依據配置特定屬性之"件號"及"名稱"存檔
分享在他網的回覆
' 依據配置特定屬性之"件號"及"名稱"存檔 - macro recorded on 10/30/18 by scliang
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swConfigMgr As SldWorks.ConfigurationManager
Dim swConfig As SldWorks.Configuration
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim nNbrProps As Long
Dim Part As Object
Dim Code_Name(2) As String
Dim valOut As String
Dim resolvedValOut As String
Dim longstatus As Long
Sub main()
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
Set swConfigMgr = swModel.ConfigurationManager
Set swConfig = swConfigMgr.ActiveConfiguration
Set swCustPropMgr = swConfig.CustomPropertyManager
' Get the number of custom properties for this configuration
nNbrProps = swCustPropMgr.Count
vPropNames = swCustPropMgr.GetNames
For j = 0 To nNbrProps - 1
swCustPropMgr.Get2 vPropNames(j), valOut, resolvedValOut
If vPropNames(j) = "代號" Then Code_Name(0) = valOut
If vPropNames(j) = "名稱" Then Code_Name(1) = valOut
Next j
'Debug.Print " Name, type, and resolved value of custom property:" & "代號: " & Code_Name(0) & " ----- " & "名稱:" & Code_Name(1)
Path_Name = swApp.ActiveDoc.GetPathName '取得"路徑名稱及擴展名",不管擴展名是否隱藏
Path_ = Left(Path_Name, InStrRev(Path_Name, "")) '提出路徑
Set Part = swApp.ActiveDoc
longstatus = Part.SaveAs3(Path_ & Code_Name(0) & " " & Code_Name(1) & ".SLDPRT", 0, 2) '依據配置屬性"件號"及"名稱"存檔
End Sub
图号分离? zx65606 发表于 2018-11-15 16:15
图号分离?
非也!如主題名稱.
Camtasia Studio 8.0 软件截取的
