中级塑料模具设计师知识试卷
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><FONT size=3><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">一、判断题(共</SPAN><SPAN lang=EN-US>15</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">题。将判断结果填入答题卡中,正确的填“√”,错误的填“×”。每题</SPAN><SPAN lang=EN-US>2</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">分,满分</SPAN><SPAN lang=EN-US>30</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">分。)</SPAN><SPAN lang=EN-US><P></P></SPAN></B></FONT>
<P></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><FONT size=3><SPAN lang=EN-US>1</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、在相同齿数的情况下,直齿圆柱齿轮模数</SPAN><SPAN lang=EN-US>m</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">越大,分度园直径越大。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5"><FONT size=3><SPAN lang=EN-US>2</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、塑料制品在充模流动方向上和垂直流动方向上的收缩率是一样的。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5"><FONT size=3><SPAN lang=EN-US>3</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、曲肘式注塑机和直压式注塑机相比较,前者提供的锁模力较大,后者防止动模板变形的能力较大。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>4</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、成型薄型较宽的透明制品,常采用扇形浇口,可以减小制品的内应力。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>5</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、潜伏式浇口应该设计成尖圆锥形。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>6</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、热流道系统主要由热流道板、热嘴、温控器组成。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>7</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、排气钢是一种新型的模具钢种,利用它可以改善模具困气的情况。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>8</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、浇口应该设置在塑料制品比较薄的地方,这是为了便于补偿制品冷却收缩。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>9</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、组合式型腔侧壁挠度与侧壁厚度的平次方成反比。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>10</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、气体辅助注塑成型(</SPAN><SPAN lang=EN-US>GAIM</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)通常使用的气体是氮气。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>11</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、有限元法是目前模具</SPAN><SPAN lang=EN-US>CAE</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">中的基本方法。</SPAN><SPAN lang=EN-US><SPAN style="mso-tab-count: 1"> </SPAN></SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><FONT size=3><SPAN lang=EN-US>12</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、使用液压抽芯机构,抽芯距离大,动作时间灵活。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>13</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、电火花加工中,相同条件下,使用石墨电极的电极损耗大于紫铜电极。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5"><FONT size=3><SPAN lang=EN-US>14</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、车削细长轴时</SPAN><SPAN lang=EN-US>,</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">为了减小径向切削力</SPAN><SPAN lang=EN-US>,</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">避免工件产生弯曲变形应减小车刀主偏角。</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 15.75pt; TEXT-INDENT: -15.75pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly; mso-char-indent-count: -1.5; tab-stops: 31.5pt"><FONT size=3><SPAN lang=EN-US>15</SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">、蚀纹(皮纹)加工是一种电化学加工方法。</SPAN></FONT></P>
Re: 中级塑料模具设计师知识试卷
二、单项选择题(共20题。选择正确的答案,并将答案填入答题卡。每题2分,满分40分。)1、关于零件标注,以下说法不恰当的是??。
A、尺寸不能多 B、尺寸可以封闭
C、尺寸不能少 D、表达清楚的情况下,视图数量尽量少
2、某模具流道凝料重20克,制品重15克,型腔数为8,优先选用以下哪种注塑量的注塑机???
A、50克 B、100克
C、200克 D、500克
3、一般地,比表面积最小的流道断面形状是??。
A、梯形 B、半园形
C、矩形 D、圆形
4、热塑性塑料熔体??。
A、是非牛顿流体 B、是牛顿流体
C、流动过程中表观粘度不变 D、流动过程中温度不变
5、对于气体辅助注塑成型(GAIM),不正确的是??。
A、制品残余应力降低 B、模具成本降低
C、制品综合性能提高 D、消除或减少缩痕
6、目前主流模流分析软件可以完成的分析是??。
A、压力降分析 B、温度降分析
C、困气分析 D、以上皆是
Re: 中级塑料模具设计师知识试卷
7、某套模具中,制品及流道在分型面上的投影面积为10000mm2,型腔平均压强为80MPa,请选择合适的注塑机吨位??。A、50吨 B、80吨
C、150吨 D、500吨
8、使用顶管顶出时,已知顶出行程为20mm,那么,镶针和顶管的配合长度设计较好的是??。
A、10mm B、25mm
C、50mm D、100mm
9、普通斜导柱抽芯机构中,增大斜导柱斜角会??开模距离,减小斜导柱斜角会??夹紧力。
A、降低、提高 B、降低、降低
C、提高、降低 D、提高、提高
10、互换性是指??规格的一批零件中,任取一件,??选择和修配,都能顺利地装配到机器上,达到设计规定的性能要求,这样的一批零件就称为具有互换性的零件。零件具有互换性,不但给机器装配、修理带来方便,更重要的是为机器的现代化大生产提供了可能性。
A、不同、不经过 B、同一、经过
C、同一、不经过 D、不同、不经过
11、斜滑块内侧抽芯机构(斜顶抽芯)在开模时,斜滑块(斜顶)除了??运动外,还完成??运动,从而在完成顶出制品的同时,完成内侧抽芯动作。
A、纵向顶出、纵向抽芯 B、横向顶出,横向抽芯
C、横向顶出、纵向抽芯 D、纵向顶出、横向抽芯
12、一般地,对塑件表面粗糙度影响较大的除了??外就是模具温度,??模温可改善塑件表面状态。
A、型腔表面加工质量、降低 B、型腔表面加工质量、提高
C、模具结构、降低 D、模具结构、提高
Re: 中级塑料模具设计师知识试卷
13、某制品一关键中心距尺寸为10±0.10mm,收缩率为1%,模具设计时,该成型尺寸设计较好的是??。A、10.00mm B、10.05mm
C、10.10mm D、10.15mm
14、以下常见塑料的收缩率由大到小正确的是??
A、PC>POM B、PP>ABS
C、PBT+30%GF>POM D、ABS>PE
15、使用潜水口注塑ABS材料,关于潜水口角度的说法,不正确的是??。
A、潜水口中心线与开模方向可以呈15° B、潜水口中心线与开模方向可以呈30°
C、潜水口中心线与开模方向可以呈45° D、潜水口中心线与开模方向可以呈60°
16、热流道技术是利用??的方法,使从注塑机喷嘴起到模具型腔为止这一段流道中的塑料一直保持??状态,从而在开模时只需取出产品,而不必取出水口料。
A、加热、熔融 B、加压、玻璃化
C、加热、玻璃化 D、加压、熔融
17、渗氮是模具热处理中常用的一种方法,它的主要目的是提高工件??硬度,硬化深度可以达到??。
A、表面、1mm B、表面、10mm
C、心部、1mm D、心部、10mm
18、一些注塑模具的成型部件采用镀铬处理,可以达到的目的是??
A、提高硬度 B、防腐
C、改善熔体流动性 D、以上皆是
19、1/20和1/50的游标卡尺,主尺和副尺每小格之差分别为??和??。
A、0.50mm、0.20mm B、0.05mm、0.02mm
C、0.02mm、0.05mm D、0.20mm、0.50mm
20、常见的五轴加工中心有两种形式,一种是??可做??,一种是工作台可做90°旋转。
A、主轴、90°旋转 B、主轴、平面运动
C、夹具、90°旋转 D、夹具、平面
Re: 中级塑料模具设计师知识试卷
三、问答题(共2题。请将答案填入答题卡。每题15分,满分30分。)1、请给出下面滑块的合适加工工序及简要的加工技术要求。注:该模具产量较大,尺寸精度要求较高。
Re: 中级塑料模具设计师知识试卷
2、根据下面模具装配图,完成问题:⑴、写出①到⑤共五块模板的名称(提示:该模具为三板模)。
⑵、请解释图示的机构名称及其可以完成的功能。
Re: 中级塑料模具设计师知识试卷
有答案吗 有没有WORD版本的? 对啊,楼主有答案吗?要是有答案就更好了 把答案也传上来阿??:handshake
