步进电机这个c程序怎么改电机频率阿?是改哪个参数频率能降低
#include<reg51.H>#include <intrins.h> //内部包含延时函数 _nop_();
typedefunsigned char u8;
typedefunsigned int u16;
sbit key =P1^0; //正反转
sbit key1=P1^1; //启动停止
sbit key2=P1^2; //加速
sbit key3=P1^3; //减速
sbit LCD_RS=P2^4;
sbit LCD_WR=P2^3;
sbit LCD_EN=P2^2;
sbit BEEP=P3^5;
sbit Ir_Pin = P3^2;
u8 Ir_Buf; //用于保存解码结果
u8 code table[]="Zhang and wh 0011 ";
u8 code table0[]="---- STOP 00R/M"; //初始 停止
u8 code table3[]="FOR SPEED 12R/M"; //启动 3档正转
u8 code table2[]="FOR SPEED 05R/M"; //2档正转
u8 code table1[]="FOR SPEED 03R/M"; //1档正转
u8 code table4[]="FOR SPEED 20R/M"; //4档正转
u8 code table5[]="FOR SPEED 30R/M"; //5档正转
u8 code table10[]="---- STOP 00R/M"; // 停止
u8 code table13[]="BACK SPEED 12R/M"; //3档反转
u8 code table12[]="BACK SPEED 05R/M"; //2档反转
u8 code table11[]="BACK SPEED 03R/M"; //1档反转
u8 code table14[]="BACK SPEED 20R/M"; //4档反转
u8 code table15[]="BACK SPEED 30R/M"; //5档反转
u8 code FFW={0x7F,0x3F,0xBF,0x9F,0xDF,0xCF,0xEF,0x6F};
u8 code REV={0x6F,0xEF,0xCF,0xDF,0x9F,0xBF,0x3F,0x7F};
u8 code SPD={0x18,0x16,0x12,0x08,0x06,0x04}; //五个档
bit flag=1;
bit flag1=0;
u8 j=0x01;
u8 s=0x00;
u8 d=0x00;
void int1_init(void)
IT0 = 1; //下降沿有效
EX0 = 1;
EA = 1;
* UART初始化
* 波特率:9600
void uart_init(void)
TMOD = 0x21;
SCON = 0x50;
TH1 = 0xFD;
TL1 = 0xFD;
TR1 = 1;
* UART发送一字节
void UART_Send_Byte(u8 dat)
SBUF = dat;
while (TI == 0);
TI = 0;
* 获取低电平时间
u16 Ir_Get_Low()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (!Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
return (TH0 * 256 + TL0);
* 获取高电平时间
u16 Ir_Get_High()
TL0 = 0;
TH0 = 0;
TR0 = 1;
while (Ir_Pin && (TH0&0x80)==0);
TR0 = 0;
void delay(u16 x)
u16 a,b;
for(a=x;a>0;a--)
for(b=10;b>0;b--);
void beep(void)
u8 i;
for (i=0;i<180;i++)
delay(6);
BEEP=!BEEP; //BEEP取反
BEEP=1; //关闭蜂鸣器
void sdelay(u8 n) //延时程序
u8 i,k;
for(i=2*n;i>0;i--)
for(k=125;k>0;k--);
u8 READ_COM(void) //读状态(命令)函数
u8 a;
LCD_RS=0; //命令(状态)字操作
LCD_WR=1; //读操作
LCD_EN=1; //操作允许
delay(1); //延时
a=P0; //读取状态赋值到a
LCD_EN=0; //操作禁止
return a; //将读取的命令(状态)字返回
void WRITE_COM(u8 com) //写状态(命令)函数,入口参数为命令(状态)字
LCD_WR=0; //写操作
P0=com; // 命令(状态)字准备好
LCD_EN=0; //操作使能位高脉冲
delay(10);
LCD_EN=1;
delay(10);
LCD_EN=0;
LCD_WR=1; //写禁止
u8 READ_DAT() //读数据函数
u8 a;
P0=0xFF;
LCD_RS=1; //数据操作
LCD_WR=1; //读操作
LCD_EN=1; //操作允许
delay(1); //延时
a=P0; //数据读取到a
LCD_EN=0; //操作禁止
return a; //将读取数据返回
void WRITE_DAT(u8 date) //写数据函数 ,入口参数为写入数据
LCD_RS=1;
LCD_WR=0;
P0=date;
LCD_EN=0;
delay(10);
LCD_EN=1;
delay(10);
LCD_EN=0;
LCD_WR=1;
bit LCD_BUSY() //1602液晶读忙操作,忙则返回1,空闲则返回0
return (bit)(READ_COM()&0x80);
void init() //1602液晶初始化函数
delay(15);
WRITE_COM(0x38);
delay(5);
WRITE_COM(0x38);
delay(5);
WRITE_COM(0x38); //设置显示模式
while(LCD_BUSY()); //读忙
WRITE_COM(0x08); //关闭显示
WRITE_COM(0x06); //指针加1模式
WRITE_COM(0x01); //显示清屏
WRITE_COM(0x0f); //开显示,显示光标,光标闪烁
void DISPLAY(u8 m) //显示主程序
u8 a;
init();
WRITE_COM(0x80); //设置初始操作地址
for(a=0;a<16;a++) //写入table1内容
while(LCD_BUSY());
WRITE_DAT(table);
WRITE_COM(0xc0); //设置初始操作地址
for(a=0;a<16;a++) //写入table2内容
while(LCD_BUSY());
switch(m)
case 0: WRITE_DAT(table0);break;
case 1: WRITE_DAT(table1);break;
case 2: WRITE_DAT(table2);break;
case 3: WRITE_DAT(table3);break;
case 4: WRITE_DAT(table4);break;
case 5: WRITE_DAT(table5);break;
case 10: WRITE_DAT(table10);break;
case 11: WRITE_DAT(table11);break;
case 12: WRITE_DAT(table12);break;
case 13: WRITE_DAT(table13);break;
case 14: WRITE_DAT(table14);break;
case 15: WRITE_DAT(table15);break;
int zfan(s,j,d)
flag=~flag; //按键后标志取反
if(flag) d=0;
else d=10;
s=j+d;
DISPLAY(s);
return(j);
int qting(s,j,d)
flag1=~flag1; //按键后标志取反
if(flag1) s=j;
else s=0;
s=s+d;
DISPLAY(s);
return j;
int jia(s,j,d) //通用加速主程序
if(j<5)j++;
elsej=5;
s=j+d;
DISPLAY(s);
return j;
int jian(s,j,d)
if(j>1) j--;
else j=1;
s=j+d;
DISPLAY(s);
return j;
void int1_isr() interrupt 0 //中断处理程序
u16 temp;
u8 i,k;
temp = Ir_Get_Low();
if ((temp < 7833) || (temp > 8755))//引导脉冲低电平8500~9500us
return;
temp = Ir_Get_High();
if ((temp < 3686) || (temp > 4608))//引导脉冲高电平4000~5000us
return;
for (i=0; i<4; i++) //4个字节
for (k=0; k<8; k++) //每个字节8位
if ((temp < 184) || (temp > 737)) //200~800us
return;
if ((temp < 184) || (temp > 1843)) //200~2000us
return;
Ir_Buf >>= 1;
if (temp > 1032) //1120us
Ir_Buf |= 0x80;
beep();
UART_Send_Byte(Ir_Buf);
s=Ir_Buf;
switch(s)
case 15: zfan(s,j,d);flag=~flag;j=zfan(s,j,d);break;
case 01: qting(s,j,d);flag1=~flag1;j=qting(s,j,d);break;
case 17: j=jia(s,j,d);break;
case 12: j=jian(s,j,d);break;
void main(void)
u8 i,k,s,d;
s=0;
d=0;
DISPLAY(s);
while(1)
{ uart_init(); //波特率初始化
int1_init(); //中断初始化
if( flag1 )
{ for (i=0; i<8; i++) //一个周期--八拍
if(flag) P1 = FFW; //取数据
else P1 = REV;
k=SPD;
sdelay(k); //节拍延时,用于调节转速
if(!key)
{ //正反转 //正反显示控制
sdelay(10);
beep();
if(!key) flag=~flag; //按键后标志取反
if(flag) d=0;
else d=10;
s=j+d;
DISPLAY(s);
while(!key) ; //按键灵敏
else P2=0x00;
sdelay(10);
if(!key1)
{ //启停转
sdelay(10);
beep();
if(!key1) flag1=~flag1; //按键后标志取反
if(flag1) s=j;
else s=0;
s=s+d;
DISPLAY(s);
while(!key1) ; //按键灵敏
if(!key2) //加速按键
sdelay(10);
beep();
if(!key2)
if(j<5)j++;
elsej=5;
s=j+d;
DISPLAY(s);
while(!key2) ;
if(!key3) //减速按键
sdelay(10);
beep();
if(!key3)
if(j>1) j--;
else j=1;
s=j+d;
DISPLAY(s);
while(!key3) ; //按键灵敏
这里调速度的五个挡的时间数,也就是电机运行的八拍里的每一拍的间格时间,比如你可调快一倍SPD={0x0c,0x0b,0x09,0x04,0x03,0x02};注意太快容易丢步。 Industrial 发表于 2014-7-19 22:22 static/image/common/back.gif
这里调速度的五个挡的时间 ...
我是要调慢阿。。。 能不能变通下,调慢你就把时间都加大就是了。比如调慢一倍把所有参数乘以2,改为
u8 code SPD={0x30,0x2c,0x24,0x10,0x0c,0x08}; //五个档 爱德利才知道要调步进电机的参数这么难啊!
