lilac1983 发表于 2006-12-21 15:41:53
求助:弯头识图
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>各位高手,本人是个新手,刚接到一张英文图纸,请见附图。</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>有几个问题想请教一下:</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18.0pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>1、</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></FONT></SPAN></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">图中所有尺寸均为英制,如要将全部尺寸换为公制,是否每个英制尺寸都要乘以</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">25.4</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">?</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 15.75pt; mso-char-indent-count: 1.5"><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>可不可以在画图时用英制画出,然后转化为公制呢?如果行,该怎样操作?</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-US><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p><FONT face="Times New Roman" size=3>&nbsp;</FONT></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18.0pt left 352.5pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>2、</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></FONT></SPAN></SPAN><FONT size=3><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">如图中,</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">1.25PATT</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">是何意?上部法兰右侧偏上方的</SPAN><SPAN lang=EN-US><FONT face="Times New Roman">PCB69.25</FONT></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'">是否为法兰上孔的中心圆的直径?</SPAN></FONT></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; tab-stops: 352.5pt"><SPAN lang=EN-US><o:p><FONT face="Times New Roman" size=3>&nbsp;</FONT></o:p></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt 18pt; TEXT-INDENT: -18pt; mso-list: l0 level1 lfo1; tab-stops: list 18.0pt left 352.5pt"><SPAN lang=EN-US style="mso-fareast-font-family: 'Times New Roman'"><SPAN style="mso-list: Ignore"><FONT face="Times New Roman"><FONT size=3>3、</FONT><SPAN style="FONT: 7pt 'Times New Roman'">&nbsp; </SPAN></FONT></SPAN></SPAN><SPAN style="FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'"><FONT size=3>如将此件用焊接的方式制作,则焊接成型后是否要做射线探伤或超声波探伤?</FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt; tab-stops: 352.5pt"><SPAN lang=EN-US><o:p><FONT face="Times New Roman" size=3>&nbsp;</FONT></o:p></SPAN></P><SPAN style="FONT-SIZE: 10.5pt; FONT-FAMILY: 宋体; mso-ascii-font-family: 'Times New Roman'; mso-hansi-font-family: 'Times New Roman'; mso-bidi-font-size: 12.0pt; mso-font-kerning: 1.0pt; mso-bidi-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA">谢谢各位大侠支招,本人在线等。</SPAN>
watercai 发表于 2006-12-28 12:43:12
Re: 求助:弯头识图
回答我知道的,呵呵,献丑了
1、公英制换算进率是25.4;如果要是采用autoCAD2007类的软件直接采用英制单位和国标都可以画出来的,没有什么影响,转换下就可以了;
2、PATT       =Partial Automatic Translation Technique,半自动翻译技术;
                  = Programmable Automatic Transistor Tester, 可编程自动晶体管测试器
两种翻译,可能不准确;
   PCB =Printed -circuit Board 印刷电路板;
            =Printer Control Box 打印机控制箱;
            =Propulsion Control Box 发动机操纵台
3、如果需要承受力的情况下,建议要做探伤;
不好意思,答的有不合理的地方,请大家多多谅解!请继续补充.....
kitlunkwok 发表于 2024-8-6 08:23:13
感谢分享,了解一下
查看完整版本: 求助:弯头识图
