kisqin2010 发表于 2012-12-1 12:07:41
the determination of a factor of safety
The determination of a factor of safetymust also take into account such matters as the following: 1. Probability of accidental over-loadingof the structure by loads that exceed the design loads;2. Types of loads (static or dynamic); 3. Whether the loads are applied once orare repeated; 4. How accurately the loads are known; 5. Possibilities for fatigue failure; 6. Inaccuracies in construction; 7. Variability in the quality of workmanship;8. Variations in properties of materials; 9. Deterioration due to corrosion or otherenvironmental effects; 10. Accuracy of the methods of analysis; 11. Whether failure is gradual (amplewarning) or sudden (no warning); 12. Consequences of failure (minor damageor major catastrophe); 13. And other such considerations. Ifthe factor of safety is too low, the likelihood of failure will be high and thestructure will be unacceptable; if the factor is too large, the structure willbe wasteful of materials and perhaps unsuitable for its function (for instance,it may be too heavy).
kisqin2010 发表于 2012-12-1 12:18:06
欢迎补充
查看完整版本: the determination of a factor of safety
