寂静天花板 发表于 2015-11-30 21:27:50
solidworks2016: PDM Standard 客户端
The SOLIDWORKS PDM Standard Client, is the user portal for your vault. This portal provides users access to the files in your vault, with the ability to view or modify the files depending on user permissions. Users can interact with the vault through a Windows Explorer interface, or directly from within SOLIDWORKS software.
在SolidWorks PDM标准客户端,为用户门户使用Vault。该入口为用户提供访问该文件使用Vault,以查看或修改根据用户权限的文件的能力。用户可以通过Windows资源管理器接口Vault中,或直接从SolidWorks软件内部互动。
Windows Explorer ClientThe Windows Explorer Client, shown in the image below, consists of three main sections:
[*]The Navigation Pane, allows users to navigate the folders and subfolders of the vault.
[*]The File Folder displays the file and sub-folders of the folder selected in the Navigation Pane. This area also contains pull-down menus that allow users to interact with the vault.
[*]The third area displays information about selected files within the vault.
Windows资源管理器客户端
在Windows资源管理器客户端,如下图所示,包括三个主要部分:
1.导航窗格中,允许用户浏览Vault的文件夹和子文件夹。
2.文件夹显示文件,并在导航窗格中选择的文件夹的子文件夹。该区域还包括下拉式菜单,允许用户与库互动。
3,第三个区域显示了有关存储库中选定的文件的信息。
SOLIDWORKS PDM ClientIn SOLIDWORKS, users can interface with the vault, by clicking on the SOLIDWORKS PDM Standard icon, in the SOLIDWORKS Task Pane. The function available in the Explorer interface, are mirrored in Solidworks
SOLIDWORKS PDM Standard, is added to SOLIDWORKS the same way as any other add-in.
SOLIDWORKS PDM Standard, can be configured for each user to control how messages are shown, generate Serial Numbers and modify View Settings.
SOLIDWORKS PDM标准版,可以为每个用户配置来控制信息列出,生成序号并修改视图设置。
查看完整版本: solidworks2016: PDM Standard 客户端
