zht_udb 发表于 2006-12-22 10:47:23
紧固件的热处理之二: 预备热处理
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>&nbsp;&nbsp;&nbsp; 冷作用钢要求进行球化退火,以得到铁素体基体上均匀分布的球化碳化物组织。</FONT></SPAN></P><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>球化组织硬度低、塑性好,冷作成形时不易产生裂纹。</FONT></SPAN></P></FONT></SPAN>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3></FONT></SPAN>&nbsp;</P>
<TABLE class=MsoNormalTable style="BORDER-RIGHT: medium none; BORDER-TOP: medium none; MARGIN: auto 6.75pt; BORDER-LEFT: medium none; BORDER-BOTTOM: medium none; BORDER-COLLAPSE: collapse; mso-border-alt: solid windowtext .5pt; mso-table-lspace: 9.0pt; mso-table-rspace: 9.0pt; mso-table-anchor-vertical: paragraph; mso-table-anchor-horizontal: column; mso-table-left: 14.4pt; mso-table-top: 39.05pt; mso-padding-alt: 0cm 5.4pt 0cm 5.4pt; mso-border-insideh: .5pt solid windowtext; mso-border-insidev: .5pt solid windowtext" cellSpacing=0 cellPadding=0 align=left border=1>
<TBODY>
<TR style="HEIGHT: 23.25pt; mso-yfti-irow: 0; mso-yfti-firstrow: yes">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 118.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt" width=158>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">钢</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp;&nbsp;&nbsp;&nbsp; </FONT></SPAN></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">号</SPAN><SPAN lang=EN-US><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></B></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: windowtext 1pt solid; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 252.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 23.25pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt" width=336>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">退</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp; </FONT></SPAN></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">火</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp; </FONT></SPAN></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">工</SPAN><SPAN lang=EN-US><SPAN style="mso-spacerun: yes"><FONT face="Times New Roman">&nbsp; </FONT></SPAN></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">艺</SPAN><SPAN lang=EN-US><o:p></o:p></SPAN></B></P></TD></TR>
<TR style="HEIGHT: 62.15pt; mso-yfti-irow: 1">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 118.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 62.15pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=158>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">(</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">ML</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">)</SPAN><SPAN lang=EN-US><o:p></o:p></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">10</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">15</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">25</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">15Cr<o:p></o:p></FONT></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">20Cr,15MB,15MnVB<o:p></o:p></FONT></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">20MnTiB<o:p></o:p></FONT></SPAN></B></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 252.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 62.15pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=336>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">69</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">~<?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" /><st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="720" UnitName="℃"><SPAN lang=EN-US>720</SPAN>℃</st1:chmetcnv>、保温<SPAN lang=EN-US>3</SPAN>~<SPAN lang=EN-US>5</SPAN>小时<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">炉冷至<SPAN lang=EN-US>550</SPAN>℃出炉空冷</SPAN><SPAN lang=EN-US><o:p></o:p></SPAN></B></P></TD></TR>
<TR style="HEIGHT: 37.55pt; mso-yfti-irow: 2">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 118.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 37.55pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=158>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">30,40,45<o:p></o:p></FONT></SPAN></B></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 252.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 37.55pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=336>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">74</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">~<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="760" UnitName="℃"><SPAN lang=EN-US>760</SPAN>℃</st1:chmetcnv>加热<SPAN lang=EN-US> 4</SPAN>小时、</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">66</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">~<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="680" UnitName="℃"><SPAN lang=EN-US>680</SPAN>℃</st1:chmetcnv>等温<SPAN lang=EN-US>2.5</SPAN>小时,<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">炉冷至<SPAN lang=EN-US>500</SPAN>℃出炉空冷</SPAN><SPAN lang=EN-US><o:p></o:p></SPAN></B></P></TD></TR>
<TR style="HEIGHT: 38.75pt; mso-yfti-irow: 3; mso-yfti-lastrow: yes">
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: windowtext 1pt solid; WIDTH: 118.5pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 38.75pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=158>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">40Cr,35CrMo<o:p></o:p></FONT></SPAN></B></P></TD>
<TD style="BORDER-RIGHT: windowtext 1pt solid; PADDING-RIGHT: 5.4pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 5.4pt; PADDING-BOTTOM: 0cm; BORDER-LEFT: #ece9d8; WIDTH: 252.3pt; PADDING-TOP: 0cm; BORDER-BOTTOM: windowtext 1pt solid; HEIGHT: 38.75pt; BACKGROUND-COLOR: transparent; mso-border-alt: solid windowtext .5pt; mso-border-left-alt: solid windowtext .5pt; mso-border-top-alt: solid windowtext .5pt" width=336>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center" align=center><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US><FONT face="Times New Roman">76</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">~<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="780" UnitName="℃"><SPAN lang=EN-US>780</SPAN>℃</st1:chmetcnv>加热<SPAN lang=EN-US> 4.5</SPAN>小时、</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">66</FONT></SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN lang=EN-US style="FONT-FAMILY: 宋体">0</SPAN></B><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">~<st1:chmetcnv w:st="on" TCSC="0" NumberType="1" Negative="False" HasSpace="False" SourceValue="680" UnitName="℃"><SPAN lang=EN-US>680</SPAN>℃</st1:chmetcnv>等温<SPAN lang=EN-US>4</SPAN>小时,<SPAN lang=EN-US><o:p></o:p></SPAN></SPAN></B></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-ALIGN: center; mso-element: frame; mso-element-frame-hspace: 9.0pt; mso-element-wrap: around; mso-element-anchor-vertical: paragraph; mso-element-anchor-horizontal: column; mso-element-left: 14.45pt; mso-element-top: 39.05pt; mso-height-rule: exactly" align=center><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 宋体">炉冷至<SPAN lang=EN-US>500</SPAN>℃出炉空冷</SPAN><SPAN lang=EN-US><o:p></o:p></SPAN></B></P></TD></TR></TBODY></TABLE>
查看完整版本: 紧固件的热处理之二: 预备热处理
