萧萧天竹 发表于 2007-9-14 08:28:16
变频电机和三相异步电动机的尺寸是不是一样的?
<P><FONT size=4>变频电机和三相异步电动机的尺寸是不是一样的?</FONT></P>
<P><FONT size=4>例如</FONT><FONT size=4><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">变频调速电机</SPAN></FONT><FONT size=4><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">YVF132S1-2和普通异步电动机Y132S1-2&nbsp; 都是5.5KW,它们的安装尺寸和结构尺寸是不是一样的,</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=4><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA"><SPAN style="FONT-SIZE: 12pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">变频调速电机</SPAN><FONT size=4><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">和普通异步电动机是不是只是前面的字母不同,其机座号相同就表示尺寸相同呢?</SPAN></FONT></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=4><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA"><FONT size=4><SPAN lang=EN-US style="FONT-SIZE: 12pt; FONT-FAMILY: 'Times New Roman'; mso-fareast-font-family: 宋体; mso-font-kerning: 1.0pt; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA"></SPAN></FONT></SPAN></FONT>&nbsp;</P>
如履薄冰 发表于 2007-9-14 08:40:33
Re: 变频电机和三相异步电动机的尺寸是不是一样的?
没有考证过全部,大部分是一样的。
机座号决定安装尺寸,机座号相同,其安装尺寸当然一致。
变频电机和普通电机的最大区别在于前者的风扇另由风扇单独传动,而普通电机的风扇是直接装在电机轴上面。前者不管转速快慢都能得到良好的风冷,而普通电机如果变频至低转速运转,则风扇转速不够,有可能让电机过热。
因此,如果电机经变频可能运转在低速时,应选用专门的变频调速电机,而如电机一直以较高转速运转,则用普通电机不会有问题。
这只是一点经验而已。至于两者之间究竟在结构和材料上有多大差异,还应请专业人士作答。
安装尺寸一样 只是变频的长 后面有个独立的风扇
byy26 发表于 2007-9-27 11:08:15
机座号一样就是一平的
electrode11 发表于 2015-1-26 18:19:49
害怕伏枥 发表于 2007-9-14 20:57 static/image/common/back.gif
变频电机和普通电机的最大区别在于前者的风扇另由 ...
谢谢正需要,变频电机和调速电机有什么区别呢?
查看完整版本: 变频电机和三相异步电动机的尺寸是不是一样的?
