向前冲冲冲 发表于 2019-7-10 09:45:37
请教如何正确关联不同的solidworks文件类型?如图所示!
如右图所示,SW文件在文件夹类型一栏全显示“solidworks 2018 application”,无法分清装配,零件,和工程图,请教如何设置成左图这样的类型关联呢。
https://gss0.baidu.com/9vo3dSag_xI4khGko9WTAnF6hhy/zhidao/pic/item/03087bf40ad162d9b39881fb1fdfa9ec8b13cde7.jpgdata:image/png;base64,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
向前冲冲冲 发表于 2019-7-10 09:49:57
贴子上好像有个图显示不出来,我再描述下,同事的SW文件夹中显示的文件类型是很清楚,工程图就是工程图,零件就是零件,装配体就是装配体,而我的全显示‘:SolidWorks 2018 application’这种类型,请问怎么修改显示类型呢?
li1565682565 发表于 2019-7-10 11:54:07
你可以让文件夹按类型分组显示
li1565682565 发表于 2019-7-10 11:55:58
|li1565682565发表于 07-10 11:54你可以让文件夹按类型分组显示哦理解错了
远祥 发表于 2019-7-10 18:57:52
也可以根据数模的大小来区分,总装配图往往是最大的那个文件!
办法之一吧,我还是想找个法子让它显示成正确的类型
晨曦Ch3nX1 发表于 2022-2-8 19:09:47
解决方式,见附件图(不谢:D)
查看完整版本: 请教如何正确关联不同的solidworks文件类型?如图所示!
