伊凡 发表于 2008-6-10 16:05:51
求助:英语对照
1Bead roller w/tipping dies 水珠滚筒倾斜台模具2Caliper, dial
卡钳,刻度盘3C-Clamp, small
C型夹钳4Center punch, automatic 定准器(自动)5Circle template 圆形模板6Comma TP541D7Compass 罗盘8Counter sinks 计算接收器9Dividers
圆规10Dollies, round TP541A 铆钉头顶具,圆头11Drill bits 1/8"
1/8英寸钻头12Ear muffs 护耳13English wheel
英制车轮14File, Vixen, 1/4 round 锉15File, Vixen, flat bastard16File, Vixen, rat tail
17French curves 曲线板18Grinder discs, 4-1/2", 36-grit (air)19Hack saw 弓锯20Hammer, body (Eastwood) DISHING21Hammer, body (Eastwood) FLAT/WEDGE22Heel/Toe TP541B23Mallet, leather24Mat, cutting25Pliers, Cleko 1/8"
1/8英寸钳子26Profile gauge (Eastwood) 轮廓量规27Respirator 呼吸器28Roper Whitney hand punch 手动冲压机29Rubber gloves, box 橡皮手套,盒子30Safety glasses 不碎玻璃31Sander, dual action 80-grit disc 磨沙机,双重作用80-32Scales w/rulers 6", 12" 18", 48" 刻度标尺33Scissors 剪刀34Screw driver bit for drill 钻子上的螺丝刀35Scribes 划线器36Sharpies, box37Shot bag, large38Shot, steel for shot bag39Shrinker / Stretcher40Slapper, steel41Slapper, wood42Square, large combo 是带有刻录功能的光驱43T-Dollirs set44Tin snips, left, straight cut45Tin snips, right, straight cut46Universal PD541C/ PD541C 整件47Utility knife & blades /效用刀具
大虾们,帮帮忙,看看翻译的对不对,补全一下,谢谢啦!!!朋友说这是国外的作铝的冶金方面的客户发的?
[ 本帖最后由 ivantse 于 2008-6-10 16:36 编辑 ]
查看完整版本: 求助:英语对照
