nkfbearing 发表于 2013-8-2 15:49:54
关节轴承尺寸表
            轴承型号外形尺寸额定载荷重量
    ≈Kg
ES2RSdDBCdkr1
    min r2
    min α
    ≈ 动载荷 静载荷
GE15ESGE15ES-2RS1526129220.30.3816840.027
GE17ESGE17ES-2RS17301410250.30.310211060.041
GE20ESGE20ES-2RS20351612290.30.39301460.066
GE25ESGE25ES-2RS2542201635.50.60.67482400.119
GE30ESGE30ES-2RS3047221840.70.60.66623100.153
GE35ESGE35ES-2RS35552520470.616793990.233
GE40ES GE40ES-2RS40622822530.617994950.306
GE45ES GE45ES-2RS45683225600.6171276370.427
GE50ESGE50ES-2RS50753528660.6161567800.546
GE55ESGE55ES-2RS55854032740.61720010000.939
GE60ES GE60ES-2RS609044368011624512201.04
GE70ES GE70ES-2RS7010549409211631315601.55
GE80ES GE80ES-2RS80120554510511640020002.31
GE90ES GE90ES-2RS90130605011511548824402.75
GE100ES GE100ES-2RS100150705513011760730304.45
GE110ES GE110ES-2RS110160705514011665432704.82
GE120ES GE120ES-2RS120180857016011695047508.05
GE140ES GE140ES-2RS14021090701891171070535011.02
GE160ESGE160ES-2RS160230105802091181360680014.01
GE180ES GE180ES-2RS180260105802361.11.161530765018.65
GE200ES GE200ES-2RS2002901301002651.11.1721201060028.03
GE220ES GE220ES-2RS2203201351002901.11.1823201160035.51
GE240ESGE240ES-2RS2403401401003101.11.1825501270039.91
GE260ES GE260ES-2RS2603701501103401.11.1730301519051.54
GE280ES GE280ES-2RS2804001551203701.11.1635701785065.06
GE300ESGE300ES-2RS3004301651203901.11.1738001910078.07
材料学子 发表于 2013-8-2 17:04:49
这个是要?知识共享?
luhaidong818 发表于 2013-8-3 13:27:06
知识共享
nkfbearing 发表于 2013-8-5 17:46:40
            SA…ES
Bearings number        d        D        B        C1max        d2 max        L1 max        h        L2max        d3        动Dynamic        静Static                weight
SA5E        5        14        6        4.5        21        16        36        48        M5×0.8        3.4        8.1        13        0.011
SA6E        6        14        6        4.5        21        16        36        48        M6×1        3.4        8.1        13        0.013
SA8E        8        16        8        6.5        24        21        42        55        M8×1.25        5.5        12.9        15        0.026
SA10E        10        19        9        7.5        29        26        48        63        M10×1.5        8.1        17.6        12        0.044
SA12E        12        22        10        8.5        34        28        54        71        M12×1.75        10.8        24.5        10        0.066
SA15ES        15        26        12        10.5        40        34        63        83        M14×2        17        36        8        0.121
SA17ES        17        30        14        11.5        46        36        69        92        M16×2        21        45        10        0.172
SA20ES        20        35        16        13.5        53        43        78        105        M20×1.5        30        60        9        0.283
SA25ES        25        42        20        18        64        53        94        126        M24×2        48        83        7        0.504
SA30ES        30        47        22        20        73        65        110        147        M30×2        62        110        6        0.835
SA35ES        35        55        25        22        82        82        140        182        M36×3        80        146        6        1.41
SA40ES        40        62        28        24        92        86        150        198        M39×3        100        180        7        1.86
SA45ES        45        68        32        28        102        92        163        217        M42×3        127        240        7        2.57
SA50ES        50        75        35        31        112        104        185        246        M45×3        156        290        6        3.58
SA60ES        60        90        44        39        135        115        210        282        M52×3        245        450        6        5.73
SA70ES        70        105        49        43        160        125        235        318        M56×4        315        610        6        7.94
SA80ES        80        120        55        48        180        140        270        365        M64×4        400        750        6        12.06
奔跑的羚羊 发表于 2013-9-5 18:48:47
有关节轴承W系列吗?规格型号怎么表示?
冷月波心荡 发表于 2014-2-13 21:29:14
路过,学习了,,,,,,,,,,
查看完整版本: 关节轴承尺寸表
