为什么我用mastercam X4编的程序倒圆角成这样的?!
为什么我用mastercam X4编的程序倒圆角成这样的?!不是现实的R多少,而是现实的I和K。希望高手给予指导。谢谢。。。G0 T0101
G18
G97 S275 M03
G0 G54 X132.478 Z0. M8
G99 G1 X73.4 F.25
G0 Z2.
X400.
Z200.
X169.117 Z2.7
G1 Z-132.744
X171.228 Z-133.8
X173.
G0 Z2.7
X165.234
G1 Z-130.803
X169.517 Z-132.944
G0 Z2.7
X161.351
G1 Z-128.861
X165.634 Z-131.003
G0 Z2.7
X157.468
G1 Z-126.955
G18 G3 X157.814 Z-127.093 I-.534 K-.846
G1 X161.751 Z-129.061
G0 Z2.7
X153.585
G1 Z-126.8
X156.4
G3 X157.814 Z-127.093 K-1.
G1 X157.868 Z-127.12
G0 Z2.7
X149.702
G1 Z-126.8
X153.985
G0 Z2.7
X145.819
G1 Z-87.137
X148.378 Z-102.466
Z-126.798
G2 X148.7 Z-126.8 I.161 K5.347
G1 X150.102
G0 Z2.7
X141.936
G1 Z-63.876
X146.219 Z-89.533
G0 Z2.7
X138.053
G1 Z-40.614
X142.336 Z-66.272
G0 Z2.7
X134.17
G1 Z-17.353
X138.453 Z-43.011
G0 Z2.7
X130.287
G1 Z-5.823
X132.207 Z-7.205
G3 X132.558 Z-7.692 I-.822 K-.57
G1 X134.57 Z-19.749
G0 Z2.7
X126.404
G1 Z-3.026
X130.687 Z-6.111
G0 Z2.7
X122.521
G1 Z-.23
X126.804 Z-3.314
G0 X400.
Z200.
M9
G28 U0. V0. W0. M05
T0100
M01
(TOOL - 3 OFFSET - 3)
(车刀 75INSERT - CNMG 12 04 08)
G0 T0303
G18
G97 S275 M03
G0 G54 X121.594 Z.362 M8
G1 X132.022 Z-7.148 F.25
G18 G3 X132.162 Z-7.343 I-.329 K-.228
G1 X147.861 Z-101.391
G3 X147.869 Z-101.491 I-1.196 K-.1
X146.947 Z-102.436 I-1.2
G1 X139.025 Z-105.531
G2 X137.604 Z-108.35 I5.239 K-2.819
G3 X137.6 Z-108.393 I-.4
G1 Z-121.05
G2 X149.5 Z-127. I5.95
G1 X156.537
G3 X158.234 Z-127.352 K-1.2
G1 X171.766 Z-134.117
G0 Z200.
X400.
M9
G28 U0. V0. W0. M05
T0300
M01
(TOOL - 94 OFFSET - 94)
(OD THREAD RIGHT- SMALLINSERT - R166.0G-16MM01-100)
G0 T9494
G18
M05
G0 G54 X153.358 Z0. M8
G92 X148.505 Z-110. R-9.16 E6.35
X147.864
X147.328
X146.857
X146.433
X146.044
X145.682
X145.343
X145.022
X144.717
X144.426
X144.146
X143.878
X143.619
X143.368
X143.168
X143.168
G0 X153.358
X400. Z0.
Z200.
M9
G28 U0. V0. W0.
T9400
M30
这我还真不知道什么原因 后处理的问题,改下后处理就好了! 是的后置处理没有修改好加我QQ335998297 {:soso_e100:}后处理的问题 但是不需要修改后处理 在这里修改
这样安全可靠,后处理不要乱动,否则会出问题 本帖最后由 huang9112008 于 2012-3-5 22:52 编辑
cj0203 发表于 2012-3-5 15:41 static/image/common/back.gif
这样安全可靠,后处理不要乱动,否则会出 ...
你好,我找到自定义控制器了。应该改哪个?我都是过了怎么最后的程序还是I和K?
I.J.K编程一样用,后处理改不好就就郁闷啦 太乱了。。。有图纸就好了、、、、 谢谢啦,很好的东东 还是不习惯一段段读程序,下次麻烦把图上来好么?
