 Q) J9 S j Unified fine NF
r+ m) W5 f1 P% i Whit worth WT
/ ^' F; M9 y7 Q. c* b% }
4 G% D5 l7 L- |CS standard SD
: f5 D9 p1 Y/ X# }; ^ Throw away TA
/ {4 y& L& [! U6 L! R9 i) {( |AG standard SD0 K; g, Q& s; _" N. R
Solid SL3 ?+ O5 y) |' _$ Y! T
Throw away TA
9 u) s- e/ L1 i$ t3 y
R1 Z8 H0 ?% Q0 l k CF standard SD
: o' O: b" M. H Throw away TA3 ]0 l' r j/ P5 \
SC standard SD
" y% M9 }+ x+ J) o: m- P, Y5 E Throw away TA
C* H' ?" ?! w4 V4 z+ k TS standard SD
$ \! X: v2 T. K& W9 E6 a Throw away TA; f' s& @' g2 B% k I2 i% v
RC T slot type TS
+ Y' X. h `) V& q3 K: c, `6 F5 ? Side cutter SC
/ a7 r& [3 B+ H2 w- ^& o OG end mill type EM
6 {, U) S- R" b0 O l5 B. m3 a D T slot type TS1 k$ F" Q$ R0 E1 i6 V3 T
Boring type BB
1 f3 {, W" w5 G1 c4 J' g7 G BF erix spotfacer SF6 l5 O8 ~0 ]# X
Standard SD |
