关于ADAMS仿真---[图,求助]
<P>我用ADAMS做游梁式抽油机的仿真模型时,对驴头处的钢丝绳用连杆代替,并定义其与驴头的接触碰撞,但是仿真进行不下去了为什么啊? </P><P> </P>
<P>报错及警告:</P>
<P>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 0.0.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>ERROR: Abnormal termination encountered in ADAMS/Solver.<BR>ERROR: The simulation stopped at time = 0.0.<BR> <BR> The equations of motion can not be solved at this point because of a<BR> singularity in the Jacobian matrix. This singularity is due to the<BR> equation for PART pumping_unit.PART_39 ( PART/39 Xdot ).<BR>ERROR: The matrix is numerically singular.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 0.0.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>ERROR: Abnormal termination encountered in ADAMS/Solver.<BR>ERROR: The simulation stopped at time = 0.0.<BR> <BR> The equations of motion can not be solved at this point because of a<BR> singularity in the Jacobian matrix. This singularity is due to the<BR> equation for PART pumping_unit.PART_39 ( PART/39 Xdot ).<BR>ERROR: The matrix is numerically singular.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 0.0.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>ERROR: Abnormal termination encountered in ADAMS/Solver.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 3.85955E-03.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 3.87531E-03.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 3.87531E-03.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9254.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9255.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9255.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9255.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.4308.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.4308.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 4.4307.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.4308.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 4.4307.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.5731.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 4.5731.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.5731.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 4.5731.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.5731.<BR>WARNING: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> NOTE: The set of redundant constraints has changed at time = 4.5731.<BR> ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++<BR> <BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.6156.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.6156.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.6156.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.6251.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.6251.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.6251.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.8588.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.8588.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.8588.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.8724.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.8724.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 4.8724.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 5.0307.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 5.0307.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 5.0307.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 5.5871.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 6.1315.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 7.8049.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 7.8049.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 7.8049.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 7.8053.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 7.8053.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 7.8053.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9254.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9255.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9255.<BR>WARNING: The symbolic refactorization failed. The matrix is structurally singular<BR> at time = 2.9255.</P> 楼主解决了没呀,我也出现这问题了,高手帮帮忙:handshake 我也想了解一下这个问题是怎么解决的呀!
我的是仿真过程中对一个物体施加接触实现的还比较可以,可是再添加另一个物体在仿真就出现这个问题了, 我的错误代码是
WARNING: The symbolic refactorization failed.The matrix is structurally singular
at time = 9.01467E-02.
NOTE:The set of redundant constraints has changed at time = 9.01433E-02.
++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 回复 fynymq 的帖子
我现在也遇到了你去年遇到的问题,请问你是怎么解决的,谢谢赐教! ping21 发表于 2011-5-6 11:51 static/image/common/back.gif
回复 fynymq 的帖子
兄弟 我看他那处应该是柔性体,然后楼主用flexlink做成刚体,本身adams对这种仿真形式就不能很好支持。建议用有限元软件做成柔性体,导出mnf文件。而且你最好把你的模型贴上来,否则很难判断问题
我也碰到这个问题了,没有高手解决吗,,,所有约束副加上就有问题,去一个就可以运行。。。
