楼主 |
发表于 2022-3-21 22:57:23
显示全部楼层
) C, D8 \2 ~9 H解决了,需要增加代码就可以了
7 \) X- j9 }' Q2 v2 b1 \3 b文件名命名格式(代号 名称)代号及名称中间有个空格,此代码以空格为间隔点,如果不带空格,那会全部显示成名称。
) A7 r8 U# l& w
2 ~+ \3 O# j# ^' w以下是零件代码
9 B/ P. c. \/ A) ?* s" T名称代码:Part.Extension.CustomPropertyManager("").Set("名称",Right(Part.GetTitle,Len(Part.GetTitle)-InStr(Part.GetTitle," ")" Z, d5 u5 l, w/ G" \
代号代码:Part.Extension.CustomPropertyManager("").Set("代号",Left(Part.GetTitle,InStr(Part.GetTitle," ")))8 e$ u' A- \9 ]% _- ~* ~- S
"Dummy1":= "名称代码"* _1 J( L% d* t
"Dummy2":= "代号代码"" D7 C& v7 ~2 h0 }4 t+ }0 W
(其中(Dummy1),(Dummy2)及(名称代码),(代号代码)可随意,保证上下一致即可。)
" z( g3 c% c5 s+ w0 J( f c$ L6 R- W
, s0 Z6 F3 ^* M9 S* }6 y 4 _2 L$ J! q) }' O" g9 b7 y _( D
6 R' d, z4 W$ i1 E' _
. } i% ~; o0 N# t) Y& P" u9 |8 |0 q1 I( T9 |7 k: T0 p2 I
( a# k8 M. d1 I& ^, i m0 ^/ ^
0 b; y$ Z7 P: m. M
# Q$ w4 O7 S; u U" r
- x( B# a) E: V; Z. D2 ?$ a- Q! V
3 Y; ~9 H) j9 h8 m/ g1 r+ [" @$ ~# ]8 P1 P' v# l8 d; Y4 G1 Z8 }
以下是装配体代码. X) O/ w2 M) \6 A! y# H, _
名称代码:Assembly.Extension.CustomPropertyManager("").Set("名称",Right(Assembly.GetTitle,Len(Assembly.GetTitle)-InStr(Assembly.GetTitle," ")))6 ^6 P1 w- ]7 d+ ^; R
代号代码:Assembly.Extension.CustomPropertyManager("").Set("代号",Left(Assembly.GetTitle,InStr(Assembly.GetTitle," ")))
$ G* Z8 `) p* H
% D" z! H+ Q7 K( H( O; c' F4 l6 ^' }"Dummy1":= "名称代码"
2 ]& `! C1 n" e"Dummy2":= "代号代码"
& L0 K4 v. ^' M C! N(其中(Dummy1),(Dummy2)及(名称代码),(代号代码)可随意,保证上下一致即可。) ]+ t' V+ }" c. x; V
0 L1 U* |/ Q1 T ' C; _# S. o9 U& @ }
% l1 d7 R ~$ g $ j( p& [ u/ M" B: A4 k3 k. G
* F/ h, W! H7 L& y- r |
