ljf-333 发表于 2007-3-21 21:20:43
油道漏油,产品的密封性---[求教]
我公司刚接了一个产品牵涉油道漏油的现象,据说别的公司也是采用的管螺纹丝堵和宛形塞来密封,但是还存在泄漏
<TABLE class=MsoNormalTable style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; BORDER-LEFT: medium none; WIDTH: 455.4pt; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-alt: solid windowtext .5pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=0 cellPadding=0 width=607 border=1>
<TBODY>
<TR style="mso-yfti-irow: 0; mso-yfti-firstrow: yes; page-break-inside: avoid">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 203.4pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" width=271 colSpan=2>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-size: 14.0pt">采用空气不同方法的压力</SPAN><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><?XML:NAMESPACE PREFIX = O /><O:P></O:P></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BORDER-LEFT-COLOR: #ece9d8; PADDING-BOTTOM: 0cm; WIDTH: 108pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" width=144>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-size: 14.0pt">测试压力</SPAN><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><FONT face="Times New Roman">(bar)<O:P></O:P></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; BORDER-LEFT-COLOR: #ece9d8; PADDING-BOTTOM: 0cm; WIDTH: 144pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" width=192>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; TEXT-ALIGN: center; mso-line-height-rule: exactly" align=center><SPAN style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-size: 14.0pt">最大允许泄露量</SPAN><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><FONT face="Times New Roman">(cm<SUP>3</SUP>/min)<O:P></O:P></FONT></SPAN></P></TD></TR>
<TR style="mso-yfti-irow: 1; mso-yfti-lastrow: yes">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 106.5pt; BORDER-TOP-COLOR: #ece9d8; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=142>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; mso-line-height-rule: exactly"><SPAN style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-size: 14.0pt">油道</SPAN><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><O:P></O:P></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; BORDER-LEFT-COLOR: #ece9d8; PADDING-BOTTOM: 0cm; WIDTH: 96.9pt; BORDER-TOP-COLOR: #ece9d8; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=129>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; TEXT-ALIGN: center; mso-line-height-rule: exactly" align=center><SPAN style="COLOR: black; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-size: 14.0pt">成品</SPAN><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><O:P></O:P></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; BORDER-LEFT-COLOR: #ece9d8; PADDING-BOTTOM: 0cm; WIDTH: 108pt; BORDER-TOP-COLOR: #ece9d8; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=144>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; TEXT-ALIGN: center; mso-line-height-rule: exactly" align=center><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><FONT face="Times New Roman">6.0<O:P></O:P></FONT></SPAN></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; PADDING-LEFT: 5.4pt; BORDER-LEFT-COLOR: #ece9d8; PADDING-BOTTOM: 0cm; WIDTH: 144pt; BORDER-TOP-COLOR: #ece9d8; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=192>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; LINE-HEIGHT: 18pt; TEXT-ALIGN: center; mso-line-height-rule: exactly" align=center><SPAN style="COLOR: black; mso-bidi-font-size: 14.0pt"><FONT face="Times New Roman">10.0<O:P></O:P></FONT></SPAN></P></TD></TR></TBODY></TABLE>产品做的是内直螺纹,丝堵是外管螺纹。请指教
kljt123456 发表于 2007-3-23 21:00:36
Re: 油道漏油,产品的密封性---[求教]
好象对问题没大讲清楚吧
给个图看看
295475272 发表于 2012-2-15 14:28:54
是的啊,不然怎么给讨论呢
yncxljh 发表于 2012-2-17 16:41:26
是不清楚,想象不出,如何解答?
查看完整版本: 油道漏油,产品的密封性---[求教]
