drmallreeve 发表于 2014-6-30 12:41:23
菜鸟DIY之:学人家做几只蛤蟆夹
看了好多人说,蛤蟆夹比那种组合压板效率好些,确实也挺烦那组合压板的,面上总是挡住不能铣,
先用SW设计一下(样式1):
http://diychina.org/data/attachment/forum/201308/10/122923vyqmqtytq9zmic3b.jpg
样式2:
http://diychina.org/data/attachment/forum/201308/10/122916nrm8j2zafxpsa9qu.jpg
下料45#钢板切割 :
http://diychina.org/data/attachment/forum/201308/10/122857l88jajssjajfzj8y.jpg
http://diychina.org/data/attachment/forum/201308/10/122917htz110007ve7022h.jpg
飞一下平面:
http://diychina.org/data/attachment/forum/201308/10/122856rs5jlsrsxszsfrvs.jpg
继续:
http://diychina.org/data/attachment/forum/201308/10/122855i359ol5la339at5f.jpg
放在一起看看:
http://diychina.org/data/attachment/forum/201308/10/122854ox6oysxc88cxcxdl.jpg
先弄下钳口之类的东西
http://diychina.org/data/attachment/forum/201308/10/122859uggahwgpkpgppeap.jpg
把蛤蟆身和头分开:
http://diychina.org/data/attachment/forum/201308/10/122902x1ro8a8hie5hr9yh.jpg
http://diychina.org/data/attachment/forum/201308/10/122903z3z1rhiklqzzqq69.jpg
http://diychina.org/data/attachment/forum/201308/10/122901qs7s016kkkzmmk7w.jpg
http://diychina.org/data/attachment/forum/201308/10/122858dxex0xxdy7e5ndad.jpg
试作的的一只蛤蟆头:
http://diychina.org/data/attachment/forum/201308/10/122905vadqw5359xozhijk.jpg
http://diychina.org/data/attachment/forum/201308/10/122905nabfzgnbffbog5vy.jpg
http://diychina.org/data/attachment/forum/201308/10/122904xahi0i8fqf808d80.jpg
先用“小強”(20MM自D的銑刀)给燕尾切掉一点,一会再用燕尾刀上:
http://diychina.org/data/attachment/forum/201308/10/122909oxs8jj22c1aza62n.jpg
http://diychina.org/data/attachment/forum/201308/10/122910r4f2j9tvt2vrhczr.jpg
http://diychina.org/data/attachment/forum/201308/10/122918fi44kk31biiw4t43.jpg
自D的燕尾刀来个特写:
http://diychina.org/data/attachment/forum/201308/10/122908iffu1upblfaozunx.jpg
http://diychina.org/data/attachment/forum/201308/10/122907cd60bt8uddtf1b8b.jpg
蛤蟆半成品排队中:
http://diychina.org/data/attachment/forum/201308/10/122921tkip81k0vn111jpp.jpg
http://diychina.org/data/attachment/forum/201308/10/122911ehym09zly60smyul.jpg
今天天色晚了,还下雨!拿出刚买的防锈剂喷一下先,
晕倒,卖家说的是“绿色环保防锈剂”,真的是绿色的,变成绿蛤蟆了
http://diychina.org/data/attachment/forum/201308/10/122920gz3xbxe96exa4wwe.jpg
http://diychina.org/data/attachment/forum/201308/10/122922iq9vj2ugj2849qwj.jpg
完成了
http://diychina.org/data/attachment/forum/201308/10/122913es3luuaxqaswy0ys.jpg
http://diychina.org/data/attachment/forum/201308/10/122915e0vvq1mv2k6hq3h7.jpg
http://diychina.org/data/attachment/forum/201308/10/122914x08uufx88800z0up.jpg
附上自D的倒角刀,适用12-20MM孔,及边线:
http://diychina.org/data/attachment/forum/201308/10/122852qdknnquqq0y42pnu.jpg
http://diychina.org/data/attachment/forum/201308/10/122853pa41mvm0sckzfme2.jpg
攻丝油(谁用谁知道)undefined:
http://diychina.org/data/attachment/forum/201308/10/123640nr5p4rn8r2p699xv.jpg
此次作业所用的刀具:
http://diychina.org/data/attachment/forum/201308/10/123718qnn04ffupunt2n8h.jpg
關於SW軟件製圖:
在当当网买的书,拿到手了看了一遍,软件装好,习题挑几个做,就差不多了,主要是把菜单功能搞清楚,
常用的功能就那几个,开个新文件,选一个工作面开始画,草图画好了就拉伸/旋转生成毛坯,
接下来模仿加工过程画加工草图,比如你手上有10MM铣刀,就画个10MM的圆,下刀和收刀的位置用标出坐标,
然后用切除功能设置深度,几个步骤下来,东西就基本成形了,最后把各步骤草图打印出来,上机的时候按这些坐标操作,
简单说就是人肉CNC。
http://diychina.org/data/attachment/forum/201308/10/123758zmzz000v7svy5oei.jpg
拖延症患者 发表于 2014-6-30 12:57:53
感觉很厉害啊
害怕伏枥 发表于 2014-6-30 13:14:28
欣赏,楼主高手!
arsasus 发表于 2014-6-30 14:49:58
蛤蟆夹这名字好奇怪,大侠请教下它具体怎么个用途?
把刀用好 发表于 2014-6-30 15:12:30
你的图片为什么有别的论坛的名字?
drmallreeve 发表于 2014-6-30 15:12:39
arsasus 发表于 2014-6-30 14:49 static/image/common/back.gif
以下用百度搜索结果进行说明:
蛤蟆夹是机床使用的一种通用楔形夹具,因其外形酷似蛤蟆而得名,需和机床配合使用,铣床和刨床上使用较多,适用于手工作业的夹紧和定位作用。特点是工作面上无剁面,精度比台钳高,作用和台钳相似。左图为国外常见蛤蟆夹。
蛤蟆夹的用途
蛤蟆夹是一种通用夹具,常用于安装小型工件。它是铣床、钻床的随机附件。将其固定在机床工作台上,用来夹持工件进行切削加工。
蛤蟆夹的工作原理
蛤蟆夹底座与梯形槽平台用梯形块联接,实现大距离的调节水平位移。用内六角扳手转动调节螺栓,通过调节螺栓的螺旋副带动前端滑块在机座上沿斜面上、下移动来实现小距离的调节水平位移,完成对工件的加紧与松开。
蛤蟆夹的构造
蛤蟆夹的装配结构是可拆卸的螺纹连接;滑块沿斜面的运动是由螺旋运动转变的;工作表面是螺旋副、导轨副及间隙配合的轴和孔的摩擦面。蛤蟆夹组成简练,结构紧凑,具体结构主要包括钳口块、蛤蟆夹滑块、调节螺栓和蛤蟆夹底座。
蛤蟆夹的突出优点
在完成对工件夹紧时,水平方向的夹紧力在沿调节螺栓所在的斜面进行力分解,能够得到一个垂直于斜面的分力以及一个沿斜面向下的分力,沿斜面向下的分力可以防止在夹紧工件的过程中前端滑块向上翘起。
drmallreeve 发表于 2014-6-30 15:17:18
把刀用好 发表于 2014-6-30 15:12 static/image/common/back.gif
你的图片为什么有别的论坛的名字?
我是新人,没有权限上传图片,只能链接外部图片。
呱呱的等待 发表于 2014-7-2 09:03:03
51上面 过来的高人啊……
amone 发表于 2014-8-1 15:04:56
有意思 不错
纯粹之火 发表于 2014-8-2 11:20:34
楼主nb
查看完整版本: 菜鸟DIY之:学人家做几只蛤蟆夹
