baboon9105 发表于 2007-11-30 11:19:26
换热器的计算---请教
最近单位上新的项目,要选择换热器,但是如何计算?板式和管式有啥区别?
olive3000 发表于 2007-12-6 21:25:50
管式的不好,建议选用板式的。
hemei 发表于 2008-1-19 13:19:25
管式的冷却面积没有板式冷却面积大
天涯125 发表于 2008-2-11 02:54:59
可以查阅化工版的机械设计手册第4册上面有详细的介绍换热面积的算法
13572593532 发表于 2008-2-11 20:23:09
板式的换热效率高,不过最好选择好一些的制造厂家.小的可以用管式的划算.
液压青年 发表于 2008-2-12 09:13:20
这得看你需要得散热功率是多大,一般大的用板式散热器
开达 发表于 2008-2-15 14:08:16
COOLER
SELECTION
Designation:
PV = Power loss
P01 = Specific cooling capacity
V = Tank contents
ρoil = Density of the oil
for mineral oil: 0.915 kg/l
Coil = Specific heat capacity
for mineral oil 1.88 kJ/kgK
∆T = Temperature increase in the
system [°C]
t = Operating time
T1 = Desired oil temperature [°C]
T3 = Ambient temperature [°C]
Example 1:
Measurement of the power loss
on existing units and machinery.
For this method the temperature
increase of the oil is measured
over a certain period. The power
loss can be calculated from the
temperature increase.
Parameters:
The oil temperature increases
from 20 °C to 45 °C over
15 minutes.
The tank contains 100 l.
Heat to be dissipated:
PV =(∆T × C oil × ρoil × V)/t × 60
PV =25 × 1.88 × 0.915 × 100 / (15 × 60 )
= 4.78
Cooler selection:
– Desired oil temperature: 60 °C
– Ambient temperature air: 30 °C
P01 =PV    /(T1 - T3) =0.159
A 10% safety margin is
recommended to allow for
element contamination, and
therefore the specific power is:
P01 × 1.1 = 0.175 kW/°C.
The power loss 0.175 kW/°C must
be dissipated by an oil cooler.
Suggestion:
–Cooler OK-ELH2 - 3000 rpm,
P01 = 0.20 kW/°C at 80 l/min
我发了一段在上面!
查看完整版本: 换热器的计算---请教
