轴承HCS7004C.T.P4UL ,转速,品牌和代号的意思
这个轴承的转速,品牌和代号的意思。请详细告诉我。谢谢。 只能自己寂寞的坐沙发了 您好,这是FAG的陶瓷滚珠的角接触球轴承HCS代表陶瓷,有密封圈,C 15度,t 纤维保持架,p4精度是p4,UL,万能配对,即f=b。有其他不懂可以交流下。想买德国原装进口fag轴承可以联系我,qq38034116,绝非国产容易买到的假货。这陶瓷的,带密封圈,价格自己做好心理准备。C
Contact angle 15 °
Standard
E
Contact angle 25 °
H
High preload1)
L
Slight preload1)
M
Moderate preload1)
P4S
Tolerance class P4S
T
Solid window cage made from hard fabric
UL
Universal design, for example for fitting in pairs, bearing pair has slight preload in O and X arrangement
2RSD
Spindle bearing with sealing shields on both sides (in series B and HCB)
d20mm
D42mm
B12mm
a10mm
Da H1234,5mm
da h1227mm
ra max0,6mm
rmin0,6mm
m0,079kg Mass
Cr5700N Basic dynamic load rating, radial
C0r3200N Basic static load rating, radial
nG Fett670001/min Limiting speed for grease lubrication
Cur198N Fatigue limit load, radial
